Question about Whirlpool LHW0050PQ Front Load Washer
I need to know how to replace the belt - Whirlpool LHW0050PQ Front Load Washer
    Genius:
  • 1,417 Answers
intruction
Front load washers are convenient and easy to use. They offer the convenience of extra capacity and tend to wash clothes a little better than their top loading counterparts. Sometimes, however, the belt that drives the drum will break and need to be replaced. Replacing a drive belt on front load washers is not that difficult and can be performed by many home mechanics.
  • Use the screwdrivers to remove the screws in the rear access panel of the washer and then pull off the panel.
  • 2
    Locate the pump coupling, which is the rubber part that connects the motor to the water pump, and unscrew the clamps securing it to the motor. Once the coupling is removed, tension is removed from the belt.
  • 3
    Slide the belt off of the pulley assemblies and slide the new belt in its stead. Reattach the coupling with the mounting clamps and check the tension on the belt. You should be able to wiggle the belt a bit, but not more than an inch or so.
  • 4 Close the access panel and turn on the machine. Run it through a cycle while observing it to see how it handles the belt change.
  • TIPS
    Be sure to unplug the washing machine before beginning to work on it. thnak and thanks for using fixya.
    Posted on Sep 30, 2010
    How do you know where u need to replace the timing belt
    The engine dies when the belt breaks.
    Can also do major damage to the engine.
    Most car brands recommend replacing at 60,00 to 80,000 miles.
    Jun 30, 2012 | Cars & Trucks
    How to know if timing belt on volvo t6 needs to be replaced if dealer stamps and bills don't show it. The 105 page was stamped.
    The timing belt should have been replaced at the 105K service. Someone should look at the timing belt to determine the condition. However, if you have any doubts, you should replace it to be on the safe side. Also replace the mechanical tensioner.
    Apr 10, 2010 | 2001 Volvo S60
    1996 tacoma belt replacement, all belts
    Dear Belt Replacer,
    Nothing special you need to know, just that to make sure you take the belts off and reinstall them in the correct order, also make sure that each belt has between half an inch and one inch of play when the final tension is set on each belt, thx, I'M HERE TO HELP!!!
    Nov 22, 2009 | 1998 Toyota Tacoma
    I am over heating but not from thermostat problem but the belt
    I'm interested to know how you pin down the problem to the belt to make sure the diagnose id accurate.
    How do you know the problem from the belt.
    If you are sure a problem from the belt then there are 2 posible causes:
    1- Your water pump need to be replaced.
    2- Your fan clutch needs replaced.
    Aug 09, 2009 | 1999 Oldsmobile Aurora
    Opel Corsa timing belt replacement
    You need to find the timing marks on both crank and cam pulleys, set it, then take of the belt ane dont let any pulley move! Put on new belt and set the tension of the belt.
    Jul 31, 2009 | 2000 Acura Integra
    How to replace the belt on an Indesit IS60V Tumble Dryer
    hello, replacing a belt on a dryer is pretty straight forward and wont use to many tools other then what you need to take the cover off, the only difficult part is keeping the belt on the pulley while getting the belt all the way around the tumbler it may take a few trys but its not imposable when i did mine it took about 10 mins to get the belt on the tumbler while keeping the belt on the pulley if you have somebody that can help you this will make the job allot easier. good luck
    Mar 26, 2009 | Dryers
    Squileeng with the belt
    I need to know why you changed the power steering pump and the belt. It sounds like you had a problem and replaced the wrong component. You chould change whatever component is locked up behind the pulley and replace the belt. Let me know if this helps.
    Jan 15, 2009 | 1991 Chevrolet Caprice
    Need to Know how to replace belt on 07 jeep Liberty. Cat was under hood when I started and knocked belt off. Need to Know how to put belt back on.
    serpentine belt requires a wrench (prybar) on the tensioner.
    Re install the belt & release tension from prybar.
    There is a diagram on the radiator supprt telling of the belt path.
    Dec 25, 2008 | 2007 Jeep Liberty Sport
    1994 Corvette Cassette/Radio?Replace cassette "drive belt"??
    Donne Trav, you can take that belt to an electronics shop (your neighborhood shop is best). They will most likely have replacement belts. They will also have a tool that measures the belt so you know which size to get. I used to fix T.V.'s and VCR's. Its the best method when you cannot source an original belt. As far as the diagram, I would need a model # of the radio to even start a search for such a thing.
    May 16, 2008 | 1994 Chevrolet Corvette
    Whirlpool LHW0050PQ Front Load Washer Logo
    Sal De
    Gerry Harvey
    Gerry Harvey
