Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Dryer is a Fridgidaire Home Gallery...and the dryer tumbles, and heats in beginning of cycle but the heat will not continue to heat...tumbles normally. The vents have recently been cleaned.
  • Frigidaire Master
  • 2,180 Answers
If it's gas you have bad gas coils,if not blow out the vent line with a leaf blower if it's long from the back of dryer to the outside vent,also make sure the outside vent isn't blocked,then remove the lint filter and then remove the duct that it slides into and clean that out,let me know what you find,this came in under a frigerator,ha kinda messed me up
Posted on Sep 30, 2010
Hi. My tdvcw bush dryer is turning but not heating up. The temperature light is flashing. There is no reset button on back of dryer. I have a child and need clothes dried. Thanks in advance
My tumble dryer is not heating up! - 24'7 Home Rescue
https://www.247homerescue.co.uk/my-tumble-dryer-is-not-heating-up-2/
My dishwasher won't fill with water! ... My TV will not turn on! ... If your tumble dryerdrum is not heating up, but the drum is spinning normally, then you might be ...
Tumble dryer not heating - White Goods Help
Jan 25, 2016 | Dryers
My dryer works fine...heats tumbles the timer just doesnt advance once it starts therefore the dryer wont turn off on its own
the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Jul 11, 2014 | Whirlpool LEB6200 Electric Dryer
Fridgidaire high capacity stackable FEX831CSO/ washer/dryer no heat
If dryer tumbles but won't dry usually means the heating element has broke in two. It can also be a thermostat usually installed near outlet of blower assembly or a limit switch installed in element heater assembly.
Jun 16, 2012 | Washing Machines
Dryer won't heat up during dry cycle
Make sure you check these to fix the problem.
  • Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
  • Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
  • A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Thank you
Jun 09, 2010 | GE DBSR453EBWW Electric Dryer
Dryer will not stop running
Your machine may have a feature called wrinkle guard or wrinkle shield, which basically keeps tumbling the clothes without heat to prevent wrinkles from setting in. Turn that feature off and see if that does the trick.
May 15, 2010 | Frigidaire Electric Dryer
Tumble dryer will not dry
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Aug 19, 2009 | Dryers
Dryer not heating, help
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
May 30, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryer not heating
  • There are two house circuits/fuses in an electric dryer's circuit.
    If one of them is tripped/blown, the drum may turn, but the heater will not operate. Reset the circuit breaker or replace the house fuse.
  • Outlet wired incorrectly.
    Have a qualified electrician verify that the supply voltage is correct.
  • Gas supply valve to a gas dryer is not open.
    Open the gas supply valve. See Installation Instructions for details.
  • LP gas supply tank is empty or there has been a utility interruption of natural gas.
    Refill or replace the LP tank. Call your natural gas utility company.
  • Dryer does not have enough air supply to support the gas burner.
    The dryer needs space around it for proper ventilation. Do not stack or place laundry or throw rugs against the front or back of the dryer. See Installation Instructions for details about installing a dryer in a closet or alcove.
  • Incorrect cycle or temperature has been selected.
    If the Air Fluff cycle or temperature is selected, the dryer will tumble without heat. Each cycle ends with a Cool Down period during which the load tumbles without heat. Check the location of the indicator on the Cycle Selector knob.
Jan 08, 2009 | Frigidaire Dryers
Estate gas dryer model#TGDX640JQ2 running no heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Heating element
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
Oct 26, 2008 | Whirlpool LGV4634JQ Gas Dryer
Broken heater during the dryer cycle
Heating element
Thermal fuse
Wiring
Feb 17, 2008 | Equator EZ 3710 CEE / W Ventless...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
