Question about Iomega Computers & Internet
I have Iomega 1tb External Desktop Drive 2.0 USB, and suddenly it stopped letting me open it. When I tried to open it, I would get a message saying that I need to format the drive. Yet when i try to format it I get a message saying "Windows cant format drive. Check to see that the disk and drive are connected properly, make sure that the disk is not read-only, and then try again. For More information search help for read-only files and how to change them.." and once I close this message I get another message saying " Data error (cyclic redundancy check)" I tried using a different formatting software then the one i have on my computer, and once again I couldn't format it. Only this time I got a different message stating that my drive was write protected. I don't know what to do to fix my external drive.
  • 1 more comment
  • sk8terbugz20 Oct 02, 2010
    I followed your instructions but instead of formating the drive, the command prompt said "Invalid drive specification." What else can I do to fix it?
  • sk8terbugz20 Oct 03, 2010
    I disconnected the external drive from my computer and hooked it up to my dad's computer. I looked it up to make sure I had the correct drive name, and it is F. I pulled up the command propmt and entered "format F' and yet it still said "Invalid Drive Specification".
    President:
  • 2,777 Answers
This indicates the drive has failed, which is common for any drive, but for some reason Iomega's drives are notorious for this. Sadly the drive is "bad" so to speak. If you happened to buy it with a credit card you may be in some luck as far as you can get a refund at least on the drive. There is a good chance it may still be under the free extended warranty most credit cards place on electronics. Please contact your credit card company to inquire if they do this, and they will be able to file the claim and get you a refund for the TV.
Posted on Oct 03, 2010
  • Tim Grayson
    Tim Grayson Oct 03, 2010
    Oops, I accidentally typed TV at the end there, lol I meant drive. I am been working with a lot of TV's today, still have them on the brain. What I said though definitely applies to your drive, and is applicable, sorry about that.
    Tim
  • 4,737 Answers
Please connect it on another computer and format it from the command prompt. Once it's connected, note the Drive letter, i.e. E: or F: or which one. Now open the command prompt by clicking "Start", then "Run" (windows xp) or "Start Search" box (win vista and win 7) and type in "cmd" (without quotes), press enter. The commands are as follows, I'll assume it's drive letter is F:, in the command prompt window, type in "F:", press enter, then "format F:", again "yes" or "Y", you will need to confirm another warning, simply press enter and proceed, may take some time. After it's completed, you'll see another message, asking you to assign the volume name, give any name you like and press enter. That's all, if this doesn't fix, let me know.
The problem with this issue might be virus or drive partition corrupted or some technical/mechanical issues with the Hard drive. If it's infected by virus, then you should understand that the virus might still infect your system and so it is not possible to format it from your computer. On the other hand, you should check the usb cable and the adapter, and make sure they are properly connected and cleaned.
Let me know when you are done.
Good luck.
Thanks for using FixYa.
Posted on Sep 30, 2010
  • Lebanon Raingam
    Lebanon Raingam Oct 02, 2010
    What was the drive letter you saw on the My Computer folder? I only assumed it as F for you to understand, you have to use the exact drive letter, suppose if you see the hard drive's letter as F then do so or if it's E or G or H etc.... you have to select the correct drive letter in the command prompt. What you've just posted "Invalid Drive Specification" simply means, the drive letter you've selected is incorrect.
    There are still few more options, well, have you tried it on another computer? The best option is to format it from another computer, not from yours where it's not working.
    First connect the drive, open My Computer and note the drive letter, and then follow the commands on the command prompt.
    Let me know when you are done with more details.
    Good luck.
  • Lebanon Raingam
    Lebanon Raingam Oct 03, 2010
    It seems you've missed something "in the command prompt window, type in "F:", press enter, then "format F:", again "yes" or "Y".
    That should work, if it doesn't, then I'll give you a tool/app to format it manually. Once again, Good luck.
Iomega 2TB Prestige External Hard Drive NOT COPYING FILES
A shot in the dark but partition it as two 1tb drives.
Sep 02, 2017 | Iomega 2TB Prestige Desktop HDD USB
I have a white light on my iomega external harddrive. My computer does not recognize it. Is my data recoverable?
There is a chance that the only thing that isn't working on the external hard drive is the actual controller of the enclosure. What you could try doing is opening up the external hard drive to get at the actual drive that's inside. Go online and look for something called an IDE to USB adapter. They are usually relativly cheap, 10-20 bucks. This will plug into the back of the hard drive and then to the computer with a usb cable. See if the drive is readable. or if you have another open SATA port in your desktop computer, just try connecting it as a secondary hard drive. See if it will read it.
Mar 04, 2011 | Iomega 1TB Desktop USB 2.0 Hard Drive
I have a minimax 1TB external hard drive. All of a sudden it doesn't show up on my desktop any more. Any suggestions?
If it still has a valid warranty, exercise the warranty to get a free replacement.
Otherwise, open the enclosure, and separate the disk-drive from the USB-to-disk-drive adapter, and connect the disk-drive as a 'slave' disk-drive in a desktop computer, to see if the adapter was the problem.
Oct 24, 2010 | Iomega MiniMax Desktop - Hard drive - 500...
Suddenly my Iomega 1tb stopped working and i started getting a message saying that I needed to format it. When I treid to format it, I got a error message saying "Windows cant format.Check to see that the...
Have you tryed chkdsk in the command prompt, goto command prompt and type CHKDSK F: /F and press enter, this is a tool that checks your drives for any errors and hopfully should resolve any problems, rather than formating it and loosing everything on the drive.
Also have you tryed setting up the usb for mass storage in the bios somtimes there is a setting for this in the bios, or try setiing it back to factory defaults and see if that works.
The only other option would be to update your usb 2.0 driver in device manager in the properties of my computer icon on the desktop. hope this helps in some way and post back what happens.
Sep 29, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
No video
The No signal message is comming from the TV... not the media drive. The TV is not receiving a signal from drive ... Drive is the problem
May 12, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
Hello, I plugged in my iomega 1tb desktop hard drive storage device and the drive does not appear in my drive or computer. I do have the new hardware 'sound' that comes up but I dont have the drive show up...
Iomega 1TB Desktop Hard Drive is a dedicated usb 2.0 plug and play external storage device that has an ability to transfer at 480Mbits/second. having these large capacity storage drive needs a fast connection and additional power source to make sure to run the external unit system properly.
just make sure both power and data cables are properly plugged and connected respectively. if you are using it with a desktop, please always plug your usb connection from the Iomega 1TB external drive to the rear USB port in line where you built-in LAN is.do not plug it in the frontload ports. some motherboard manufacturers uses usb 1 and/or 1.1 only for frontload desktop casing provision.
thank you.
Dec 30, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
I've got 1TB external HDD from Iomega, and it was working perfectly, but suddenly, mz computer couldn't find the device. Power management is ok, and the USB cable too, so could you tell me, what is the...
im not sure..
but i think absolutely Driver Problem...
i hope it was helpful...
just find the cd driver in the box...
if there isn't try to download it from it's site!
Sep 12, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Can't transfer items to hard drive
Go to the Iomega Web sight and find tech support or Manuals/Guides and go from There??
May 30, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
1tb hard drive with 2 500gb hd's which i need to separate
Use a third party tool to split the drive. Drive image has that capability.
Nov 12, 2008 | Iomega 1TB Desktop USB 2.0 Hard Drive
Computers & Internet Logo
184 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
