Question about CP International PLI-2030 Network Adapter
PLI 2030 utility wont run on windows 7 - CP International PLI-2030 Network Adapter
My laptop wont come on
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
Jun 02, 2012 | Acer Aspire 6930-6455 Notebook
Completly free copy of windows 7 boot disc
If it tries to boot up, Borrow a Repair disk or Operating System Disc from a neighbor, friend, relative or co-worker.
Run the Check Disk Utility.
May 22, 2012 | Acer Aspire AS5734Z4836 T4500 Notebook
ProductName=Agilix GoBinder Version=1.0.3156 OSVersion=Microsoft Windows NT 6.1.7600.0 No Service Pack Installed (NonTabletPC) Details=Exception from HRESULT:...
get the correct version for win 7 operating system
each operating system is designed to run with certain win operating systems and will not run with any not listed
Apr 09, 2017 | Franklin Covey PlanPlus 4.0 for Windows XP...
For key span server to work with windows 7 install windows xp mode to windows 7 ( this can be downloaded from microsoft website if you have windows 7 pro and above. if you have windows 7 home then install...
1. instal server utility on Windows 7
2. right click icon choose properties
3. select compatibility tab choose your o/s
now run it and presto......
regards, dean
Jan 08, 2011 | Keyspan USB Server US-4A (d47710) Print...
Satellite l355d-s7815. Can this laptop support windows 7?
See: http://www.microsoft.com/windows/windows-7/get/system-requirements.aspx
and "download the Windows 7 Upgrade Advisor for a more detailed understanding of whether your PC can run Windows 7" and run this utility.
Dec 21, 2010 | Computers & Internet
LJ 3050 printer is printing very slow.
TRY HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Oct 27, 2010 | HP LaserJet 3050 Printer
My printer will not print black ink i just changed 3 cartridges
Oct 27, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
My D7160 cuts the bottom part off of every photo. How do I fix this?
Oct 27, 2010 | HP Photosmart D7160 InkJet Printer
PC attorney 3.1 and up win850 wont load on windows 7
I'm guessing that those programs are not compatible with Windows 7. If they worked on Windows XP you can upgrade to Windows 7 Ultimate and you'll have backwards compatibility.
Thanks,
Brandonmxb
Dec 08, 2009 | Computers & Internet
CP International PLI-2030 Network Adapter Logo
363 people viewed this question
Top CP International Computers & Internet Experts
David Payne
David Payne
Are you a CP International Computer and Internet Expert? Answer questions, earn points and help others
