Question about Polaroid Portable DVD Player PDM-0822BD
My player reads "bad disc" when i start it up with a disc inside. What does this mean?
  • Polaroid Master
  • 11,800 Answers
It means that the laser head is no longer getting a good signal - the lens is dirty and you must clean it by using a cleaning disk : $10 at Walmart.
If the clean doesn't help then the dust has been baked on the lens - in that case you must replace the entire laser head. Find one in un its sold for parts, or discarded ones. If you can't find a replacement head then the un it is dead.
Posted on Sep 30, 2010
My bush DVD player keeps coming up bad disc why is this?
Hi Grace,
Coming up bad Disc means your DVD player is not able to read the discs. There may be some dust on the lense ( optical unit ). If you can clean it please do it. If it does not work even after cleaning, the lense is bad and needs replacement.
May 30, 2015 | Bush Televison & Video
My magnavox dvd player will start to read a dvd, but then says disc error. This has happened on every dvd I have tried
Usually this means either a dirty or bad optical pickup in the unit which is what reads the disc.
Dec 20, 2012 | Magnavox Televison & Video
C13
C13 means the deck cannot read the minidisc table of contents for some reason. Since you have no disc in the deck it probably means the laser head is out of allignment or just plain worn out.
I often see MDs being sold for parts, but you need to know the fix is usually cost prohibitve. Most likely the laser assembly in your deck is bad and will cost too much to replace. MD's are more complex than CDs and are optical/magnetic using a laser to read and a laser + magnetic head to record on the discs which are read/write many times.
Jan 30, 2012 | Sony MXD-D40 Mini Disc Player
Disc spins for about 30 secs then error reads wrong disc, I have 2 players, both same fault
was the player reading discs before now? And how long have you been using this player?
I suspect that the laser (lens) of this player is weak, that's why it cannot load discs.
The symptoms is like that of a dirty or bad laser (lens).
Use a lens lens cleaner to clean the lens. But if that doesn't solve the problem, then it means you will have to replace the lens of your player completely, in order for it to play/read discs again.
Good luck.
Aug 25, 2010 | Car Audio & Video
DVD-Player not reading discs.
Well if it happens to every disc, then you know its the discs that are the problem. It should be the DVD player. Check if you plugged in the yellow, white, and red plugs accordingly. And also try blowing inside the DVD player, to blow away any dust that might be fogging the disc from beiing read.
Good Luck!!!! Rate Please!!!!!
Jun 13, 2009 | Philips Televison & Video
Ps3 does not read any of my games
see if the player tries to read the disc. Load a disc and listen.
Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track.see if the player tries to read the disc. Load a disc and listen.
Feb 10, 2009 | Sony Playstation 3 (PS3) Console
Toshiba DVD player says every DVD is a bad disk
HI,
Feb 10, 2009 | Toshiba SD6100 DVD Player
It reads u11
U11 means "incompatible disc"
Either you are trying to read a disc outside your region (region 1 discs required for U.S.) or the player has gone bad.
Jul 09, 2008 | Panasonic Televison & Video
When a blank DVD disc is installed in the DVD recorder, it displays this message"NO READ". this just started happening 2 weeks ago. how can i regain the use of the recorder?
HI,
The problem is that the player is not reading the dvd
First try to unplug it for 20min then plug it back in and see if it works.If it doesn't then follow these steps:
If the problem does not get solved then you have to get it repaired.
Goodluck..
Feb 24, 2008 | Televison & Video
No Picture
i think this means it is dying. mine started to skip and then promptly stopped reading the disks too. i was told it may be the optical lense and it may be better to buy a new one than have it fixed. my problem now is that i can't find a replacement that is not upconvert (i see no difference in the component cables vs. hdmi). i am sad to lose this player. love it.
Jul 25, 2007 | Yamaha DV-C6480 Multi-disc DVD Player
Polaroid Portable DVD Player PDM-0822BD Logo
147 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
