Question about Dishwashers
I have a Dishlex DX203WK dishwasher and it is not heating the water as it is supposed to. I have removed the heating element and it measures 26ohms, so I suspect it is OK. What else could be wrong?
  • mortonkr Oct 01, 2010
    I am reasonably sure that the heater did not heat at all during the wash cycle! The manula says it should heat to around 50-60 degress C. Do you think the thermostat could be broken?
  • mortonkr Oct 02, 2010
    Thanks heaps for your thoroughness. Great service!
  • Dishwashers Master
  • 3,247 Answers
The thermostat could be faulty and therefore turning the heater off earlier then the desired cutoff.
Do you use cold water connection or hot? some dishwashers expect the inlet temperature to be within a range?
I will check out the specs for your model and come back to you later.
Posted on Oct 01, 2010
  • Sam Oct 01, 2010
    Sorry I didn't want to alarm you, but going through some of the internet postings on similar models most people seem to have fixed this problem by having to replace the control card.
    Now this is disturbing as you will have to see the investment in that versus buying a more reliable dishwasher.
    I would suggest you can verify this by tracing the heating element wires to the control card and checking if you get a voltage across the two wires during heating cycle. You will have to remove the door front cover to get there.
    Unfortunately these models are very unique to Australia and there is not enough open documentation to diagnose.
DISHLEX DX302 REPLACE HEATING ELEMENT
Remove the device and then restart again
Jan 25, 2014 | Dishwashers
Hi I have a Dishlex DX302. After an intense wash it leaves a film of scum / powder on the dishes and sometimes does not wash properly. I have tried using various soaps and also tried to use a dishwasher...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Mar 17, 2011 | Electrolux 24 in. EDW5505EPS Stainless...
Dishlex dx302 not drying dishes. Doesn't seem to be as hot as usual when opened immediately after finished. Steam not present.
Check your heating element..
How to Replace the Dishwasher Heating Element
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Mar 04, 2011 | Dishwashers
No drying cycle on the electrolux dishlex 302 any idea's
Dishwasher Problems The Heating Element not Working
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Nov 10, 2010 | Electrolux 18 in. ESL4114 Slim-Line...
What is the the test for the heat element
All you need to do is set your controls to heated dry cycle, and see if the interior heats up nice and warm. You can also check the element by touching it when it is not heated, and note how warm it is, and then when you run the heat cycle. Careful not to burn yourself.
Oct 15, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Dishlex 302 water not heating
My son fixed this problem with our DX302 dishwasher only this morning. Now works fine and hot. Found the solution on this site posted 11 august 2008 from dishwasher dishlex dx302wb no hot water. There are photos to help you. Take out the circuit board in the top of door and resolder the points on left hand side of green board there are 2 long solders and a half moon. The problem is at the top of the 2 long solder lines. Do not replace your element. There is a fault with the circuit boards on this model 302. I want to thank all the posters for helping me fix my no hot water problem.
Jun 26, 2009 | Electrolux 18 in. ESL4114 Slim-Line...
Dishlex Global Unable to remove heater element retaining screw
I have a simialar problem with the Dishlex 450 Global model, after searching for the heating element on line, I found a picture of the element (450 model), showing that the Stainless Steel screw is actually spot welded to the element bracket, hence you should be able to remove it by accessing a retaining nut from underneath the dishwasher....(turn power off first!)..
May 24, 2009 | Electrolux 18 in. ESL4114 Slim-Line...
Vulcan dishlex 750 eco taking alot longer to complete wash cycle.
How is the water flow into the machine. Are all your inline filters clean?
Apr 05, 2017 | Dishwashers
MDB7600AW water level
I'm not sure if it is suppose to fill above the heating element. The heating element may just be there to dry the dishes instead of heating the water. Try using a pitcher to fill the unit manually to above the heating element. If water drips out from below the kick plate then you know the water is not suppose to go that high.
Let’s say the unit is indeed under filling.
Check for a deformed shaft on the water level float. Remove the kick plate and look for where the shaft of the float touches a micro switch. Often the shaft is bent sideways and only engaging the micro switch indirectly. Straighten by hand for a temporary fix or reinforce the shaft with aluminum tape and sewing needle. Keep the retrofit light weight to avoid problems with water overflow.
Mar 11, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
Dishwashers Logo
241 people viewed this question
Top Dishwashers Experts
Owen Barnes
