Question about Dryers
I need to know how many elements are in my ge dryer. And where to find the part. model #DCSR483EA 1ww serial # TZ756464A and the part to get for a high low thermostat
    President:
  • 1,554 Answers
Your GE DCSR483E1WW electric dryer has only one heating element which is part number WE11M23. You can also find the parts you need here.
GE DCSR483E1WW Electric Dryer Parts
Posted on Sep 30, 2010
I have a GE clothes dryer model DBSR453EB3. It seems to heat up properly but takes entirely too long to dry a load of clothes. I have cleaned the lint hose. Can you help me out here??
ck cabinet and element housing for lint ck motor blower housing and discharge tube also if cleaned and still does it ck that limit switches are not short cycling due to weak bimetal disc
Jan 26, 2010 | GE DCSR483EA Electric Dryer
My GE dryer DHDSR46EG 1WW less than 2 year-old dryer flips the breaker after about 10 minutes of drying
If the dryer appears to be running OK before the breaker trips, I might consider checking the breaker. Over time they can get weak and not hold the current rating.
If the dryer is smelling "hot" then we can look a little further.
Let me know.
Regards,
Aug 15, 2009 | GE Dryers
Old GE drier - Is it gas dryer or electric
it's a gas and you need a new gas or a 220 volt dryer.
Jun 24, 2009 | GE DCSR483EA Electric Dryer
Not drying adequately
There are only one element in the system. if your system is not drying the clothes properly then you should really check the temp sensor to make sure that the system is working correctly and not shutting off at the wrong time or to early and not really heating up properly
Feb 13, 2009 | GE DCSR483EA Electric Dryer
Kenmore Heating Element
There are levels of heat according to cycle and some driers do not use all the coils during low heat cycles. They rarely need replace unless visably broken. There could be a loose connection.
Jan 23, 2009 | GE DCSR483EA Electric Dryer
Timer / heater malfunction
The heater coils or going bad. It has two wire rings that heat up. One are two has burned out.
Jan 17, 2009 | GE DCSR483EA Electric Dryer
Have old dryer GE model DDE7206MCLWH it is getting to hot
you may want to get rid of it before it does start a fire...it sounds like the heating element is getting too hot or your limit switches have gone one allowing the element to get too hoy
Dec 28, 2008 | GE DCSR483EA Electric Dryer
How do I test for bad thermastat or heating element on GE dryer
well the fact that hte heating elemnt is glowing tells me that all the thermstats are working, i would check for a blockage/restriction in the venting. looking at te diag, its possible that only 1 of the 2 coils for the heate are actually going on, check the coils for continuity( may be a small break that separates when gets hot)
Dec 07, 2008 | GE DCSR483EA Electric Dryer
HOW TO FIX A NO HEAT ON A GE ELECTRIC DRYER OVER 10 YEAR OLD
Either one of 2 ways to get to the thermostat on a GE dryer.....
depending on your model, you will have an access point on the back of the dryer to get to the heating element which has attached to it, the thermostat.
If there isn't an access point on the rear of the unit, open the front door of the dryer and remove the 2 screws in the top of the door opening. Using a small prybar, slightly apply pressure prying up the lid. On the inside of the face of the dryer in the corners will be 2 more screws, remove those and pull the face of the dryer outwards to you to about a 45 degree angle. From there, you will be able to lift off the face. Be cautious to unplug the wires for the door switch before pulling the face all the way out. There isn't much to a 10 yr old dryer, just take your time, study the parts and put it back just as you took it apart. For the replacement thermostat or heating element look at
www.marcone.com
www.partstoday.com
Good luck and let me know if there is any more trouble I can help with.
Mar 17, 2008 | GE DCSR483EA Electric Dryer
GE Dryer
Sounds like an intermittant break in the heat element. Could also be an irratic control thermostat or bad connection somewhere between the line and the heater. Simple to isolate with a tester.
Jan 04, 2008 | GE DCSR483EA Electric Dryer
Dryers Logo
105 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
