Question about Brother ML-300 Typewriter
HAVE A BROTHER ML-300 "DISPLAY" TYPEWRITER.. COUPLE HANDS ON THE DAISYWHEEL ARE BENT, NEED A NEW ONE.. NOT SURE IF I NEED THE 402 OR 405.. WHAT'S THE DIFFERNCE BETWEEN THE 2...?
  • Brother Master
  • 3,594 Answers
The 402 is a prestiege 10/12 pitch the 405 is script12.
The most common is 411 Brougam 10.
DickyO
Posted on Oct 04, 2010
Cannot get symbols to display
" Make sure your keyboard setting is correct. If using standard 411 daisywheel, the keyboard setting should be at KB I. It is also possibleyour daisywheel needs resetting. Turn the machine off, wait ten seconds and turn back on. If the wrong characters continue printing, change to a new daisywheel. If problem persists contact your Authorized Brother Service Center. You may locate your authorized Brother service center bycontacting us as 1-800-284-4357 or visiting our website.
http://www.brother-usa.com/service/default.aspx"
Mar 15, 2013 | Brother EM-630 Typewriter
When i install the new daisy wheel i cant get it set to type the correct letters
First, be sure you are using a Brother compatible daisywheel. Some other manufactures' daisywheels "look" the same but the charters are in different order, so they will not function properly.
After changing the daisywheel you need to d a reset. Hold down CODE and press "Q" the carriage will do a little dance and your machine should be good to go!
Dec 22, 2010 | Brother GX-6750 Typewriter
When I type it uses different letters
You will need to replace the daisywheel.
May 24, 2010 | Brother ML-300 Typewriter
How do I set left margin for brother model ML-300
Go to brother.com, click on support you will find a downloadable manual there.
DickyO
May 11, 2010 | Brother ML-300 Typewriter
Types funny symbols instead of the number I
The typewriter will print the incorrect letter, or the face of the hammer if it does not spin properly to the correct position. 1. Turn the machine offf for 15 seconds and turn ON, or Depress MODE RESET(the Q key). This will rehome the Daisywheel.I If it prints correctly for awhile then looses its' position, check for ribbon or correction tape interference with Daisywheel movement. If it does not print correctly as soon as you start typing, remove the Daisywheel and inspect the spokes to see if any are bent. Reinstall the Daisywheel and power ON. If the Daisywheel has a bent spoke or two, you can try to straighten them, howvever the cause of bent spokes is a concern. While typing, carefully watch the print hammer movement. It should always return to the same position and not move towards the paper until a letter is pressed. If it does not come to rest properly, the hammer is not in proper timing and may enter the Daisywheel while it is spinning to the character, thus causing damage to the Daisywheel or causing it to lose homing. .The hammer cams would require adjustment ore replacement. If bent spokes is a persistent problem, make sure to get the hammer problem repaired before buying a new daisywhel.
Dec 29, 2009 | Brother SX-4000 Typewriter
Brother gx-6750 is typing incorrect numbers and letters. how do i fix?
Removed and reinstall the Daisywheel. Inspect the ribbon and lift-off tape to eliminate interfering with Daisywheel spinning. Make certain the daisywheel has no bent spokes. Type slowly while carefully watching the hammer come to rest after printing. If you see the hammer moving towards the paper after a print cycle, the hammer is probably causing the Daisywheel to lose homing and will need to retimed or have the hammer cams assembly replaced.
Dec 27, 2009 | Brother GX-6750 Typewriter
How do i type a percent sign O/O
The keyboard of the typewriter differs from country to country to adjust to special characters used in its language.
In the standard US keyboard the percent sign is in number 5 key. To insert the percent symbol you would use right or left [SHIFT] + number 5 key , provided you are using the standard daisywheel,
Download the Brother ML-300 Typewritter User's Manual to learn more
Nov 24, 2009 | Brother ML-300 Typewriter
Wrong letters typing
it sounds like you were using a non-brother correction tape,one that was too sticky and consequently too "slow" and during the correction sequence the fingers of the daisy-wheel got entangled with the tape. Make sure that the correction tape is of a "non-sticky" nature and then take off the correction and printing tapes. That way you will see better how the daisy-wheel is fitted . I will assume that you have an instruction book to show how this is done. before fitting the daisy wheel examine the fingers to see that none are bent or crossed over each other. If this is the case it is better to buy another one. bring your typewriter to the shop if this is the case and they will possibly re-fit the wheel for you. good luck.....
Mar 19, 2008 | Brother ML-300 Typewriter
Brother ML-300 Typewriter Logo
49 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
