Question about Sony DAV-DX150 System
Sound Only limited sound coming out when dvd playing?
  • 10,594 Answers
Dear Anamalia,
Please try to check sound level by Amp mode and it can be change by remote. like Dolby Pro-Logic, DTS surround etc etc.
Normaly dvd has low sound level as compare to vcd, so i think its normal with your home theater system.
Posted on May 26, 2008
Everytime i go on realplayer and i put in the dvd the sound doesnt come on.But when im on the internet it works.
Are you using RealPlayer to play DVD or just realplayer formats?
If its for realplayer formats you will need to go on their website and download the newest sound files / and or download their new version.
If its for DVD, I would recommend VLC. Google it, its a free program with most usable formats, and plays DVDs. There are other things about DVDs on laptops but its too long to go into. So to make it short, you can only play a limited amount of DVD on your laptop/desktop before it won't work. On VLC you wont have that problem.
Sep 13, 2009 | Real Network RealPlayer Enterprise Manager
How do i connect my non hdmi xbox 360 to my panasonic scbt205ebk home cinema and panasonic 42v10 plasma so that the sound comes from the home cinema system. i also have sky hd
If you use a component system (1 yellow video wire, 1 red audio wire and 1 white audio wire)
You will have to connect the audio wires to your cinema system and the video directly to your set.
The unfortunate part of this is that when you want to use your system, you will have to change the input of the TV AND the Cinema system.
The same would be true if you wanted to use the DVD connectors (YBPBR). You would connect the video to the TV and the audio to the Panasonic unit.
The system you have is meant more for just playing DVD's and not a total cinema system. This is why there are limited (extremely limited) video inputs. The system is mostly for output of sound and of a the built in DVD video.
Aug 05, 2009 | Panasonic Televison & Video
While player a dvd the screen will go black ,still
That is called a limit switch. Disassemble the player and check this switch. It might be stucked. Perform continuity test using an ohmmeter. If resistance does not change when switched and released, replace it. Check also for loose ribbon connection. Realign connections and resolder connector terminals.
Aug 03, 2009 | Initial IDM-1731 Portable DVD Player with...
Cant get rear entertainment system to work- 05 durango
You need to change the mode on the stereo to dvd. The dvd sound comes through the vehile stereo. I just bought a used one a week ago and had the same problem, eventually figured it out.
Dec 16, 2008 | 2005 Dodge Durango
Philips Pet706 portable dvd will no longer play sound without earphones
try connecting it to small external multimedia speakers (usually played with computers) that come with a small jack simmilar to that on earphones.
Aug 13, 2008 | Philips PET702 Portable DVD Player
Dvd getting picture but no sound
can you play a music cd? if not, your probably missing the audio cable that hooks between the player and the motherboard or soundcard ( if a separate card is installed )
Feb 23, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
The DVD player does not recognize disks that it used to play before.
It sounds like the DVD region (a setting in both your OS and your DVD hardware) may have been changed. DVD regions are the agreed upon method (by entertainment companies, hardware manufacturers and governments) to limit cross-border sharing of media. Most valid (read: non-pirated) DVDs have a region code. Your DVD drive will only play DVDs with a region code that matches the DVD region code set on the DVD drive.
You didn't mention your OS but if you are running Windows XP then go to Start->Control Panel->System->System->Hardward->Device Manager and find your DVD player. Right-click the DVD player and select Properties from the menu and you should see a properties dialog-box with a DVD region tab. This is where you can change the DVD region that your player will recognize. Be careful, don't play around here, most DVD players have an embedded limit on the number of times (4-or-so) the DVD region can be changed.
Hope this helps.
Mar 31, 2007 | NAD C541 CD Player
Sony DAV-DX150 System Logo
151 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
