Question about Dryers
How do I get access to the inside of a dryer?
I was changing my power cord and accidently dropped a nut down inside the dryer. How do I get access to the inside of the dryer to retireve this nut?
Thanks
  • 525 Answers
Almost all current dryers have front-access service. Access varies from manufacturer to manufacturer. Some panels are secured by snap clips, others by screws.Shock Hazard Warning! Be sure to remove the dryer from its power source before accessing internal components.
Posted on May 26, 2008
Replace dryer cord
There should be a cover where the cable goes into. Look at your old dryer - notice where the red, black, white and green cables go to - they should be marked. Compare those to your new dryer. With the power cord unplugged from the wall, remove the cord from the old dryer and install on the new one. The cord should have terminals already installed - you will need a socket to remove the nut holdng the terminals down.
If the power cord is really old and the insulation cracks when you bend the cord, replace the cord.
Dec 16, 2013 | Kenmore 700 6972 Dryer
What's color code for wires in back of dryer
Yes, here you go.
You should have 3 or 4 wires on/in the electric wire from the socket to the back of the dryer.
Open the plate and look at where the wires go to be hooked on.
You will see 3 screws or nuts in a row, left to right.
Carefully loosen these nuts or screws, be SUPER careful not the get them too loose, or they will fall off, sometimes down inside the machine.
Your electric cord has 2 hot wires, they are black and red.
These hot wires go on the right and the left screws, or nuts, but absolutely NOT in the middle!
The hot wires are interchangeable, the can go to the right or to the left.
You should also have a white wire in the cord, and that one, which should be in the middle of a 3 wire cord, attaches in the middle.
It is a ground.
If you have a 4 wire cord, you will have another wire, maybe blue or green.
That attaches to the case or the body of the dryer.
If your dryer has an extra green wire that comes from the inside and is fastened under a screw, that is where the 4th wire goes.
Be blessed.
Mar 03, 2013 | Maytag Neptune MDE5500AY Electric Dryer
I need to convert a 3 prong dryer cord to a 4 prong
Hi. Ok, with the rear terminal block cover open, you will see three wires. Black on one end, white in the middle and red on the other end. Use your 3/8′ nut driver to remove the nuts or a Phillips screwdriver to remove the bolts (depending on your dryer) and remove each dryer cord wire from the terminal block. When you remove the nuts or bolts, be careful not to drop them down into your dryer. Next, you need to disconnect the bonding jumper on your dryer. The bonding jumper is either a metallic strap (typically copper or copper clad) or a green wire that is connected between your dryer’s neutral (white wire) terminal and the green ground screw connected to your dryer’s frame. If you removed a ground wire instead of a bonding strap from the neutral terminal, you need to connect this ground wire to your dryer’s frame. Loosen the screws at the connector and pull the cord out. Now thread your new cord through the connector and tighten down. This only needs to be snug do not over tighten. Sometimes the old connector will work with the new cord and sometimes not. If not, your new cord will include a connector that you may use. Now,to hook up your new 4-wire dryer cord, connect each wire to the dryer’s terminal block matching color for color (white to white, black to black and red to red). Connect the green wire to the green ground screw on your dryer’s frame. Once the wires are connected, simply recover the space, and secure the cove with the screw provided.
Aug 24, 2010 | Maytag Neptune MDE5500AY Electric Dryer
A fork was used to get some of the lent where the filters goes. It was dropped inside by accident. How do I gain access to remove the fork. Thanks
Remove the back panel off the dyer. Lay the dryer on its back, hope that the fork falls to the back to get it out. If not, you may need to dismantle the internals of the dryer to remove the fork. Remove the drum belt and drum first. Hope this helps, good luck.
Aug 18, 2010 | Samsung DV337 Electric Dryer
Need four prong wiring diaagram for the power cord to a fridgedaire dryer Model FDEB55R
Due to a change in the National Electrical code in 2005 all dryer recepticals are required to have a 4 wire receptacle. This is to insure an isolated ground. You will need the following tools,
  • 1 – phillips screwdriver
  • 1 – standard screwdriver
  • 1 – 3/8′ nutdriver
  • 1 – 5/16′ nutdriver
  • 1 – 1/4′ nutdriver
First disconnect any power cords from thier outlets. Then on the back of the dryer,/uploads/images/ae228a3.jpg You will need to remove this access panel. Once removed you will see a connection block that looks like,
You will now need to loosen the connections using the nut drivers, once the connections are removed the loosen the screws on the strain relief. ( the clamp holding the wires)
Once this is loose you can remove the old cord and install a new 4 wire cord. When making the new connections you will need to neutral or white wire in the center of the block, and the green wire is connected to where the bonding strap use to be or connect it to the frame of the dryer using the access panel screw holes.
The black and red wires are your hot or L1 and L2 connections. It should look like this when finished.
/uploads/images/527d09d.jpg
Then reattach you access panel door and plug your dryer in and you ready for laundry.
Thanks, Dorrian
Aug 07, 2010 | Frigidaire Dryers
After replacing our 3 prong cord with a 4 prong cord, it no longer works. Have we fried the control panel?
First, go back and check the power cord configuration. There is a difference between how a 3 and 4 prong power cord is connected. Copy and paste the following link to your browser:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
If you connected the power cord wrong, you may have simply blown the thermal fuse. This is a small plastic looking component (usually white in color) with two wires attached to it. Its located on the air blower housing inside the dryer.
If the model number is correct, you can access the thermal fuse by following these steps:
1. Remove the lower toe panel directly below the door, by locating the screws under the bottom front edge. You can gain better access to the screws by propping up the two front feet of the dryer (a 2 x 4 works well for this).
2. With the screws removed, the panel will drop down, then come off.
The thermal fuse should be located on the air blower housing directly below the drum in the front. A resistance check should read something close to zero ohms (short) if good. If you have no continuity, the fuse is blown.
NOTE: Make sure you have the dryer UNPLUGGED and the wires disconnected from the fuse, when taking resistance checks.
If you have questions, or need further assistance, please post back and let me know. I hope this helps you.
Aug 05, 2010 | Whirlpool GEW9250 Electric Dryer
Need to change electrical cord, how do i open the dryer
Make sure the replacement cord has the same number of prongs on the cap. The NEC now requires 4 prong instead of 3 prong on dryers. If this is an older unit it may still be 3 prong. the access is in the rear. Make absolutely sure this unit is disconnected. You will need a philips and or straight blade screw driver. and nut driver and pliers. Replace the existing wires with the new one in the exactly the same sequence. The center green wire is equipment ground and the outside conductors are the ungrounded conductors. Make sure everything is tightened down
May 22, 2010 | Kenmore 62602 Electric Dryer
I NEED HELP CHANGING CORD TO A 4 PRONG ASAP!!THANKS
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one to the left here is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown to the right. These are just just thumbnail pictures that you can click for a larger view. But I'll bet you already figured that out, didn't you?
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
tn_3prong_dryer_outlet.jpgtn_4prong_dryer_outlet.jpgIf you need to re-wire the outlet, these pictures will explain the anatomy of the three-prong (left) and four-prong (right) outlets. Once again, these pictures are just thumbnails--click 'em for a larger view.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Comments: Jul 23, 2009- bf71290.jpgfb4d3ed.jpg
Three wire Four wire.
Better? Best wishes and sorry about the pics. Hope this is better.
Aug 17, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Where to wire the ground when changing a three prong to a four pr
This cover is all different sizes and shapes depending on the manufacturer of the dryer, but it is typically very close to where the cord enters the dryer. The cover is typically held in place with 1 - 4 screws. See image to the right of a Maytag Performa dryer access panel.
04b796a.jpg With the cover open you will see a terminal block with three wires. Black on one end, white in the middle and red on the other end. Use your 3/8′ nutdriver to remove the nuts or a phillips screwdriver to remove the bolts (depending on your dryer) and remove each dryer cord wire from the terminal block. When you remove the nuts or bolts, be careful not to drop them down into your dryer. Now you need to install a bonding jumper from the neutral terminal to the dryer’s frame. The bonding jumper is either a metallic strap (typically copper or copperclad) or a green wire that is connected between your dryer’s neutral (white wire) terminal and the green ground screw connected to your dryer’s frame.
Installing this bonding jumper is an extremely important step when changing from a 4-wire to a 3-wire power cord to prevent electrical shocks when touching anything metallic on your dryer.
If you do not have the original bonding strap, you can make one. You need a short piece of green 10 AWG wire, 2 ring terminals, a pair of wire strippers and a pair of crimpers. Strip both ends of the green 10 AWG wire and crimp one ring terminal onto each end of the wire. Now connect one end of the wire to the neutral (center) terminal and the other end to the dryer’s frame; where your ground is connected now. a9fc1b2.jpg Loosen the screws at the connector and pull the cord out. Now thread your new cord through the connector and tighten down. This only needs to be snug do not over tighten. Sometimes the old connector will work with the new cord and sometimes not. If not, your new cord will include a connector that you may use. To hook up your new 3-wire dryer cord, connect each wire to the dryer’s terminal block. The 2 outer wires are your “hot” wires and the center wire is the neutral. Replace the access panel cover and your new 3-wire dryer cord is installed Before plugging in your new dryer cord, I recommend turning off the breaker to your dryer receptacle. Then plug in your dryer. Now turn the breaker back on. This is not fool proof, but it is a safer way to turn on the power to your dryer if you made a mistake connecting your new dryer cord.
If your dryer is different from the one described above and would like a second opinion on your connections, email a picture of the terminal block to info at ezdiyelectricity dot com. I will post the pictures on this page to help others with the same dryer.
Apr 05, 2009 | Whirlpool LER4634J Electric Dryer
Replacing light bulb on dryer
Light is located just above the door on the inside of the drum. It has a clear plastic lens on it. The lens has a hinge on the top and a retention feature on the bottom. You can see all of this with a mirror. Simply push the button up and the lens will swing up. You can then access the light bulb.
Oct 27, 2007 | Dryers
Dryers Logo
89 people viewed this question
Top Dryers Experts
