Question about American Standard Heating & Cooling
The air conditioner fan comes on but no air is coming out of the vents - filters are clean
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 141 Answers
Check the evaporator coil for dust and dirt if its dirty then use a wire brush and remove the dust or dirt use the brush lightlt and dont bend the fins flat while doing this
Posted on Oct 01, 2010
Goodman central air conditioning. Little air is coming from the vents in the house and the air that is coming out isnt very cold
have the central unit blower/fan cleaned as they block up from dust and other particles so that they eventually look like logs and do not move air like they should. Have the unit gas pressure tested for correct amount of gas
Jun 17, 2013 | Heating & Cooling
Fan runs but no cool air or any air coming thru ducts
Be sure the "fan running" noise you hear is actually the fan and not just the refrigeration pump. The unit would still make a running noise but the fan may not be turning.
Check to be sure the filter is clean and that all vents are open.
Jul 19, 2010 | Dometic Rooftop RV Air Conditioner
1.5 ton ac. It is getting cold near the outlet but cold air is not blowing out. Instead pieces of ice are sometimes coming out. How to troubleshoot?
Is the fan running? If the fan is running you should check your filter. If it isn't running then you should check the capacitor for the fan and the fan motor. Also make sure the evaporator coil is clean. If all of this is good then get the refrigerant charge checked.
Jun 06, 2010 | Samsung AW0503B Air Conditioner
AC Not coming out of vents enought to cool
First thing you should do is check/change your air filters and check the indoor coil and make sure they are clean. If that doesn't make a difference then check your fan and see if you think it is running fast enough. A weak capacitor can cause a fan to run slower. Also check the fan and make sure it is clean. Let me know if you need more help.
Jun 02, 2010 | Heating & Cooling
I have an electric furnace...there is no air at all coming from most of the vents located on the out walls and very little air coming out of the vents situated in the center of the house. It is cold in the...
Dirty filters, dirty coils, collapsed duct work, or a fan motor with the blades covered in dirt, dust, mold etc reducingthe airflow.
All of the above could cause your symptoms, clean/have cleaned and check those issues.
Nov 06, 2009 | Heating & Cooling
Air not circulating through vents
is the unit running outside? did you check the breaker? Ruud units often times will have a reset bitton on the outside unit to the left of where the freon lines connect. It is a high pressure switch if it comes on when reset make sure the coil is clean and the fan runs(outside)
Sep 20, 2009 | Ruud UBHC Air Conditioner
Ruud a/c heating system problem
Get service tech to check charge. Clean condensor check filters first.
Jun 12, 2009 | Heating & Cooling
AC Problem
possibly faulty fan or fan relay also check that 24 v are coming out of the transformer
Sep 03, 2008 | Carrier 38CKC036 Air Conditioner
Kenmore 73259 wall unit a/c blowing out black particles
remove the filter aand run it and see what happens, the filter still could be causing the issue
Apr 25, 2008 | Kenmore 73259 Air Conditioner
Heating & Cooling Logo
46 people viewed this question
Top American Standard Heating & Cooling Experts
Tim Whalen
Mack Baxter
Pete Norton
Are you an American Standard Heating and Cooling Expert? Answer questions, earn points and help others
