Question about Frigidaire Microwave Ovens
My Freezer Model No. FFU14F5HWB door ajar alarm Keeps going off when the door is seal closed tight
I have to slam the door very hard for it to close correctly what would cause this problem?
Incorrectly adjusted door catch. They have movement on them to allow a tight seal due to the microwave capability.
I just found the specs and instructions on it.
Whirlpool Gold 2 0 cu ft Velos SpeedCook Oven
Mar 09, 2016 | Whirlpool Gold 2.0 cu. ft. Velos SpeedCook...
How do I fix a microwave that counts down and does not turn on?
Appears to need a replacement door switch, might just be cheaper to get a new microwave if it is old.
They are made to close tightly and sealed so you are not exposed to microwaves. Not sure how safe you are overriding the microwave safety feature standing nest to it holding door.
Nov 30, 2015 | Microwave Ovens
Freezer has ice in it and the fridge isn't cooling
Hello Cass, being that you have a top mount, the vent in the freezer is what circulates air down to the Fresh Food section, making it cool. Here are a few simple troubleshooting tips that may help you resolve this issue:
First check clearances around your refrigerator. There must be adequate space around a refrigerator with a static condenser so that air can circulate properly. Proper clearances include 1" at the back and 3" on top of the refrigerator.
Examine your doors. If the doors have been opened too often or for too long, this may have allowed warm air to enter the refrigerator. Make sure to shut the door completely and be sure not to keep the door open for too long. Even leaving a door slightly open can allow too much warm air intake. Make sure refrigerator is level and keep food and containers from blocking the door closing.
Check the door seal. You do this by placing a dollar bill between the body of the refrigerator or freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet, double check to see if the door is being blocked by anything that may be stopping it from closing. If nothing is stopping the door from closing then replace the gasket.
Check to see if the condenser is dirty. A dirty condenser cannot release heat efficiently into the surrounding air. Cleaning the condenser may be necessary, more if you have animals in the house. If you have condenser coils, they should be wiped occasionally with a damp cloth to remove accumulated dust. The condenser coils should be wiped occasionally with a damp cloth to remove accumulated dust.
Check for any obstructions to the vent to ensure proper air flow. If the vent is blocked, the air in the refrigerator will not get cool.
I recommend to double check the freezer control. If the freezer control is set too warm, set freezer control to a colder setting and allow 24 hours for temperature to stabilize.
If these assessment measures prove to be ineffective, I would strongly suggest contacting an authorized service technician who would be better able to assist you in the diagnosis and repair of your unit. You can often locate an experienced technician in your area by going to the manufacturer website.
Aug 18, 2013 | Electrolux Microwave Ovens
E305075FPSA HighSpeed Eletrolux the door appears to not be closing tight.
No! this not normal, I'am concerned about microwave leakage, and a 1/8 gap is to much, should be tight against the seal "major safety factor" the door is out of alignment or the bottom latch is not secure "to much play" I recommend a pro simply because he needs test for leakage when the door is properly fixed.
Mar 22, 2012 | Electrolux ICON Microwave Combination Oven
I have a Frigidaire freezer , M# GLFU1767FW4 S# WB70936901. The computer keeps on beeping, even when the door is closed, the temperature is fine. I already changed the computer and the door...
Hi, the door switch might have had liquid poured on it freezing it, or the switch itself is bad.
Unplug your refrigerator from the ac outlet, and 0pen the door for approx. 5 minutes. Then plug it again, after you hear the beeping close the door.
Nov 24, 2010 | Microwave Ovens
We have a Haier upright freezer and i can not get the alarm to go off
the reason there is no fan on the outside is because the outer shell of the unit is the condenser. the unit does it have a fan on the inside? also how does that gfasaket on the outside of the door look like? let me lknow
I would leave the door closed unplug it for half an hour. In that half hour go to sears.com customer service, manuals and guides and type in the full model number from the freezer. You should find an owners manual there to print or just browse for an answer. Good Luck.
Jul 06, 2010 | Microwave Ovens
Oven keeps shutting off, says close door or says push start. When you push start again or restart only runs for few seconds and then shuts off again
1)Make sure there is a clearance all round the machine so that there is a good airflow. The sensor is picking up a lack of circulation or heat factor.
2) Chdeck the door switch, it may well not be closing correctly. when the door is closed and prior to hitting start,\; pull the door gently to see how much movement or play is in it. The door should be tight and have almost zero movement. Look at t both sides of the door lock to ensure no debris is preventing it from closing correctly, and the latch itselof is not broken!
Thanks for using FIXYA
Oct 13, 2009 | Microwave Ovens
Emerson MW8119SB microwave wont stop running with door closed
It should have a one-year warranty on parts and labor.
I'd call Emerson at 1-800-695-0098 to find your nearest authorized service center to have it fixed free.
It's probably a bad door switch or door switch mount.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 22, 2008 | Emerson MW8778 Microwave Oven
Microwave Ovens Logo
61 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
