Question about GE JTP85 Electric Double Oven
The turn table will not turn and the light will not light when I operate the Microwave. It heats fine....
  • Lancair IV Sep 30, 2010
    Thanks. I'm 99% sure the light and the turn table not working are related some how! The trouble shooting tips are great, but didn't mention my issue.
  • GE Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Sep 30, 2010
    Thanks Heatman101. Unfortunately, the basic troubleshooting tips does not help us. I'm 99% confident the turn table and light malfunction are related. probably a bad circuit board.
    Thanks again
  • D. Floyd Kolb
    D. Floyd Kolb Oct 01, 2010
    Yes, you may be right...I basically assumed that the turn table was just bad and that the light was an after thought...
    Many people never realize their light was blown till something else goes, so I usually disconnect the light deal heavily and do not even consider that...
    But with what you are saying then I would go the circuit board route even though it often is something else...it is very possible also that they are interrelated...
    heatman101
Microwave table does not turn
table motor needs to be replaced probably
Dec 07, 2013 | GE JKP86 Electric Double Oven
Do you take the turn table out when using both the microwave and the oven (combie)
No; if you're using the microwave you need to leave the turntable in to ensure the food heats evenly.
If you use just the oven or grill you can still leave the turntable in; there's no need to remove it. But you could remove it if you wanted.
Jul 25, 2011 | Ovens
Conbi microwave oven and grill grill and oven working microwave not warming up light on and turn table working as normal
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Mar 05, 2011 | Ovens
Microwave has power...light lights and turn table turns but nothinng heats up and there is a smell of burnt electrical items
heatman101
Nov 19, 2010 | KitchenAid KEMC378KSS Electric Double Oven
Hotpoint microwave wp900esp23s won't heat up light comes on and table turns but thats all
heatman101
Oct 14, 2010 | Hotpoint Ovens
Oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. checked the circuit breaker and it is fine. is there a thermal fuse i can check. where...
oven will not heat up. microwave works fine. all oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. checked the circuit breaker and it is fine. is there a thermal fuse i can check. where is it located
Jul 19, 2010 | GE JKP86 Electric Double Oven
GE double oven wall, JKP85B0A3BB
I would start by checking all of the door switches. Once you remove the shell, you will see them all on a rail where the door latch goes. Some will be normally open, some normally closed. If they all check out, check all of your overloads and thermal fuses. They should all read closed. If they all check out as well, replace your magnatron, capacitor, and diodes.
Oct 25, 2008 | GE JKP85 Electric Double Oven
Microwave oven stopped working
This is most common in over the range microwaves. Cooking grease migrates into the door switches, resulting in the symptoms you list. Replace the door primary and secondary interlock switches and you should be cooking again. NOTE: be careful not to touch other wires! Even with the unit disconnected from power, if you happen to have a bad bleeder resister in the high voltage capacitor you can still get a nasty zap !
Aug 27, 2008 | Ovens
Microwave will turn on but not heat
Test the high voltage capacitor, the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Nov 26, 2007 | GE JTP85 Electric Double Oven
GE JTP85 Electric Double Oven Logo
103 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
