Question about Toshiba Satellite A85-S107 Notebook
My computer won't turn on or charge. - Toshiba Satellite A85-S107 Notebook
    Genius:
  • 1,456 Answers
Hello
Remove the battery from the laptop. A Toshiba battery is located on the bottom of the laptop. Slide the locking mechanism to the right. Hold the mechanism in place with one hand while lifting the battery upward with the other hand. Release the locking mechanism once the battery is removed.
Plug the power cord into the right side of the Toshiba laptop while the battery is removed. Press the "Power" button to turn the laptop on. If the laptop turns on, the power cord is properly working. If the laptop doesn't turn on, ensure the electrical outlet is working by plugging in another device. If the electrical outlet is working but the computer won't turn on, the power cord is dead and needs to be replaced. If the power cord is not properly working, it will not charge the battery. Turn off the laptop and remove the power cord.
Examine the battery. Look for signs of damage, such as corrosion, dents or dings. If you see damage on the battery or battery contacts, replace the battery with a new one.
Clean the laptop battery. Pour a small amount of rubbing alcohol into the rubbing alcohol cap. Dip a cotton swab into the rubbing alcohol. Rub the swab onto the battery contacts, located on the battery and in the battery bay, to remove dust and grime. Dirt can prevent the battery from properly charging, so the battery should be routinely cleaned.
Push the laptop battery back into the battery bay. The battery will snap into place.
Plug the power cord into the side of the laptop. Allow the battery to charge for 8 hours or overnight. Do not use the laptop during this time, as it can slow down the charging process.
Remove the power cord. Press the "Power" button. If the laptop will not turn on, the battery is dead and should be replaced.
Posted on Sep 30, 2010
    Guru:
  • 382 Answers
You need to diagnose the problem.
>First try to take the battery out of the computer and just use the charger to make computer run.
>If it turns on it means that the battery is what's causing the problem.
>But, if computer cannot run using the charger/AC Adapter then it means that we have a problem with the charger.
By doing this diagnostics you know which part to replace.
SOURCE:
I have a samsung STM330 tablet it has charged but won`t turn on.
  • Defective battery
  • Defective charger
  • Defective power switch
May 13, 2018 | Samsung Computers & Internet
My MP4 won't charge or turn on and the USB port isworking fine, my computer won't even recognise that the mp4 is connected
You can turn off the Mp4 for a while and re-install the system ,and then you can change if the port is fit the computer ,you can also used a transfer interface to connected the computer .
Dec 11, 2012 | Philips Gogear Vibe 8gb Mp3 Mp4 Video...
I just bought the eclipse cld and it won't turn on after charging for hours
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Sep 30, 2012 | Eclipse Audio Players & Recorders
Notebook won't turn on
my nb500 netbook wont turn on i slamed it shut now wont turn on
Apr 23, 2012 | Toshiba NB500-12X
Netbook charging indicator light won't light and battery won't charge. AC adapter works on other computers
If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems.
1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose
Hope this helps...
Sep 15, 2011 | Gateway LT2021u Netbook
Won t charge
Download Motorola Phone tools and get a new battery for your phone.
The batteries go bad about once a year, sometimes longer.
if this helps you please leave a vote on fixya
May 21, 2009 | Motorola Mobility MOTORIZR Z3 Cellular...
Toshiba Satellite A85-S107 Notebook Logo
365 people viewed this question
Top Toshiba Computers & Internet Experts
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
