Question about Epson Stylus R265 InkJet Photo Printer
After changing ink, my colours come out wrong
    Master:
  • 473 Answers
Issue with your Cartridge Carrier... May need to clean up your interior ..Try to clean up a few time with menu setup program ...also take off your cartridge and bang it gently on a paper on the side of the table then clean up with a Q-tip the inside of your machine ..Go get on any computer store ask for toner cleaner tell him you want to clean you printer ..then with a Q-tip clean all your inside printer the your printer will work like new..
Posted on Oct 01, 2010
I was low on black ink and needed to print flyers , the Epson 630 asked me if i would like to continue printing and use other colors , i pushed yes, and have changed out ink and its still prints in r
Is it possible that you accidentally put the wrong colour cartidges in the wrong spots? Otherwise, it should work fine. Also, the printer's default is usually to print in colour, therefore even pages in black and white will usr colour, which uses up coloured ink. Always check the prooerties when printing to switch to b&w:)
Jan 20, 2014 | Epson WorkForce 630 Wireless All-in-One...
I dont have any coloured ink cartidges left and need to immediately print some forms in full black will be okay but i cannot change my colours to black as the ink holder stays on the far right of my epson...
To print in all black, you can change a setting through the computer to tell the printer to only use the black ink. This is better than putting black ink where the color ink normally would go as that would cause the shading to be wrong and potentially ruin the documents.
If you have enough black ink in the printer, before you finalize the printing process make sure you have black and white only selected.
This will allow you to print without getting access to the ink cartridge holders.
Good luck hope this helps.
Mar 11, 2011 | Epson PRINTER, 4800 PORTRAIT EDITION...
Printer will not print in black. Colour ink appears to be out. Should this effect it
Yes for sure If your colour ink is down there is the possibility that the print may vary in colour.As the colour ink level decreases you might have got the error to change the ink. Hence it will tend to change the printing commands. To further confirm on this you can disconnect printer, uninstall and reinstall the printer software,then connect the printer for hardware detection and installation. now do a head cleaning maintenance and a test printing. If there is still no change it will be better to replace the colour cartridge after using the menu for ink cartridge changing so as to get the ink indication correct after installation. Hope you try this out. Good day
Aug 13, 2010 | Epson Stylus C46 InkJet Printer
Printer HP Deskjet D1460 prints pink"..Instead of Black
The printed colours are an "additive" mix of the "primary" colours in your printer.
So, when the colour ink-jet cartridge is "out-of-ink" on one (or more) of its colours, the "mix" will be off, and the "wrong" colour will be the result.
Change the colour cartridge.
Before changing it, run a "deep-cleaning" cycle, using the HP Support software that was installed when you installed from the CD-ROM that came with the printer, to "clean" any/all "clogged" ink-jets -- i.e., a clog could be preventing one colour of ink from being sprayed onto the paper.
Apr 08, 2010 | HP DeskJet D1460 InkJet Printer
Have changed Ink Black and Colour... Stil getting error Message.
Make sure the tape covering the hole on the bottom of the black cartridge is removed. and then go into the printers folder and right click on your printer icon and go into the properties of that printer and there should be something in there to tell it that you changed cartridges and you can also print a test page as well.
Feb 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Printing and copying colour wrong
Please change your printer's colour cartridge. after that the issue will resolve.
Nov 23, 2008 | Brother MFC 420CN All-In-One InkJet...
Poor photo printing
when the printer says that "for best results use Epson Ink." They mean it! otherwise using Xprint cartridges works as well, if changing the type of ink doesn't work then you might have to tinker with the advanced settings (you can change the amount of color used in the print) when you click the properties button in the print screen, ONLY if you know what you are doing!!
Oct 10, 2008 | Epson Stylus Photo R300 InkJet Printer
Wrong colours!
Hi Dannydoda,
I understand that, you are using different compatible ink cartridges and having problem with colors.
HP printers has a small built in firmware, which can detect the original ink cartridges and the ink level.
Using other compatible ink cartridges may damage the print heads of the printer.
I suggest you to replace the ink cartridges with original or Genuine HP cartridges.
You can also try some of the steps to fix the issue as given in the web link.
please click on the web link given below and perform the steps carefully.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00042885&cc=us&lc=en&dlc=en&product=79499
This should fix the issue.
Have a great day!
Mar 21, 2008 | HP PSC 2210 All-In-One InkJet Printer
Epson Stylus R265 InkJet Photo Printer Logo
178 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
