Question about KitchenAid 24 in. KUDM01TJ - Multiple Color Built-in Dishwasher
The dishwasher has had intermittant problems for the last month or so where it would stop mid cycle and then eventually kick back on and finish the cycle after a couple of hours, but this week, it stopped completely. It will start a cycle and get part of the way through the wash cycle and then just stop with the lights flashing on the front.
  • 441 Answers
Shut the breaker to the dishwasher off for 2 hours then back on, this will give it a reset. Your problem was caused by a power spike
Posted on Sep 30, 2010
Whirlpool quiet wash plus dishwasher
Sounds like the timer module is going bad. Might be getting moisture on contacts. That would explain why it works one time and not the next.Just trying to help!
Aug 14, 2013 | Dishwashers
My top dishwasher drawer won't finish through the cycle. It runs fine on rinse only but not any of the wash cycles. It stops mid cycles, beeps like it has been paused, then tries to start again
Try to feel the temperature of water inside the dishwasher. If it is normal room temperature for the hot wash cycles then it is likely the heater is faulty.
It is not easy to replace unless you have good experience with repairing dishwashers.
Jan 17, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
Kitchenaid KUDS02FRSS0 dishwasher. Stops mid-cycle, sometimes wash, sometimes rinse, sometimes dry. Must restart 4-5-6 times to get it to finish. When finally done dishes are clean, hot & dry....
Hi Dennis.
If the dishwasher is hanging on in the middle of the cycle it is usually the heating system. If the temperature of the water is going up after filling, then the element may be working. The element is tested using a multi meter set on Ohms to read impedance across the heater element contacts. If impedance is infinity (open-off limit), then the element is gone. If the element is OK, then the bi-metal thermostat or the fuse must be replaced. The heating assembly is located at the base of the appliance, behind the kick panel.
Behind the kick panel you should also find the tech sheet illustrating how to run the diagnostic cycle for this model. Run a diagnostic cycle to confirm that the problem is with the heating system. Drain, water sensor and inlet problems sometimes may also result in cycle not finishing.
You can find parts and diagrams for your dishwasher in this page.
Regards.
Ginko
Dec 08, 2011 | Dishwashers
My frigidaire dishwasher works intermittently. It'll completely stop mid -cycle, as if the power was shut off - then eventually indicate a power failure on the display. Then it wil work fine for a c
Hello Tom Weiss, There are a couple of things to check.
1. Check connection at the dishwasher. It is possible that the wire nuts came lose. Re-tighten and wrap with electrical tape to secure.
2. Check for a small leak from sink or faucet this has also been the culpret before.
Dec 05, 2011 | Frigidaire Dishwashers
I'm getting a code "LE".
LE IS A LOCKED MOTOR CODE CHECK FOR OBJECTS IN PUMP BUT THE HAD THAT PROBLEM IS THE PAST
Sep 26, 2009 | LG LDF6810ST Stainless Steel Built-in...
BF41 Dishwasher with a leak stuck in mid cycle
Your air gap is clogged, the thing sticking up from the sink next to the faucet. there is a hose that goes from the air gap to the dishwasher, somewhere in that system is clogged. You can clear it if you have a quarter inch drain snake.
Apr 26, 2017 | Kenmore 17439 Built-in Dishwasher
Kitchen Aid Superba Wisper Quite will not start cycle
Intermittent door switch, should be available, easy to change out and inexpensive.
Aug 04, 2008 | Dishwashers
DU1100 Stops mid cycle.
main control cpu unit failing
needs to be replaced
May 09, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
KitchenAid 24 in. KUDM01TJ - Multiple Color Built-in Dishwasher Logo
490 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
