Question about Westinghouse Refrigerators
The Fridge will not cut out, Thermostat problem?
  • Westinghouse Master
  • 1,711 Answers
Yes if it a meachanical knob. If it is electronic then is the whole electronic control.
Posted on Oct 01, 2010
I have a Samsung side by side model # SRS 632NSS. it is about 18 months old. The freezer side does not function but the fridge side is normal .We have tried turning it off and resetting it however it is...
Defrost cycle is very often. Check freezer timer/thermostat might be cuts off frequently. Check thermostat setting..Check fridge is working continuously until frosting over freezer by keeping thermostat at 9' clock position. If not replace thermostat.
Jan 30, 2011 | Samsung RS2630SH Side by Side Refrigerator
It runs all the time
Switch the fridge off for some time till the frost clears off. make sure the compressor has cooled off before you start the fridge once again.Switch on and checck if there is any ICE formation in about 1-2 hours. If so your compressor, gas and performance is good.
Now we need to check to see if the thermostat is cutting off. Having kept the thermostat in normal mode , the compressor must cut off in less than 3-4 hours. If not the thermostat is faulty. Also if you look on if the fridge does not shut offf in baout 8-9 hours of running then your thermostat, timer can be suspects.
However if there is no cooling reached in the first place then it is possible that the compressor or the gas pressure is down.
Check for leak if the fridge is old before you waste money on filling and losing .
Sep 01, 2010 | Refrigerators
My fridge freezer is running non stop
It is probably because it's not getting cold enough to cut off. If you slowly turn the thermostat to warmer it should cut off when it gets to that temp.If it doesn't cut off then it is a thermostat problem. When you have heavy ice buildup on the evaporator coils inside the freezer behind the back panel that will hamper the cooling. This is caused by a defrost system failure.
Aug 15, 2009 | Freezers
Hi, I have a westpoint WPS1602 fridge and the problem is defrost not working. I checked the thermostat, it suppose to be NC contact at low temperatures. but is showing open circuit always. The thermostat...
The thermostat should show open above 50 degrees to protect the refrigerator from over heating during defrost. If its not closing while frozen the thermostat needs to be replaced and that will get you going. The new thermostat come with crimp splicer connections and you only need to unplug the fridge and cut the two wires to it, then splice the new one in.
If that don't get you running again let me know and I will give some other things to check, Thanks, Sea Breeze
Apr 21, 2009 | Refrigerators
Liebherr larder fridge not working in normal mode
thermostat is faulty - supercool just bypasses the stat
Sep 23, 2008 | Liebherr Refrigerators
Fridge freezer upright
Replaced the thermostat
Jun 22, 2008 | Freezers
WARNING FRIDGE
does the freezer side freeze up also? i suspect if unit uses electronic sensors probably the thermostat sensors in the refrigerator section is defective. possibly there can be a thermostat board also you probably have to check diagrams.
Apr 19, 2008 | Samsung 26.0 Cu. Ft. Side-by-Side...
KBFA20ERSS- Fridge stopped staying cool; thermostat doesn't work
Hi, if you can find the input of cool air there a slider to shut it make little way to in cool air to keep cool down.
If there a possible thermostat make it lesser so that thew thermostat will on and off.
Jan 17, 2008 | KitchenAid Architect KBFA20ERSS Stainless...
Defrost thermostat connections
well what kind of fridge is it and you should not have to cut any wires at the back of the fridge as the defrost thermostat is in the freezer
Jan 09, 2008 | Refrigerators
Refrigerators Logo
188 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
