Question about Garden
I need a parts diagram for a stihl 017 chainsaw
5 Suggested Answers
  • 594 Answers
SOURCE: I need a parts diagram for a Homelite PS-33 chainsaw
Go to m-and-d.com then parts diagram the illustrated parts online then parts look up then select oem select homelite then find model number.
Posted on Apr 07, 2009
Dolfoff
  • 148 Answers
SOURCE: tunning specification for a stihl 028 chainsaw?
I'm not sure there are any "endorsed" tuning specs from Stihl as weather, temperature, fuel quality etc all contribute to engine performance.
Pictures of all types are all over the web.
As for the carb tuning procedure, maybe I can help?
Start with fresh fuel, all filters clean, and bar and chain installed. Also, fill the chain oil tank with bar/chain oil and VERIFY that the chain oiler works properly.
Initial fuel mixture settings (the H and L screws) should be 1.5 - 2 complete revolutions counter clockwise from lightly seated. Sight the carb's throttle plate and adjust idle screw counter clockwise until the plate stops moving.(Throttle closed completely.) Then go back clockwise 3 complete revolutions. This will produce an acceptable startup condition on a HEALTHY saw.
Clamp the bar in a STURDY bench vise and roll the chain with the shank of a screwdriver to verify it is clear. BE SAFE!
Choke the saw and pull the starter rope until the engine "burps".
NOTE: If no burp after 6 pulls, stop! Something is wrong.
After the burp, set choke to half and pull starter until it runs. The settings I gave should produce a slightly rich condition and a slightly high idle. (Chain will be in motion!)
Blip the throttle trigger and idle it down just enough to keep it running during the tune procedure.
Step 1) Using the "L" screw (closest to the engine), turn it clockwise until the engine smooths out or possibly increases RPM. Back it out slightly until the engine has a slight "LOPE" sound to it. (Like a drag car on nitro).
Step 2) Accelerate the engine to full throttle and go to the "H" screw (closest to the air filter) and slowly turn it clockwise and note the RPM increase. There will come a point when the saw will "Top-Out" and loose power. Not even enough power to turn an maintain empty chain's RPM! Go back counter clockwise to the edge of that point, and counter clockwise another fourth (1/4) revolution.
Step 3) Idle the saw back down. Again go to the "L" screw and repeat Step 1.
Step 4) Repeat Step 2.
Step 5) Idle the saw down until the chain stops moving completely. NOTE: Don't settle for a "crawling chain" condition. If the steps above are performed well and all else is healthy, you should be able to idle the engine down to a ridiculously low RPM and it will not shut off.
Hope this helps,
Dolf-
Posted on Oct 13, 2009
  • 82 Answers
SOURCE: i need a parts manual for a stihl 026 chainsaw
Parts list here http://bricomeca.free.fr/Stihl/stihl%20026%20IPL.pdf
if this helps please leave feedback
Posted on Feb 04, 2010
dontbother10
  • 2220 Answers
SOURCE: Need parts diagram for Stihl 034 chainsaw.
Stihl considers all IPLs, Shop Manuals and OM parts proprietary. When they discover an on-line source for any of these they force it be removed.
They cannot stop individual owners from sharing expertise and technical publications. This is an international collection of good people that are obsessed with all chainsaw (this obsession is HIGHLY contagious).
ArboristSite Chainsaw thread (free to join)
http://www.arboristsite.com/f orumdisplay.php?f=9
This thread is discussing an oiler problem on a Stihl 034.
http://www.arboristsite.com/showthread.php?t=126068&highlight=stihl+034
People share publications here (many request for and replies to 034 IPLs):
ArboristSite Beg for manuals thread (free to join)
http://www.arboristsite.com/showthread.php?t=72322
I will provide this before you go (if oil pump or gear failure they are behind the clutch), I think it has an inboard clutch removal begins as follows:
R² Drive Link Inboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=YUbSIHMSSP8
The C-clips tend to fly when being removed. Please wear eye protection and exercise care.
Any remaining pieces can be removed using this as a guide:
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
It is not as difficult as it appears. Good Luck. HTH
Lou
Posted on Feb 24, 2010
Need sparkplug wire for ms180c chainsaw
Robert, spark plug wire for Stihl MS 180C. Check the attached links, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon com Ignition Coil Spark Plug Wire Fits Stihl 017 018 Ms170 Ms180...
New Ignition Coil Spark plug wires for Stihl 017 018 MS170 MS180 Chainsaw...
Amazon com IGNITION COIL MODULE FITS STIHL MS170 MS180 017 018 ENGINE...
Jul 30, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
Will a complete engine from a stihl 017 fit into a stihl ms180 chainsaw.
you should be able to get the engine to fit. The 017, ms170 and ms180 are all part of the same family.
Jan 15, 2013 | Stihl Garden
Will a stihl chainsaw engine assembly from 017 fit in a ms180
those saws are part of the same family so there should be no problem putting the two together
Jan 10, 2013 | Stihl 017 Crankshaft Assembly W/ Piston...
Starter coil on stihl 017
If you are asking for the part number, it is 1130 400 1302 if you have two ground wires and one lead wire. If you only have one ground wire and one lead wire, the part number is 1130 400 1300.
May 22, 2012 | Stihl 017 018 Ms170 Ms180 Chainsaw Starter...
Stihl brake assembly diagram
Oh man, you shouldn't be monkeying around in there. Bring it to a STIHL dealer and make him let you watch, but don't screw with that again, that's a big safety no-no and another reason why STIHL doesn't sell out to lowes or the home cheapo.
May 15, 2012 | Stihl 017 018 Ms170 Ms180 Chainsaw Starter...
Stihl 025 diagram of parts needed. Runs rough and will not accelerate
Try to get an IPL here:
Stihl USA Contact Us
http://www.stihlusa.com/contact.php
Stihl considers all OE parts, IPLs and Shop manuals proprietary. When they discover an on-line source for any of these they force it be removed. If they tell you no your recourse is to register a complaint. Please do. Then go here, join, post an email address and your need.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 21, 2010 | RTO Spur Sprocket For Stihl 017, 021...
The bar inside the clutch lever broke what part do i need
Stihl IPLs are propriatory. Please use this to contact your nearest dealer.
http://www.stihldealer.net/locator/
New Stihl OEM parts must be ordered through a dealer. HTH
Lou
Sep 30, 2009 | RTO Spur Sprocket For Stihl 017, 021...
Garden Logo
116 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
