Question about Kirby G4 Bagged Upright Vacuum
Kirby G4 Hi, Reddev. Could you advise the determination and self fix for the screeching? The fan looks fine...believe it is the barrings. Thanks, shautau
    President:
  • 1,673 Answers
The bearings, there are 2 of them can be replaced. You will have to take the motor apart so you can get the armature out, one bearing is in the bearing plate, the other is on the end of the armature. If you do this, be sure to mark where each wire goes into the switch. If you mix up the 2 coming from the motor, it will run backwards.
Posted on May 25, 2008
How and where do find the switch to activate self propel unit in G4 series kirby
To place the kirby G4 into gear - out of Neutral - just press down with your foot, the Gray & Green lever that is labeled N on the left side of the lever, which is gray, and D on the Right side of the lever which is Green (probably for GO). It is located directly below the Power button.
Good Luck
See Pic...
Feb 03, 2014 | Kirby Generation 3 Bagged Upright Vacuum
I am looking for a service manual for my Kirby G4D vacumn.The number on the vacumn is 7941006690. Sounds like there is something caught in the motor or fan . I am not sure how to take the vacumn apart...
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Kirby model by clicking the link below.
http://kirbywhq.powweb.com/manuals/G4/8D4538EC00E93846200D614F7C499B59/G4%20Manual.pdf
You can purchase a wide variety of high quality Kirby replacement parts for your Kirby vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Kirby
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Aug 17, 2011 | Kirby G4 Bagged Upright Vacuum
Looking for a Kirby G4 impeller?
Hi There. Here's the Impeller Blad, or Fan assembly for your Kirby G4. Hope this helped you.
Please leave feedback or rate the repair helpful if this answered your question, thanks!
Kirby Impeller Blad Assembly
Thanks so much,
Chris Jones
GoVacuum.com
Dec 29, 2010 | Kirby G4 Bagged Upright Vacuum
I need a manuel to replace a broken fan on my g4 kriby
We have actually recorded a very informative do it your self video on how to replace the fan on a Kirby Generation upright.
The video is a two part video, but this explains step by step how to remove the old fan, and put the new one on.
If you need to purchase a new fan assembly, here's a link to the Fan assembly for your Kirby G4. Unfortunately you may only purchase them as a complete assembly:
Genuine Kirby Vacuum Fan. Kirby Part # 119096S
Here's the videos showing how to replace the fan:
Part 1:
Part 2:
Hopefully this helps you with your problem! If this did help, please be so kind and rate the repair, or leave feedback for me. This is very appreciated by the Fixya community when someone is able to answer your question, and assures that experts continue to answer free questions, instead of just the premium paid questions.
Thanks again!
Chris Jones
GoVacuum.com
May 15, 2010 | Kirby G4 Bagged Upright Vacuum
Kirby G4 motor is very loud. It has suction but seams to be a lot louder than when we bought it in 1996.
Hi There,
Most likely it's just the fan that is making the noise rather then the motor. The way the Kirby vacuums are designed, anything hard that's vacuumed up such a coin, or other hard things can break the fan.
In order to check and see if it's your fan, remove the front part of the vacuum that contains the roller brush and belt. If you're not sure how to do this, here's a video that shows you how to change the belt, but will also explain how to get the front bell shaped housing off:
Once you have the front cover off, look inside the vacuum directly behind the motor shaft. You will be able to inspect the fan here. Turn the motor shaft which also turns the fan, and see if there's any cracks, or if the fan blade is broken. I think most likely you'll see the fan damaged somehow.
Here's a video repair that we've put together that explains step by step on how to replace the suction fan on your Kirby:
Part 2:
Hopefully this helped you fix your Kirby. Please be so kind and rate the repair, or leave feedback if this was helpful to you. Thanks so much,
Chris Jones
GoVacuum.com
May 02, 2010 | Kirby G4 Bagged Upright Vacuum
I've owned my Kirby G4 for 15 years and never had to touch it for maintenance. Should I ever get it overhauled or tuned up?
Kirby recommends getting it serviced yearly but if you are mechanically inclined you can service it yourself. the biggest thing is cleaning and blowing all the dust out of the motor and inside compartment. also check your motor fan for chips nicks, and stress cracks around the center. Inspect the bearings and motor carbon brushes for wear and noise. and put some 3 in 1 oil on the top handle slide assy on top of the motor. do not disassemble this unit there are many way bearings inside and if its not reassembled just right it will throw off your self propelled unit
Jan 03, 2010 | Kirby G4 Bagged Upright Vacuum
Broken Lexan fan needs to be replaced
It is similar to the G4 but without the tech drive so is easier.
Apr 30, 2009 | Kirby Heritage II Vacuum
Owners manual
Replacing old fan assembly
Sep 12, 2008 | Kirby G4 Bagged Upright Vacuum
Fan kit kirby g4 vacuum cleaner
I'm assuming you mean the fan impeller and not the fan that cools the motor...
you can find detailed instructions at this site
http://reviews.ebay.com/KIRBY-VACUUM-REPAIR-HOW-TO-REPLACE-THE-FAN-IMPELLER_W0QQugidZ10000000003711302?ssPageName=BUYGD:CAT:-1:LISTINGS:3
hope this helps!
Jan 13, 2008 | Kirby G4 Bagged Upright Vacuum
Kirby G4 Bagged Upright Vacuum Logo
101 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
