Question about Dremel 400 1/6 120V Xpr Rotory Tool Industrial
I can not remove the drill bit chuck from my dremel 400. I push the button, keep it pushed in but it still will not release, I can feel the push button popping in and out even though I am holding it down as hard as possible. What can I do? It seems like the push button is broken.
  • Donald DiNaro
    Donald DiNaro Sep 24, 2014
    Dremel 400-XPR has a design Flaw! Use a Plier, hold tight blue button, Chuck key will work then!
glenmann62
  • 91 Answers
SOURCE: help. Cannot remove the nut on the dremel
HELLO ,you must keep your thumb on the push button while trying to loosen the nut it sounds like your pushing the pushbutton in and then letting it go as you try to loosen the nut , i also have a dremel and i made the same mistake when i first got my tool , Hope this truly helps you get it off , I thank you for letting me try to help you Sincerely Glenn
Posted on Mar 04, 2009
rowdy45176
  • 2176 Answers
SOURCE: I need to replace the bent shaft that the chuck screws onto
I would go direct to Dremel.com or call them at 1-800-437-3635 and get the schematic and parts you need, I just checked and they have a parts diagram online that you can view. go to the section about manuals/literature and type in your model number. Good luck
Posted on Mar 16, 2009
memturbo
  • 226 Answers
SOURCE: I inherited a Dremel Pro from my son who passed away...
you should have a little wrench that came with it
and on the neck of the dremel there is a shaft stop button
push the button and manually rotate the dremel head till
it clicks then hold the button and use the wrench to loosen the bit
Posted on Mar 27, 2009
SOURCE: I cant loosen the head on the dremel 300
Another suggestion: you could put a point on that rod with a grinder or a file, or a dremel, and it's good as new.
Charlie
Could I get a "problem solved" / "fixya" rating on this -- there are icons at the bottom of this posting I believe.
thanks...
Posted on May 13, 2009
  • 202 Answers
SOURCE: Dremel 395 in the middle of drilling sea glass and
sounds like the rubber connector between the motor and collet.i use rubber tubing and hot glue to keep it working. bad news is you have to disassemble it to install a new connector.
Posted on Jul 13, 2009
How do I change the bit on my porter-cable 18v drill? Where/how do I line up the black dial with the silver dial to release the bit??
I just looked at some illustrations on ebay of Porter-cable 18 volt drills and they appear to be fairly standard cordless drill/drivers fitted with fairly standard keyless chucks that you get hold of with both hands and twist in opposite directions like you are giving it a Chinese burn. The part of the chuck nearest the bit twists anti-clockwise to loosen.
If you have an SDS drill for heavier duty jobs the chuck is semi-automatic in the drill bit just needs pushing into the chuck and clicks into place but the outer part of the chuck is pulled back in order to release the bit.
May 07, 2017 | Drills
How do i attach the drill bit to my dremel 300
You can use a drill that fits directly ( one size) or you can use a small chuck made for the Dremel. example: http://www.homedepot.com/p/Dremel-1-32-in-Multi-Pro-Tool-Chuck-4486/100531881
Oct 21, 2014 | Tools & Hardware - Others
Quick change clutch is locked
Push the rubber sleve off the drill bit and up the drill bit then the plastic ring. release the clip around the spindle. Slide the clip and chuck sleve forward and remove the ball sitting in the spindle. You should then be able to pull the bit from the machine. If it does not want to come hold the bit in a vice and tap the spindle off the end of the bit using a suitable punch. Rebuild chuck in reverse.
Jan 29, 2013 | Milwaukee Electric Tool Milwaukee 5359 -...
Dremel 3100 won't release the drill bit. Button at the top is pressed in and won't come out.
The button is only to keep the shaft from turning while you loosen the collet (the nut) with the little wrench. THEN the tool comes out.
Sep 25, 2012 | Dremel Variable - Speed Multipro Rotary...
Cannot remove sdsdrill from chuck
If it is stuck you may have to cut the collar (item 139) that you push to release the bit. I use a dremel tool and cut through once on each side. Once that is removed you will see the spring, plate, and ball that hold the bit it. You just need to remove the ball. If it is still stuck then it is stuck in the spindle itself (item 149). You may get lucky and be able to use a punch and hammer to hit the spindle end while holding the bit in a vice. A helper to hold the tool is recommended when doing this method, If you still can't release the bit from the spindle then it has to come apart anyway. Here is the parts diagram. I didn't find the exact model you listed but they should all be pretty close. The bit retaining method is a pretty simple design and easy to work on.
DeWalt D25003K diagram
Aug 15, 2012 | Dewalt Drills
How do I open the chuck or drill mouth to replace the drill present in my DeWalt Heavy-Duty 3/8? Keyless Chuck Drill?
Hi Tony,
To remove the bit with a keyless chuck, just turn the chuck to the right (looking from the handle to the front) to open the jaws. To put in another bit, tighten the chuck to the left to close. You have to use both hands. You will see where the ridged portion of the chuck is in two sections. Hold on to the back section with your left hand to keep it from turning while you turn the front section with your right hand.
A lot of the time I just push the button to put the drill in reverse, hold on the front section of the chuck and turn it on. It will loosen by itself. Then when you put the new bit in, put it in forward and hold on to the chuck and press the switch. The bit will be in nice and tight.
Good luck.
Please place a vote when you accept this solution.
Thanks,
Handie Andie
Aug 19, 2011 | Dewalt Drills
How do i take out a skil 12 volt battery drill bit. i havent used the drill in a year or so and i forgot please help, or not
Hi ladogers,
Welcome to fixya!
This drill has a keyless chuck. To remove the bit, just turn the chuck to the right (looking from the handle to the front) to open the jaws. To put in another bit, tighten the chuck to the left to close. You have to use both hands. You will see where the ridged portion of the chuck is in two sections. Hold on to the back section with your left hand to keep it from turning while you turn the front section with your right hand.
Good luck,
Thanks,
Handie Andie
Aug 16, 2011 | Skil 12 Volt Drill/Driver with Built In...
I borrowed a die hard 19.2 volt cordless drill from a friend, but I can't figure out how to change out the bit! Can you help me?! Thanks!
Hi Mary,
Welcome to fixya!
Good luck, Mary.
Thanks,
Handie Andie
Aug 15, 2011 | Craftsman 192 volt DieHard Cordless...
Hello... I've rented a Bosch 11318 Hammer drill and it did not come with a manual......could you please tell me how to insert the bit. thank you.
You should only need to push the bit in. If that does not work grasp the chuck and pull back towards the handle than insert the bit and release the chuck. You remove the bit by doing the same pulling the chuck back and taking the bit out
May 09, 2011 | Bosch 11318evs 11 Amp Sds Max Demolition...
How do I fit drill in this machine please? DEWALT D25113K D25113 3 MODE SDS
Youcan only use standard drill bits with the use of a chuck attachment with the SDS type bayonet. These hammer drills use an SDS type drill bit which just pushes into the fitted chuck and are released by pulling back on the lock mechanism on the chuck.
Jan 19, 2010 | Dewalt D25213k D-handle Tri-mode Sds+...
Dremel 400 1/6 120V Xpr Rotory Tool Industrial Logo
425 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
