Question about Fuji Cameras
My camera keeps saying turn off but the lens wings shut
    Brigadier General:
  • 3,006 Answers
Your camera has a lens error. This is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Fuji service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you.
Posted on Sep 30, 2010
5 Suggested Answers
mads_aye
  • 58 Answers
SOURCE: lens error
hello
it may be a bug or caused by impact damage, even the technical support team doesn't have the meaning of that error code but for troubleshooting you can call 1 800 235 6325 opt. 12 or go to www.kodak.com/go/itg
a repair may also be arranged for you - through phone call or the website
Posted on Feb 13, 2008
Matteh
  • 83 Answers
SOURCE: lens error
It could be jammed or when you turn it on, your finger or somthing is in way of it opening all the way.
Posted on Aug 05, 2008
t00nz
  • 4738 Answers
SOURCE: says lens error restart camera
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Posted on Jan 07, 2009
lock123
  • 6831 Answers
SOURCE: camera says lens error:0x02110000
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Feb 13, 2011
I turned on my camera and I get an error message that says, Lens Error Camera will shut off automatically. Then the camera shuts off. The lens will not pop out?
Hi.
This problem occurs when there is zoom-block problem. The solution is to change all the zoom-block, but normally this is more expensive than a new camera.
This mechanism fails due to sand, dust or just useful life expired.
Aug 27, 2015 | Canon PowerShot A4000 IS Silver 16MP...
How to fix a canon powershot lens
Here are troubleshooting steps for a lens error. Since the camera was dropped, and the lens is canted, suggest proceeding directly to Fix 7. And here's a video summary of the steps.
Jan 22, 2013 | Canon PowerShot SD880 IS Digital Camera
I have a kodak easyshare cd82 camera an it keeps saying error 117. how do i fix it?
clean the lens guide like. USe compressed air on the lens body, tap the lens face down position and then turn on and see the result.
Aug 12, 2012 | Kodak Easyshare CD82 Digital Camera
Keeps saying to turn off camera and won't take pictures
What the troubleshooting guide suggest is to turn off the camera and turn it back on which sound like what you have been doing. The cause of this generally points to a camera malfunction between the camera and lens. This makes me believe that either something is restricting the lens from moving like the lens cap is tethered to the camera and tight on the lens so it can't do it's "pre" view and goes into the shut down mode. If the lens has any restriction be it the lens cap, ever ready case or anything that is restricting the lens movement remove it and try it again. I have another theory which is completely opposite to anything even suggested and that is the camera can't read the SD card so goes into shut down mode. If you remove the SD card and check to make sure the "lock" switch is in the unlock position. I'll give you a diagram for this.
The little switch needs to be pushed forward towards the gold contacts.
Diagram
Jan 09, 2011 | FUJIFILM FinePix S1800 Digital Camera
After turning it on, it says lens error and shuts
Hi there its happens when the lens not ready for work. Some how its not able to stable his focus method. That's why its happens. There is a chances of lens guide pin disturbed or damaged & thats why continues failure. Its mean he inform you there is a system error. So please visit the service center for repair that. Its a very common & repairable problem. Thanks.
Apr 11, 2010 | Vivitar ViviCam X327 Digital Camera
Error lens
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Sep 20, 2009 | Sanyo Vpc-s1070w Digital Camera
Whenever I open my camera, it says zoom error
Your lens is jammed. you need to strip your camera down to access and remove the lens unit. BECAREFULL of electric shock. your camera will still have charge in the flash unit and you will recieve quite a shock if you touch the board or any components inside. You will also have to purchase a "tri-wing" screw driver for the case screws. These can be sourced on ebay.
Don't rush with your lens unit, it is likely that it has damage to the sliding assembly due to the impact. take your time and don't use excessive force. your lens will only dissassemble once it is in the retracted position so patients is required to free it off otherwise more, if not terminal, damage will result. Try and use another camera to photograph each stage of dissassembly to aid reassembly later. You will need :
small cross head screw driver
tweezers, pointed prefferably
Tri-wing screwdriver for the security screws
Soldering iron with no more than a 1mm tip and some solder and solder braid for desoldering.
If you discover broken plastic inside your lens or too much damage then I may be able to help you out with either spares or help with repairing
Mar 19, 2009 | Fuji FinePix A800 Digital Camera
Lens error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 16, 2008 | Fuji FinePix A345 Digital Camera
Lens error
Aug 05, 2008 | Kodak EasyShare M853 Digital Camera
Lens Error, Restart
Hi
What you are seeing is a generic stuck lens error message, turning off the camera and turning it on again will not fix the lens unfortunately.
Your lens needs to be cleaned or repaired, and if it cant be repaired it needs to be replaced. There are online places that will do it for a decent price and there are others that overcharge by way too much.
Fixya rules prevent me from giving you a link to anything off Fixya that would help you fix your camera.
Good luck from....
Darntoothysam com
May 01, 2008 | Canon PowerShot SD1000 Digital Camera
Cameras Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
