Removing close caption on television
I have a phillips television model #27pt543s37a and I'm unable to remove or change the close caption off.
  • Anonymous Aug 14, 2008
    I am unable to get rid of the closed caption on my set, it's very aggrivating to see all this print.
    Called my cable people and they told me to figure it out on my remote. There is no remove button.
  • daveinenglan Nov 01, 2008
    I have the same tv and same problem.
I was able to obtain a users manual online for free but I need to have a remote to remove the closed caption. Thanks for the response but I don't need to apply for an assistant plan.
Posted on May 26, 2008
How do i remove the caption from screen on a konka tv?
On Time Warner Cable box change the Closed Caption to T3. This will remove the closed caption box when you change channels.
Sep 18, 2009 | Televison & Video
My tv has a black square in the middle of the screen.how do i remove it
thats your closed captioning. on your remote, there should be a button on your remote to remove the closed captioning or to change the captioning type. Look for the "C.C." Button. press it. the closed captioning type will change. press again and again untill there is no text or it says "off or None"...
Hope that helped.
Aug 14, 2009 | JVC AV-32D305 32" TV
Philips 27 inch TV - Model # 27PT543S37A - Keeps going off!
if you have back ground of tv repair, remove back cover but you need tools and tester, check heater line from crt ckt board going to horizontal section.
Apr 03, 2009 | Philips Magnavox TP3285C 32" TV
How to remove closed caption from JVC TV without original remote
how can i get rid of the closed caption on my magnavox tv without the original remote
Mar 19, 2009 | JVC C-20810 TV
Unable to remove the closed caption through the remote control (Haier) 42 inch flat screen tv. Went through the function and selected 'No' to Closed Caption, but it does not remove it. Thanks, Sandy
I dont know what model you have i see two on there website. i read manual for one of the 42 inch lcd tvs and i do see where you confirmed you said off to closed caption mode am i correct? Ok try this turn the closed caption on and exit menu. now shut off tv and turn it back on. now go into menu and turn closed caption mode to off now and exit menu and see if that helps. ok i hope this helps ....oh i forgot to mention make sure that you didnt enable the closed captioning on your cable box remote. Just might want to check with that. It might not be your tv at all it could be the cable boxes closed captioning service. I hope some of this helps if not see if there is a factory reset in the menu.
Feb 20, 2009 | Haier Televison & Video
Unable to program universal remote with phillips TV.
Todd, there is a web site you can go to. replacement remotes.com Use the top site when it comes up. At the top type in your remote model number. You can purchase a manual or maybe call the # I found the item# you want is 61369 for 3.95 Sorry this is all i could find. good luck
Feb 12, 2009 | RCA Universal Remote Control
Removing closed captioning
Worked it out. The Direct TV remote has a yellow button and that did it. I don't know whether I had inadvertently programmed it that way but problem gone.
Thanks.
Jan 18, 2009 | Philips 42PF9631D 42 in. Plasma Television
Closed caption activiting on everytime tv is turned on
If you have the Suddenlink remote and the DVR box you can turn captions on or off by accessing a technical menu. To do this, press POWER and Menu buttons together (menu 2 times) to bring up a special menu. Select Closed Captions. On the popup menu select closed captions and using Select button change to OFF or ON as you wish. The trick is to get the menu to come up. Timing of pressing the two buttons is frustrating and it may take a few times befotre you get the special menu.
Oct 02, 2007 | Televison & Video
Closed Captioned
Assuming whatever your TV receiving from has close caption. (Not all TV channel has close caption) Solution 1) Get a new universal remote that support your model and has close caption button. Once you program in the code for your TV model and it works then all button should also programmed including th close caption button. Solution 2) Search online for the owner manual and read see how to turn it on using buttons on TV (if possible). Solution 3) Get new TV with close caption. (If you have an old old TV with bad and huge pixels then this solution is the best. Your eyes will thank you.)
Aug 25, 2006 | Panasonic CT-32G11 32" TV
Televison & Video Logo
511 people viewed this question
Top Televison & Video Experts
