Question about GPS
Good morning..., dear sir.., may carravel have type GL, 1998. our problem is on the connector cable between chips and display climatronic.., may question : where we can get it. may data is : Jamaaluddin, Surabaya, Jawa Timur, Indonesia, my email adress : jamaaluddin_dmk@yahoo.com. thank's best regard jamaaluddin
    Master:
  • 473 Answers
Well If your Lucky ..Check on kijiji.com it a Sale & Trade Place You can get just about anything... Good Luck
Posted on Sep 30, 2010
Antitheft system keep goes on I can't start vehicle
Use the remote to deactivate alarm or use key in the door lock to unlock the door. The problem you had is when you lock the door and the alarm activates it must see a disarm signal or else it thinks someone broke the window and used the switch to open the door.
Aug 06, 2014 | 1998 Nissan Pathfinder
Passat B5 outside temperature reading fault
IF THE CLIMATRONIC DOES NOT GET ANY TEMP OR TEMP BELOW 5 DEGREES CELCIUS IT WONT GO ON!!!THE AC IS NOT WORKING!!!THE PROBLEM U ARE HAVING SEEMS TO BE A BAD CONTACT AT EITHER THE CONNECTOR AT THE TEMP SENSOR OR AT THE CONNECTORS UNDER THE RIGHT SIDE {DRIVERS SIDE}CONNECTORS LOCATED UNDER THE PROTECTIVE CAP OF THE STEERING HYDRAULIC RESERVOIR OR THE PLENUM CHAMBER {BLACK BOX LOCATED AT THE RIGHT SIDE OF THE CAR JUST BESIDE THE SERVO}LET ME KNOW IF U HAVE ANY QUESTIONS!!
Mar 31, 2014 | 2000 Volkswagen Passat 4Motion
Cybex 600 cardio
Dear Sir:
You must test the fuse with DVOM, for continuity for to see if there ARE not OPEN, you must confirm this status.
2) Reset the c. breaker inside of machine.
3) Reset the treadmill.
4) Tight the ribbon cable from Keypads very well and clean it.
5) Tight the connector from display board vs lower board.
6) ADJUST THE REED SWITCH, see the diagram attached, clean, and tight the connector very WELL!
7) Change the batteries by new one type ALKALINES
sincerely. God bless you
Apr 23, 2012 | Exercise & Fitness
Heater warms up in morning but over the day only gives cold air despite being set at 22degrees. VW dealership says when set at 22degrees it will warm up to 30degrees and then introduce cold air to bring...
vw fit 3 types of aircon,
1.full climate control (you set temp is stays there)
2.climatronic (as your dealer said.....)
3.aircon std (cold draft)
you cannot change whats fitted to another type.
Apr 08, 2010 | 2004 Volkswagen Eurovan
Philips x57 distored / flikering screen
The problem is the pathway from the chip to the internal display. The Nvida chip has several output lines, many of which go to the external monitor but many also go to the internal display connector. I had a case recently where the screen worked fine until the customer opened the display past 90 degrees. What was actually happening was that enough presure was being applied by the internal connector to lift the mother board connector off the mother board. Apparently the factory solder job wasn't too good. We were lucky in that we used a high intensity heat source which remelted the solder on the connector. Whoever was dilligent enough to be to test your screen and cable should be able to trace the signal from the chip out.
Mar 23, 2009 | Computers & Internet
Problem with VW climatronic..display reads " _ _ C" instead of F
Hi, if you press in same time blue buttone(-) and red buttone(+) it will change from _ _C to fahrenheit.
Mar 05, 2009 | 2005 Volkswagen Passat
Olds Cutlass GL 1998
Are the battery cables corroded or otherwise no making a good connection? Clean them with a cable end cleaning tool avail at any auto parts store for around $5.00 and try it again, I bet the that is the issue, also charge the battery and have it tested at Kragen, they do it for free.
Sep 16, 2008 | 1998 Oldsmobile Cutlass
GPS Logo
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
