Video start scrumble and the screen get green and cover all the picture
  • alma863 Sep 30, 2010
    do you mean to revove the screen saver or just change it for any other
    correction to the previous comment ; do you mean to REMOVE the screen saver or just change it for any other
    Master:
  • 473 Answers
Well...Check First your Screen Saver if it On.. click with your right button go on your property and change our Screen Saver...
Posted on Sep 30, 2010
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
Sony trinitron color tv rain bow problem
1. first you need to check your degozing inside the power supply near @ power rely or bridge type diode. and try to pullout and shake it if the degozing are scrumbling.. if scrumbling that is the deffective. and replace with desame components
2. don't put any speaker box near your tv appliances. cause it may dammage your picture tube...
Sep 11, 2015 | Sony Televison & Video
N 70 white screen best solution or scrumbled displayA
Some good advice from someone who has been looking for this solution for many months, FORGET jumper solutions because you are just wasting your time with this and forget reheating the board as well.
I do not have a diagram to upload but those of you should know where the black bga chip is on the left hand side of the keypad system connector, that is all you have to replace, no jumpers needed. I have just finished my fourth N70 in this way, just change the chip and nothing else.
you can also find the chip on 6680 board.
May 15, 2009 | Nokia N70 Cellular Phone
Green translucient vertical bar on left side of screen
Cover green CRT lens with towel and see if red/blue video is normal......= bad CRT ?.............................T.
May 09, 2008 | Toshiba 57H82 57" Rear Projection...
Blue screen with Green Star-burst image in center?
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jan 19, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Color problem green and pink
I had a very similar problem - the picture would get garbled, the black colour would turn into dark or bright blue tones, and i would get wiggly/jaggy outlines on the picture wherever contrasting coulours' edges met. After 2 service calls (replaced video boards both times), i gave up and popped the back cover on the TV. I wiggled a cable that connects the video board (it is on the top left quarter of the TV if you are looking straight at the front of it), and noticed that the picture improved right away.
I found that there is a bad solder on the cable connector, and simply keep the cover off now, as the connection will get flaky once in a while (especially in warmer temperatures).
Dec 05, 2007 | Televison & Video
Tv Screen Problems
as you see green screen with lines through it
lines you are seeing is called retrace lines.
the problem is due to green video output section failure
please check the followings as given
  • supply to green video output & video output itself
  • components in green video output circuit
  • crt base loose.
  • connector loose in video ckt.
  • signal from signal processor to  green video section is absent.
hope this will help.
good luck.
Oct 15, 2007 | Televison & Video
Picture tinted green
green tint & screen dark means that there is a problem in green video circuit. 1 check green video supply . 2 components in green video ckt. 3 adjustment in green video section. 4 check for signal to green video.
Sep 16, 2007 | Toshiba 36AF42 36" TV
Green screen
If you can still see the video and some fine white lines running diagnally across the screen, it is very likely the picture tube itself which would likely be covered under warranty. If it is a solid green screen with no video, it could be a defective driver transistor or IC going to the picture tube.
Dec 18, 2006 | Toshiba 13A26 13" TV
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
