Question about RTO 30 Amp Dpdt 3 Position On-off-on Toggle Switch
I need a replacement toggle switch for a chipper/shredder.The 1/12 hp motor experiences frequent slow downs, depending on what is being chopped. Sometimes it even stops momentarily, I presume causing amperage spikes. It is a 125 volt motor. A regular 20 amp switch I tried lasted about a day. Hal.
My friend did a pretty good search for similar toggle
1) He found a 'wall-type' 30Amp DPDT at Global
2) He said he couldn't find others ... but the internet changes.
3) This switch could be mounted in a box that screws to side of chipper. Switch will work fine with 125V.
4) Radio shack and the automotive stores carry 5 amp versions of the DPDT, but they burn up like you said
5) Here is wiring schematic for switch schematic
6) Note: Wiring is different than automotive-type DPDT toggles where power connects to center pole and loads connect to outside poles
-Power on global DPDT connects to poles L1 and L2
-L1 switches to A1 & B1 ... while L2 switches to A2 & B2.
-Poles L1=>A1 and L2=>A2 turn on-and-off at same time
7) In a reverse of the schematic shown above, my friend is using the global switch on 30Amp water heater to switch voltages between 120 and 240 so we know switch can handle the amperage. schematic
Posted on Oct 01, 2010
Need parts for Lescha Zak 1800 Chipper/shredder
I have a used lescha zak 1800 chipper. It does not have the stand. I have the motor with the on/off switch and most of the chipper housing. IThe motor runs strong. Reply at asm3davis@yahoo.com.
Sep 02, 2012 | Yard Machines Electric Chipper/Shredder
Won't start.
depending on how old it is just get a new one they are not worth trying to get mended
Jul 23, 2010 | McCulloch Electric Chipper Shredder
Replace flails on 5.5 Yard Machine
Go to www.ordertree.com. The flailblade is p/n 719-0329, The shredder blade is p/n 942-0571, The chipper blade is p/n 981-0490.
Replace them you have to take casing off the unit to get to them.
Jan 22, 2010 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Have Troy Bilt 47279. Need Vacuum Snout.
i NEED A REPLACEMENT VACUUM SNOUT FOR A 1990 TROY BILT CHIPPER-VAC. THERE IS NO MODEL NUMBER FOR THAT YEAR, ONLY DESIGNATED AS "MODEL 5 HP".
Nov 06, 2009 | Troy Bilt Walk Behind...
Have a Lawn Machine with a 14.5 HP B&S motor. Will crank over and start with chock closed and trottle on slow. After starting if I add throttle over 1/2 it begins popping and dies. Can open chock then...
sounds more likley to be a dirty jet in the carb,
the brigs and straton engine never did have a very good carb fitted wip off the flote bole and clean out carb and all the jets,,,
Nov 05, 2009 | Yard Machines 24a 021h700 4.5 Horsepower...
I have a yard machinne 6.5hp chipper/shredder -
The blade(s) should have usually two bolts on them depending how many blades you have. Mine only has one blade held on with two bolts and that is only on the side that cuts the larger branches up to two inches in diameter and should be sharpened on a grinding wheel because it has a specific angle to it. The other side that chips smaller branches and twigs it a type of flailer, meaning pieces of metal just swinging around to mash up the sticks and do not need sharpening.
Oct 08, 2009 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Briggs & stratton chipper wont start
I believe it is part of the systen shut off. Should be connected to the motor (ground).
Hope this helps you
Kurt
Mar 18, 2009 | Yard Machines 24a 452g729 5.5 Hp Chipper...
RTO 30 Amp Dpdt 3 Position On-off-on Toggle Switch Logo
206 people viewed this question
Top RTO Electrical Supplies Experts
Ottoniel
Steve
Tom Chichester
Are you a RTO Electrical Supply Expert? Answer questions, earn points and help others
