Question about Maytag Ovens
How to fix f5 - Maytag Ovens
    Sergeant:
    Champion:
  • 351 Answers
F 5 is a bad ecr electronic rang control need to replaces
Posted on Oct 01, 2010
Getting error code EO - F5. What's the fix???
Hello & Welcome to FixYa
Error code F5-E0 is a door latch failure and is displayed due to malfunction of door latch-switch assembly. First try to check the door latch switch, if fine then recommended repair is replacement of door latch-switch mechanism. Please get back to me if you have any other questions.
Kevin
Mar 07, 2011 | Whirlpool RBS275PD Electric Single Oven
Whirlpool Gold Self-Cleaning Oven Error Message: E1 F5. What does it mean and can I fix it?
E1-F5 means the self clean latch will not lock.
Try pressing down any key and hold for 1 minute, see if this clears it. If not you will most likely need the latch switch replacing.
Dec 20, 2010 | Ovens
Trying to get gas self clean/oven to start. Getting error E1 F5.
E1 F5 is bad door lock assembly. Only way to repair is to replace the locking assembly completly. Sorry. Hope this helps.
Mar 06, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Admiral designer series gas stove flashing f5 error
Hi There
i look up your codes for you and found it. you can read this and i hope this gets you in the right direction.
F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC)Thank you for writing to fix ya.
Best Regards Richard
Dec 23, 2009 | Ovens
E1 F5 Error on Whirlpool Accubake Oven
The lock latch is located directly in the center upper portion of the door. It is a hook shaped latch that lock by turning downward. This lock gets stuck in this position which causes the e1 f5 error code. Locate the latch through the vent holes in the upper front of the oven door. Insert flat headed srew driver into vent hole and gently push latch up to a horizontal position & simply open door. Once unlocked, push cancel on the control panel.This will clear the error code and resolve the issue.
Apr 07, 2009 | Ovens
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
The F5 error code?
I unplugged the oven and it cleared the code and was able to self clean the oven.
Jun 19, 2007 | Whirlpool GBS307PR Electric Single Oven
Ovens Logo
53 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
