Question about GPS
Takes forever for garmin 260w to locate satellite signal
  • 4 more comments
  • liz1952 Jun 29, 2008
    Mine is slow to find the satellite also.
  • Anonymous Jul 01, 2008
    Same issue cannot get Garmin 260W to locate any signal. My Garmin 200W aquires signal just fine in the same area I am testing the 260W. May have to replace or return the unit.
  • missjaneltow Jul 11, 2008
    trouble finding satellite
  • sharlenelu Jul 14, 2008
    Yes, same here, and over in the Amazon website for Garmin 260w, tons of reviewers report the same thing. I imagine Garmin should have a solution by now?
  • Anonymous Aug 14, 2008
    mine worked fine, immediate satellite lock about 5 seconds after turning on, after the new software update it takes like 5 minutes or longer
  • Anonymous Dec 26, 2008
    same problem, used to work fine, now it sometimes never finds signal. hit or miss. wtf
It takes forever to get a gps signal on my garmin 260w , can you help please . thank you .
Posted on Sep 18, 2008
How to unlock the garmin nuvi 260w
  • 1
    Turn on your Nuvi 260W.
  • 2
    Enter the four-digit PIN you chose when you locked the device. If you have forgotten the PIN, proceed to Step 3.
  • 3
    Drive to your security location. When you reach your security location the Nuvi 260W will unlock automatically. If you forgot your security location or cannot drive there, proceed to Step 4.
  • 4
    Call Garmin to unlock your device. You need your receipt to complete the process. Call 1-800-800-1020 in the U.S., 1-866-429-9296 in Canada. See Resources for the Garmin support webpage.
  • Mar 05, 2011 | Garmin nuvi 260W GPS Receiver
    UNLOCK GARMIN 260W
    Take it back to the security location and it will automatically unlock. If this is not possible, send it in to Garmin with original receipt from Garmin dealer and they will unlock it for you. If this is not possible, the unit is permanently locked - there is no master unlock code.
    Oct 31, 2010 | Garmin nuvi 260W GPS Receiver
    Problem with Garmin Nuvi 260w
    No because the date recorded in the unit would have been set via satellite and cannot be changed.
    Jan 08, 2010 | Garmin nuvi 260W GPS Receiver
    Hi, I have a garmin 260W that I use at home ( washington state). I purchased a download for France and downloaded it successfully. I have the map of france, but it is not locating the satellites - (...
    When you change the location of your GPS drastically (taking it to another country), it sometimes takes 20-30 minutes for the unit to acquire the satellites and re-set itself for that country. Leave it in an area with open sky, and wait for it to find the satellites, then you should be able to navigate.
    I know this solution might be too late for you, but I'm posting the solution in the hope that it can help others with the same problem.
    Nov 12, 2009 | Garmin n?vi 260W GPS
    Trouble finding satellite-Garmin Nuivi 260w
    Suggestion that the battery in this thing is getting old or is not fuctioning as it is supposed to it would not matter if it was connected via cigarette lighter.
    Jun 16, 2009 | Garmin StreetPilot 2610 GPS Receiver
    My screen will always states "acquiring satellites"
    Have you updated your Garmin in a while? To update it you need to download their Webupdater program from their website.
    http://www8.garmin.com/products/webupdater/howtoinstall.jsp
    From here follow the instructions. A simple update of your GPS may fix this problem.
    May 20, 2009 | Garmin nuvi 260W GPS Receiver
    Trouble locating satellites
    Hi, my name is Vince & i had that very same problem with my nuvi 200w, have you tried to update it on your pc ?, i updated mine after travelling down the motorway at 40 miles an hour thinking that their was road works after the sat nav told me. I also found that updating it seemed to increase the signal strength too, try it, it may solve your problem.
    Apr 24, 2009 | Garmin nuvi 260W GPS Receiver
    Garmin 260w won't acquire satellites
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
    • If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes.
    • If your unit has not been used for an extended period of time (more then a month), it may take 3-5 minutes to acquire satellites.
    • If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal.
    • If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased.
    • If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions.
    • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites.
      • If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*.
    If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software by using our WebUpdater program. Once your unit is updated please allow the unit to acquire satellites outdoors in a stationary position with a clear view of the sky.
    Jan 30, 2009 | Garmin nuvi 260W GPS Receiver
    Since my last time i used garmin nuvi 260 it cant find a signal
    Try going outside with a clear veiw of the sky, since it cant aquire a satellite its simulating the last place where you were. Try canceling the route and see if it connects with the satellite.
    Jan 08, 2009 | Garmin nuvi 260W GPS Receiver
    Cannot locate satellites
    I can help you fix the satellite problem with your Garmin Nuvi 265WT.
    Poor or inaccurate GPS tracking, and taking a long time to acquire satellites, are issues that have been addressed by Nuvi 265WT firmware updates.
    There are three steps to take to get your Nuvi 265WT running better than new:
    1. Back up your Favorites.
    2. Perform a Hard Reset.
    3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
    I hope that helps.
    _____________________________
    Nuvi 265WT Manuals here.
    Nov 23, 2008 | Garmin nuvi 260W GPS Receiver
    GPS Logo
    787 people viewed this question
    Top GPS Experts
    Will Halftowaite
    Are you a GPS Expert? Answer questions, earn points and help others
