Question about GPX HM3817DTBLK Shelf System
Stereo volume problem
Okay, when I turn on my stereo, it automatically cranks the volume up to 17. How can I stop this from doing it when I turn it on?
  • ilovemylife Nov 30, 2008
    the volume turns itself up and i cant turn it down
    Sniper:
  • 50 Answers
You could try resetting to factory defaults. To locate the reset button, turn the main unit around and look at the back. The reset button should be at the bottom left.
First turn the unit on, then use a paper clip or something similar (because the button is very small) to hold the button in for 10 seconds and then let go. See if this solves the problem. If not, try the same thing but start with the unit off before pressing the reset.
If it still doesn't work, I don't think there's anything you can do...the unit might just come that way (particularly given that others have complained of the same problem!)
NOTE: If I've answered your question sufficiently, PLEASE PLEASE RATE ME "FIXYA"...(it helps my overall rating!) Thanks!
Posted on Mar 16, 2009
Replaced stereo. When I turn volume up, why does it cut off?
The replacement stereo may cut off when the volume is cranked up too much.
Mar 30, 2016 | 2006 Suzuki Grand Vitara
When i turn the volume up to(17-20) my sound cuts out and my speakers make a cracklin noise.i have bought new speakers and rechecked all wires.my speakers are rated at 50 watts rms and my stereo pumps out...
It seems you needs more power to maintain the level of good sound.Maybe the maximum volume is 30 - then the mininum is 15 and you can't hear any cracking sound. If you exceed 15 the minimum, as you said starting 17 - 20 you hear crackling sound .Then you reach ,what they called the "cliping level"so much distortion and crackling sound,your stereo too small to accomodate .You must add a power amplifier so crackling will gone and to fit your listening pressure...
Hope it may help you;
Regards,
VOTIT
Sep 21, 2008 | Car Audio & Video
My right side speakers have stopped working fully. When I set it to only right side, i have sound, but it is extremely low no matter how loud I turn it up. It also doesn't matter if it is set to just...
Could be worn volume-control (potentiometer), dust/oxidizing on wiper-track of same control.
Buy contact-cleaner spray,such as Servisol, McKenic, Kontakt or similar.
If linear slider-type volume, attach tubular nozzle/guide thingy to spray head, squirt cleaner into slot while zooming back & forth (stereo OFF).
This scrubs the contacted surface while cleaning.
If rotary type, remove stereo, open cover, locate volume control, squirt into control while dialling up and down.
Allow a few minutes to evaporate (quick dry spray is best).
Oct 11, 2017 | 2008 Hyundai Elantra
I have a 2001 chrysler voyager installed a kenwood stereo and when i raise the volume to where its lound the radio will turn off and on untill i lower the vol
My electronics savvy source says you may be overdriving the amplifier in your Kenwood stereo to an impedance-mismatched set of speakers, meaning that the speakers are impedance mis-matched to the Kenwood stereo, and therefore operate ok (but inefficiently) at low volume, but cut off completely at higher volume.
Fix: match the impedance of your speaker network to the specs on your Kenwood car stereo. Once this is done, you should be able to crank up the volume to the point of permanent hearing loss.
SAFETY CAUTION - sound levels above 85 decibels produce NIHL (noise-induced hearing loss).
http://www.dangerousdecibels.org/education/information-center/faq/
Oct 18, 2011 | Kenwood Car Audio & Video
JVC Car stereo with cd shuts off when volume is turned up
Hi Ithink , you are trying to push too much power to your speaker setup. Your cd, tuner, player, is only go as loud as the volume at half way setting. Your speakers are , probally good ones that want more power, and making your player overheat and making circut protection cut power. I would say, you should use it at 15, and that is as loud as it should be played to aviod distortion and overheating.
I'm guessing max is like 25 or 30, Is that so? You can listen to louder tunes by installing an amplifier. Or if you have an amp in your system it may be overheating, I would really like you to let me know if you have been trying use it at volume higher than half the maxium volume setting, so I know I helped, and you can start looking into power amp's. You can crank it up for good parts, but most players were not made to send alot of juice to good big speakers at high volume level.
Tell me what you think, tooldoc
Dec 05, 2008 | JVC AM FM CD DET FACE CAR STEREO
HELP STEREO CUTS OUT!
ok , ive found the problem with mine. I checked the voltage between the earth wire on the head unit and the battery in the car. I found that when i turned the headunit up to around 17-20 there was up to 3volts differance, which is when it would cut out. So ive run a new earth wire and she's all sweet . Even the cd player works now.
Aug 11, 2008 | JVC AM FM CD DET FACE CAR STEREO
Volume Issue with CD Player by Durabrand.
it just seems a setting problem.
go to AUDIO SETTINGS or MENU.it will have "ON VOLUME".
press volume control -ve to get desired volume.
press AUDIO or MENU to store volume level.Next time u turn it ON ,the volume will be what u SET. OK i hope this solves your problem.
Mar 24, 2008 | Audio Players & Recorders
Durabrand CD Home Music System - Volume default
HM3817DTBLK:Default volume
I sent a note to the manufacturer. Communication attached below.
Dear Customer,
We thank you for your interest in GPX and our products. We apologize, but the volume level on the unit is a factory setting that we are not able to override or alter.
Once again, we apologize for any inconvenience this may have caused.
Best Regards,
GPX Consumer Service
>>> "Chris" 12/27/2008 2:02 ">x.x@eds.com> 12/27/2008 2:02 >> PM >>>
The default volume is set way too high on this radio. It is at 17 and we would like to reset it to a much lower level. How do I do this?
Chris
Jan 08, 2008 | Audio Players & Recorders
Car Audio Cutting Out
stereo is detecting a short , or low load on speaker wire and or speakers .Go behind car stereo , disconnect all speakers and apply a known good speaker to one of four wires and see if volume works normally ..If it works use same speaker on all outputs one by one ..If all are okay then you should figure out what speaker and or wires are causing issue..Also make sure your ground is okay
Dec 01, 2007 | Pyramid 4 X 10 SPEAKERS Car Speaker
GPX HM3817DTBLK Shelf System Logo
257 people viewed this question
Top GPX Audio Players & Recorders Experts
Sandy Moore
Sandy Moore
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
