Question about Sony STR-DE597 Receiver
Why is protect always flashing?? - Sony STR-DE597 Receiver
    Genius:
  • Sony Master
  • 1,550 Answers
Because the audio amplifier IC´s are damaged and need to be replaced
Posted on Sep 30, 2010
It always shows disk is write protected.
There is a switch on the back on the card. to disable write protection, simply move the switch in the opposite direction.
Feb 28, 2011 | Kingston 4GB Secure Digital High Capacity...
When I send any folder always show me the disk is write protected remove the write protection or use another disk. for that I can't work properly. Please tell me how can I unprotected my usb flash. My...
This flash drive has a safety button located directly on it. PLEASE SWITCH THE BUTTON OVER, it will be easy to switch with the use of a nail on your finger. Once this is done, you will have access to the data on the flashjet card again. This is actually a safety feature that prevents you from accidently formatting the jetflash flash card. Thank you and have a great day.
Jan 21, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
The Disk is write protected
  • Check for a write-protection switch. This switch, when engaged, will lock the contents of the flash drive and is a very common security feature. It is generally located on the side of the flash drive, and has an "enabled" or "on" position, and an "off" position. Slide this into the "off" position.
  • Override password security. If your flash drive has password security, but you have forgotten the code, you can try to override the security feature by going to the Start menu and selecting "Run." A dialogue box will pop up, into which you should type in the path to the file on the USB drive you want to access. Note: This only works on USB drives with very simple security. If the security is complex, this will not wor
  • 3Format the flash drive. If nothing else works, you can always format your USB flash drive, which will set all your write protections back to default. From there, you can customize them however you want, but all your data will be lost. To format the flash drive, go to the My Computer, right-click your drive and select "Format." A status bar will pop up. Once the status bar disappears, you can change the write-protection settings on your flash drive without incident.
  • Oct 26, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
    How to remove write protect on my usb flash drive
    If you have a write-protected flash drive that you need to access, it can be difficult to change it to allow you access, especially if it is a security-optimized flash drive. However, there are a few practical steps you can take to change the write-protection on a flash drive.
    #1
    #2
    Override password security. If your flash drive has password security, but you have forgotten the code, you can try to override the security feature by going to the Start menu and selecting "Run." A dialogue box will pop up, into which you should type in the path to the file on the USB drive you want to access. Note: This only works on USB drives with very simple security. If the security is complex, this will not work.
    #3
    Hope this might help
    Thanks
    Oct 07, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
    My sd card on my camera now says write protected...
    Look for a small switch on the side. Switch away from the locked position.
    May 20, 2010 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
    I cant format my 1gb usb when i was formatting it it always says that it is write protected and it wont be format
    Does this USB flash drive have a small slide switch on the edge of the drive to write protect the data on the drive?
    If so move the switch to the read/write position.
    Dec 11, 2009 | Computers & Internet
    Denon CD Receiver display reads "Protect"
    Always be the audio amplifier Ic damaged and need to be replaced
    Jul 18, 2008 | Audio Players & Recorders
    Press Power Protect
    Always be solved replace him the audio amplifier IC
    Dec 30, 2007 | Sony MHC-GS300AV CD Shelf System
    Sony STR-DE597 Receiver Logo
    46 people viewed this question
    Top Sony Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
