Question about Maytag Washing Machines
The machine wont finish cycleandpump out the water.Does it have afilter and if so where is it
  • Maytag Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 30, 2010
My washing machine wont fill up with water, what would the problem be, ive cleaned the hose at both ends so its not blocked?
usually the hot and cold water solenoid fail stopping water to flow
replaceable part
location
in where the hoses attach to the washing machine
May 09, 2016 | Washing Machines
Won't finish the wash cycle
Initially we 1)used less detergent and make sure its marked 'he' . extra soap suds initiates error codes. 2) ran white vinegar with no detergent to clear suds 3) opened, checked and cleared trap.
Everything worked for a time but codes would return or like you would not finish wash cycle until water line in back of machine was made rigid so there was no chance of water or sud backup. So far so good. Good luck.
May 27, 2014 | Bosch Nexxt 300 Series WFMC2201UC
Kenmore HE3 2plus wont finish cycle
I'm not saying you don't have a problem. But just to be clear. You do understand that the last minutes on these machines can vary. The machine senses certain conditions in clothing, water discharge, etc. So sometimes the "1 min left" indication can stretch into many minutes. In theory, at least, it's possible your machine just needs to be left alone until it finishes whatever it's doing. However, one would think that any issues not resolved in 10 - 20 min are an indication of a problem. So i guess that's my next question, did you wait long enough? Keep in mind i am not a kenmore expert.
Jan 06, 2013 | Kenmore HE2 Plus Front Load Washer
Door remains locked after wash, no error code or anything.
if there is water left in the machine it will not open pull out the washer if under work top tilt the machine back wards the door should open thwn clean filter and try
Dec 02, 2012 | Washing Machines
Recently my dishwasher KUDSO1FLSS2 is not cleaning the top rack very well requiring multiple washings. Both the top spinner and mid rack spinner (under top rack) turn freely by hand but limited water...
If there afilter on the inlet hose it might need clening,if you have a partial blockage it will reduce the volume of water entering your appliance.Hope this helps.
May 14, 2011 | KitchenAid 24 in. KUDS01FLSS Built-In...
The water mostly drains from the washer but a one inch puddle is left at the bottom. i unscrewed the black hose in the back where the water drains out and the hose seems clear. is there afilter...
You need to check your pump and drain lines inside the machine for any obstructions. If the machine is draining but not taking all the water out during the drain time allotted, you have a blockage. Here is a link to a video to show you how to get to the pump.
Nov 26, 2010 | Hotpoint VVSR1070D Top Load Washer
Wont finish a small load. Gets to 4 minutes and
With a small load, the machine will have a difficult, if not impossible job of balancing the load. A bigger load will help. Another thing you can do is to use a low spin speed. If you wish to spin it out faster, just turn the machine back on after it has finished a cycle on the low spin speed and just push the spin speed button without selecting a cycle. You can touch the spin speed button until it shows the next higher spin speed, then push the start button and the machine will not fill with any water, it will just pump and spin. (about 14 minutes) This generally works, because you have spun most of the water out at a lower spin speed, and now the washer is able to reach the next higher spin speed as the load is not as unbalanced as it was before the low speed spin.
Nov 17, 2009 | LG WM0642H Front Load
Water won't drain after cycle is done. Leaves 1-2 inches of water in bottom. Checked hose and its clear. Put hose going to disposal in bucket and water comes out when diswasher is cycling
it is easy track this path of water from bottom of m/c it will b afilter then small hoses to drain pump thenouter hoses <
thanks
Jul 13, 2009 | Dishwashers
Problems Descaling
Hi You have finished the first part of the descale process if that machine is like all the others. Rinse out your water tank and put fresh water in it. Then put it back on the machine and close then open the knob for steam and let it run the whole tank out. When it is finished the descale light will disappear and your green light will blink and the water light will be steady. Refill the water tank and close and then open the steam knob to prime so the water light will go out.
Jun 12, 2009 | Gaggia Syncrony Compact Coffee...
Washing machine wont fill with water-hoover performance 1100
check that the water inlet pipe is not blocked. it does have a filtewhich can get blocked with lime scale.
Dec 27, 2008 | Washing Machines
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
