Question about Motorola Mobility RAZR V3m Cellular Phone
Progessive text I had a V3m and the charger port went bad, received a new one and I want to have progessive text like my old one. How do I set it up so that I can just hit 968 and it will type "you" insted of "wmt"
    Brigadier General:
  • 7,752 Answers
Change the text editor settings
Posted on May 29, 2008
Razr V3M and get invalid charger. I am using the same charger that came with the phone though it is a new battery.
The problem sounds like your phone problem. How old are both the phoen and charger. Who is your carrier. Depending on the carrier you may be able to get the phone replace. If you have are ready purchase a new battery and it is still saying invalid charger more and likely it is the phone. Clean the battery connections with a toothbrush. Also Use can air to blow out the dirt in the charging port. Clean these areas out very well and you should be find. If not contact motorola and have them send you a replacement. If your still getting a invaild charger. You may even be able to get them to send you a charger.
Oct 31, 2010 | Motorola Mobility RAZR V3i Cellular Phone
My inbox on my razor phone says no messages but memory full
I mentioned this in another area. We just got my son a motorola razr v3m, verizon. Any time he tried to check his inbox (which is text) or tried to send a text it would show memory full....this was the same if he tried to take a picture and send it.
First take out your battery, with the battery out, hold down you on button for like 15 seconds to drain the phone of juice, then put your battery back in it and turn it on. If this did not reset your phone, and if you are on verizon as your carrier, then you need to call them and make sure that they have you set up on their text messaging program. It used to be that if you didn't have, then they would charge you .20 cents a text, but with some of the razr, such as the v3m, you have to actually be on a monthly text plan to view inbox, send text, send pics, and receive pics and texts.
Nov 03, 2009 | Motorola Mobility RAZR V3m Cellular Phone
My razr v3m always thinks its charging even when i take the charger out it still says charging. and the phone wont stay off it turns right back on and says unauthorized charger
Sounds like the connector for the charger/data cable has become damages, there are tiny pin contacts inside that can get bent or the female port on the phone can become wallowed out. If you have insurance on your phone you can take it back and have it replaced. You might also try some compressed air blown into the connector gently to see if there is something stuck inside.
Check also the charger cable end if you look carefully inside you can see the pins, make sure they aren' bent or pushed in, might have bad charger connector.
Hope this helps
TankMurdock
Apr 23, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Motorola V3m: keyboard lights up:keys frozen,no power to screen.
If you did not replace the firmware,or try and hack the phone then it just died. Nothing last forever. This just means that the light did not die, but the hardware that holds the firmware could have went bad.
You could contact moto and see if they will fix it cheaper than you
can get one off e-bay. You only have 8mo left till your contract runs out. Do not use the upgrade through the carrier,or you are getting robbed. Either wait till it runs out and start a new one or go to
www.wirefly.com, you can get the same exact contract through the same carrier but get a way lower price on the phone,unless the phone you want is free. You could have someone try and reflash
a new firmware on the phone, but I don't think that is the problem.
Hope moto does something for you.
Mar 22, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Texting problem
in your messaging screen, choose settings (soft key). Under "all messages" choose option 2 "auto erase". Switch this to on. If you also switch "auto save" to on, it will store up to 50 texts before deleting the oldest text as new ones are received. Anyway, turning auto erase on is the way to fix your problem. I don't know what it is, but razrs can be finicky like that sometimes.
Apr 30, 2008 | Motorola Mobility RAZR V3m Cellular Phone
RAZR V3m texting problem
u sould contact your service provoder for that matter cause the dropp thing has nothing with text messages
Apr 23, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Razr v3m
The Flex cable probably went bad on it and yes it can all of a sudden so this.
Mar 20, 2008 | Motorola Mobility RAZR V3m Cellular Phone
MOTORAZR V3m "Memory Full"
DELETE YOUR COOKIES AND TEMP INTERNET FILES
Feb 17, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Motorola Mobility RAZR V3m Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
