Question about Genie Aire Heating & Cooling
The unit has been working fine but it is humid today and only runs less than 2 hours before the warning light comes on and I have to drain the tank in the back again. Is there any way to delay the warning light from coming on when it is humid?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 23 Answers
Not with out tampering, unless it has the ability to have a drain line ran off of it.
Posted on Oct 01, 2010
Unit will not run after about an hour until tank is drained -if a container is placed under the unit with plug out the unit will run like. An awful lot of water seems to come out of the unit.
Thing to remember about an Air Conditioner is it is transferring heat, so if you are in a hot humid enviroment you are going to condense more water, which will fill the tank up quicker.
If the tank has a spot to connect a hose to the tank, and you have a drain nearby, might be worth hooking a hose up.
a thought anyways on a fix
But the water is normal
Aug 21, 2013 | DeLonghi CF210 Portable Air Conditioner
Ac unit keeps reading fl or full. every 2-3 hours. auto clean button drains out about 1/4 a gallon of water and then stops draining. turn back on ac & repeat process every 2-3 hours. I have tried...
After reading over the Owner's Manual for your unit, I wonder if you are operating it in the Cool & Dry Mode. If that's the case, the dehumidifier is in operation, which would account for having to drain the unit every 2 to 3 hours. Ideally, the Cool and Dry Mode should only be operated for about an hour, when the unit is first started . Removing the humidity will allow the AC function to cool more effectively. But, it is not necessary for it to remain in Cool & Dry mode all the time. Because the AC itself unit will remove some humidity too.
Hope this helped you to troubleshoot and solve the issue of having to drain the unit every 2 to 3 hours
Jun 27, 2011 | LG LP1200DXR Portable Air Conditioner
Light comes on but dehumidifier does not work (i.e. does not extract water from the air).This is a DEC21 model
Is it running?
If the room tempature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defost over night.
Only specially made dehumidifers work below a room temo of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensot from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less. In that case your unit won't turn on.
Jan 02, 2010 | DeLonghi Dehumidifiers
Have Whirlpool AD50USS - unit ran for over 24 hours in DRY mode but collected no water. Should have been water in bucket as basement smells musty.
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 28, 2009 | Whirlpool Dehumidifiers
No water in Dehumidifier
1) low outside temp means low inside humidity
2) If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
Dec 20, 2009 | Dehumidifiers
I have an ebac dehumidifier i think 6000 model and it appears to work fine. the fan runs ok the compressor seems to kick in ok but the tank will not fill. i had it on in my room for approx 30 mins and...
Dec 19, 2009 | Ebac HD880 Dehumidifier
UNIT RUNS AN EXCESSIVE AMOUNT OF TIME AND AIR IS COOL NOT COLD COMING OUT OF VENTS CARRIER 58DLA / 58DLX CENTRAL AC FAN AND COMPRESSOR ARE OPERATING BLOWER IS WORKING UNIT IS TURNED ON TO AC TEMP SET AT 76...
DOES THE HOUSE FEEL DRIER IF IT IS 80 OUTSIDE WITH ALOT OF HUMIDITY THE UNIT WILL RUN FOR A LONG TIME TO REMOVE THE MOISTURE(HUMIDITY) OUT OF THE HOUSE BEFORE TEMP DROPS DRAMATICALLY IS THERE WATER COMING OUT OF THE DRAIN PIPE OUTSIDE
May 03, 2009 | Carrier Heating & Cooling
Amana APO95R Turning Off/Tank Light (!) On and Off
There are only two items that will shut it down after it is set to run. The bucket full which you took care of and low humidity in the area it is being operated in. Low humidity would not constitute a reason for returning it.
Jun 15, 2008 | Amana Haier AP095R Air Conditioner
A lot of H2O and Alarm
You may have a drain sensor problem. If your machanical you can try to tie the sensor together to see if this allows the unit to run, if so, replace the sensor.
Aug 22, 2007 | Windchaser PAC9 Air Conditioner
Heating & Cooling Logo
133 people viewed this question
Top Genie Aire Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Genie Aire Heating and Cooling Expert? Answer questions, earn points and help others
