Question about Canon imageCLASS MF6530 Monochrome Laser Copier/Printer
Will not copy. Cartridge replaced. Takes paper through and comes out blank
    Master:
  • 473 Answers
Try to reset the unit ...go on menu setup and ckeck for tuner level
posibility Drum Damage Refer to Professional Laser Printer Repair
Posted on Oct 01, 2010
    Scholar:
  • 107 Answers
Hello, problem with your machine is that the laser scanner shutter linkage is out of position, or needs to be relubed, so shutter will move freely. this is not as easy as you think, if your goinging to relube and put into place, the down and dirty way would be to take toner cartridge out of machine, look into machine, on the right side upper area, you will need flashlight, look at where the toner cartridge comes out, you will see, if you look hard ,the metal/silver color of the, you can take some paper roll it and tear to fit, to push that shutter up, then with the paper you can then tape it to the plastic frame, holding it into place, now problem with this is, you can actually push shutter out of position, and cause it to stay closed. i know, i did it once. never do that again.
Posted on Sep 30, 2010
Copies come out blank.
several possibility of problem are:
- empty toner (you must check it)
- moist paper (solution = the copies which come out blank return to paper case, to use again. it is mean to use not moist paper)
- lifetime of the drum is over.
Jun 21, 2011 | Canon PC-1060 Black and White Copier
Paper comes out with nothing on it
On the new cartridge, did you remember to remove the plastic seal from the toner? Do you get blank sheets only when you print or when you make copies too? Were you careful when clearing the paper jam or could you have accidentally damaged the printer?
Jan 07, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
Hi,i have Xerox Pe220,i am not able to copy as paper comes out blank but i can print from computer,i have replaced new cartridge but same result and put back the old cartridge,PLEASE HELP!!
Iffi,
Are you making copies on the glass or ADF? If you are getting blank copies using both the glass and ADF than your CIS(scanner) unit is bad.
Mar 22, 2011 | Xerox WorkCentre PE220
Blank page when I copy or print reports
Re check all the connections. When taking off the paper feed assay, other parts and plug and jack connections were needed to be taken off first.
Make sure the drum seats in its correct position, silver grounds are not bent.
The copy cartridge and Dev housing are not connecting very good somewhere.
Make sure the machine is unplugged.
Try running copies.
Apr 21, 2010 | Xerox WorkCentre Pro 580 Plain Paper Laser...
Copies blank
This is normally the corrona wire that needs to be replaced in the transfer unit and drum unit.
Sep 14, 2009 | Minolta EP4000/5000 CS/PRO Copier
My ML2010 printer turns on, takes paper, but stops halfway (blank
Hello sir; Replace paper pick up roller and feed roller.
Aug 02, 2009 | Office Equipment & Supplies
Blank copies
see the cartridge do is good installed.
Remove the cartridge and putt it again.
If the problem do not go away please try with other cartridge.
Or if the printer is ink-jet printer and you have not used it for some time than the ink can be stuck
Jul 16, 2009 | Office Equipment & Supplies
Toshiba e 650 Copier was working and copies were fading so we
When you changed the toner did you remove the strip on the new toner to release the toner
Jun 12, 2009 | Toshiba E-STUDIO 650 Copier
Make sure you remove the seal tape on the new cartridge thats why it making noise then install properly.
Canon PC1080f copies coming out blank
Did you pull the plastic tape off of the cartridge?
Feb 09, 2009 | Canon PC-1080F Plain Paper Laser Fax
Canon imageCLASS MF6530 Monochrome Laser Copier/Printer Logo
104 people viewed this question
old marine
old marine
