SOURCE: 1998 528i bmw cam shaft sensor location
hope this helps .
http://picasaweb.google.com/mmm635/CamshaftPositionSensorsCamshaftPulseGeneratorsAsBMWCallsIt#
not the same year but should be same place.
SOURCE: 96 bmw 740il misfire
This is a pretty common problem. I would change your valve cover gaskets. They run around ~ 50 bucks. If they are bad it will leak oil into spark plug well and cause a misfire. Very known on the 740.. Also if tune was not anytime not too long ago id change spark plugs while you at it. Then clear the computer and if you still get misfire on 8 try changing the ignition coil which is right about the cylinder with cylinder ignition coil 5. clear the computer. if you get random misfire and misfire cyclinder 5 after then its your ignition coil. parts store runs around 100 bucks
SOURCE: driver seat and steering wont adjust on my 95 740il
here's what you have to do:
#1. make sure the fuse to the seat adjustment is not blown, its usually a 10 or 15amp fuse.
#2. unscrew the cover to the controls on the driver's seat and make sure the harness is not loose or
broken, if the harness fails to attach to the control board correctly the steering wheel and the
seat adjustment will not work, this harness tends to come loose and even brake over time due to
the constant movement when you get in and out of your car.
I hope this solves your problem.
Rafael Reyes.
SOURCE: NEED TO KNOW TIMING MARKS ON 84 S-10 2.8
the timing is set to 8 degrees at 700 rpm...if it helps any
