Question about Lexmark X5470 All-In-One InkJet Printer
Push scanner button slected computer to scann from and then it cannot access application list
  • Lexmark
    Lexmark Sep 30, 2010
    Make sure the Lexmark scan software is installed on the computer. Do you get the same result when scanning from the Lexmark software on the computer? Make sure USB cable is connected securely behind the printer and the computer. Allow all Lexmark files to have full access in the program permissions/rules for the firewall. If these don't help, contact Lexmark technical support.
    Master:
  • 473 Answers
Check Spool for waiting command ..Reset Printer... unplug printer and restard PC with out printer ..then plug printer to PC then start printer...If not Re-Install Printer Software and drivers then re-start PC then check for application ...
Posted on Sep 30, 2010
I want to block yahoo messenger on my computer, how can i do it?
Just block it from the Firewall settings: go to Control Panel > Windows Firewall > Exceptions and untick the mark next to it.
But the best solution is to uninstall it , from Control Panel > Programs.
Aug 13, 2011 | Computers & Internet
In lan scanner xerox is not coonected i have alredy install the drivers for scanner but he doesnt reply when ping command fire
did you press the scann button on the copier?
If not press scann button and then try to ping it.
Hope that helps!
Jul 15, 2011 | Canon imageRUNNER 2018 Copier
The scanner is not scanning as fast as it says its suppose and we just got it why is this
Hello
Make sure EPSON Smart Panel is installed.
If you are using Windows XP:
Click the Events tab in your scanner's Properties dialog box and make sure Take no action is not selected. Also, make sure the desired button is selected in the Select an event list box, and Start this program is selected.
For Windows Me, 98, and 2000 users:
Click the Events tab in your scanner's Properties dialog box and make sure the Disable device events check box is clear. Also, make sure the desired button is selected in the Scanner events list box, and the desired application in the Send to this application list is selected.
For Mac OS X users:
When in Classic mode, the buttons are disabled. Quit Classic mode. Initially, only the user who installed the scanner software can scan using the buttons. Other users must start EPSON Scanner Monitor in the Applications folder before using the buttons for the first time. From then on, pressing a button will automatically start the application assigned to it.
Jun 10, 2011 | Epson GT-2500 Flatbed Scanner
I downloaded the disk for my scanner and now I dont know what to do so I can ues it.
Not sure what kind of scanner you have, but on my Lexmark, I have to push the scan button on the printer to scan. It then downloads the application list to the scanner, and scans. After it scans, then the Lexmark Imaging Studio (the downloaded program on the computer) comes up on the computer screen, and received the scan. Not knowing what kind of scanner you have, I can only explain in generalities. Good luck, and hope this helps.
Jun 16, 2010 | Office Equipment & Supplies
There is no application registered for this event is the message I get when pressing the buttons on the scanner (email/copy/scan buttons)
In the software setup, there will be a place where you program each of the Application Buttons to access a program you have installed on your computer.
Examples are: Photoshop, Email, OCR, Corel Photopaint, etc. any program that could use a feature called, "Aquire" which is simply getting a graphic from the scanner.
Be shure to install the Applications disc that came with the scanner, (not just the driver). And run the configuration, or settings tool, to set up what programs will run when you press the Quick access buttons on the scanner.
Otherwise, you can access the scanner features from a menu item called "Aquire" in Photoshop, Corel photopaint, or in Microsoft Office it's in the menu, string Insert - Image - from scanner or camera.
There are some complications with the WIA driver, and reccomends using the ScanGear CS software instead. I'm guessing WIA is (Windows Interface Access, or Windows Instant Access) whatever, it is, it is the buttons you're talking about.
I downloaded a driver from Server 1, Here, to get an Idea about your hardware. IF that link dosn't bring you to a site that says,
"Downloading Driver Canon CanoScan LiDE25"
then start here a few steps back, and find your model number in the list.
If you have the driver disc for this device, just use that,
if you have already done that,
find your scanner software on the Start Menu, and look for a configuration tool.
Hope this helps.
Dec 12, 2009 | Canon CanoScan LiDE 30 Flatbed Scanner
How to do scannning
you can scanning application oftware.If it has no navigation key which use pc to scane.Only use application software.
Thank you very much for your requist.
Jun 08, 2009 | Samsung SCX-5115 Fax Machines
Pixma mp520 scanner won't scan
I emailed Canon Tech Support (after searching their MP FAQ) and received this response. It worked for me:
Please follow these steps to set the push button event for the MP520
scanner:
1. Click on the Windows button and then Control Panel.
2. Double-click 'Scanners and Cameras'. For Vista users, if 'Scanners and Cameras' is not listed, click 'Switch to Classic View' on the left and then try again.
3. Double-click on the MP520.
4. Next, click on the Events tab.
5. For the 'Send to this application' option, select ScanGear driver, MP Navigator, or imaging application you would like to use for the scan button event in the list.
6. Click Apply or OK to save your settings.
Jul 16, 2008 | HP PSC 2110 All-In-One InkJet Printer
Scanner
this happened to me yesterday after recieving whatever lexmark update my computer downloaded. I restarted everything, computer and turned on/off fax and unplugged for a bit.
It seems to be working OK now.
I know that's lame dell-style, advice, but the restart worked for me.
Feb 12, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
32 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
