Question about Dryers
Can combustion air come from bathrooms or bedrooms
  • 489 Answers
Yes it can come from any room. Just remember that the air coming in has to go out of the room just as well.
Posted on Oct 04, 2010
The half of my house where the furnace is is hot. So there is hot air coming from the vents. (some of them). Half of the kitchen living room bathroom and 3 bedrooms and the hallway are blowing cold air.
where is the duct work located? In an attic, crawlspace? It sounds as if part of the system is disconnected. Are the outlets at the floor or in the ceiling? Is the duct work insulated? Can you take actual air temperatures at the outlets?
Feb 01, 2015 | Heating & Cooling
3gfi plugs on a coachman Aurora do not bathroom bedroom work fine.
sometimes, a GFI will be controlled by another GFI. Did you "reset" the GFI ( if there is one ) in the bathroom? You have to find out where
The wires in the dead GFI come from. Electrical panel....circuit breakers. Did you flip each circuit breaker off then on to reset them ?
Do you have an electrical meter ? let me know then we will go from there.
Oct 13, 2014 | Computers & Internet
Heat ducting to the main bedroom
You can use flexible insulated duct work to route it anywhere you would like. Most manufacturers also make elbows, tees etc and can be connected with zip ties.
Jun 11, 2013 | Palomino 2013 Sabre 32 BHOK
What are some good websites for information & pictures of remodeled small bathrooms using ceramic tile?
This is the car and truck section, but you might try youtube for videos.
Dec 18, 2012 | Cars & Trucks
Placed in bedroom to heat large hall, office,dinning room, bathroom...making bedroom to hot
Placement of the heater is the problem. It needs to be in a more central location. Perhaps the hallway. That way, it heat has a more open area to travel and reach the areas you're trying to heat. Keep in mind though, it will always be hotter where the heater is located.
Be safe. Electric Space Heaters can start fires.
Mar 03, 2011 | Heating & Cooling
I have 2goodmanGKS9 gas furnaces(propane) installed on 27 Dec 2009. Both units are working. One is in the basement adjacent to the rear outside wall. Lower unit heats about 1200 square feet. Lower...
well lets start with the 2" pvc pipe. that is a combustion air intake it does not put air into the room, i hope. this is a 90% furnace and they should have installed it that way. there should be 2 pipes to the outside the other is combustion gases. the dust problem maybe caused by the air return pulling the air to that room. the bedroom normaly does not get the trafic that the rest of the condo does.so it would not have as much dust.
Feb 10, 2011 | Goodman Heating & Cooling
There is black "dust"all over
the dv 215 uses no room air for the combustion. it is called a sealed combustion unit all combustion air and vent gases are outside of the building. look at the vent cap outside. is it black? if not unit is most likely working ok. if it is black you need to have it checked. so unless the unit has been damaged you should be getting no air from the combustion into your room.
Feb 08, 2011 | Empire DV-215 Direct Vent Natural Gas...
Arc fault breaker trips sporadically
Are there any heaters anywhere in the circuit for this breaker? (ie: bathroom fan w/light and heater) If yes, I would suspect and inspect them first. Also,any type breaker will trip more easily if the electrical connection screws on the breaker are not tight enough...check to make sure that's not the case.
Jul 31, 2009 | Eaton 20A ARC FAULT BREAKER
Drawing combustion air for a gas dryer
I am assuming that this is a gas dryer not an electric dryer.
Per the 2009 Uniform Mechanical Code Section 902.0
(B) Gas utilization appliances shall not be installed so its combustion, ventilation, and dilution air are obtained only from a bedroom or bathroom unless the bedroom or bathroom has the required volume in accordance with Section 701.2. [NFPA 54:10.1.2]
Section 701.2 basically says you need to provide adequate combustion air. One way is if the volume of the space is 50 cubic feet per 1000 btu. I personally think it is a bad idea to obtain combustion air from a bedroom even if it has adequate volume; it used to be prohibited by the Uniform Mechanical Code. The combustion air requirements are based on the BTUs of the appliance not the CFM. For gas pipe sizing purposes the Uniform Plumbing Code says that clothes dryers have a BTU input rating of approx. 35,000 BTUs. One 4" duct to the attic with the opening of the duct inside the closet within 12 inches of the ceiling would provide enough combustion air per the "One Permanent Opening Method" in UMC chapter 7.
Make up air is a different requirement than combustion air. Chapter 5 of the UMC states that if you have a dryer in a closet you need to provide a make-up air opening of 100 sq inches. The make -up air is to replace the air that is being exhausted not to provide air for combustion. The make -up air could be taken form the exterior of the building or another room within the building. Technically the closet should be insulated and weatherstripped if you get the make-up air and combustion air form the exterior.
Sorry doc john but the fire inspector is not talking about the exhaust duct (environmental air duct). That is required no matter where you have installed the dryer and is a totally separate
Oct 07, 2008 | Dryers
Dryers Logo
42 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
