Question about Kicker (ZX750.1) Car Audio Amplifier
My kicker amp goes in and out of protection, like when i turn the car on it turns on green then just goes red then goes to green again and goes back to red. I was bumping for awhile and just started hear clicking in my speakers so i unplugged them and the amp was just going back and forth into protection mode. Can anyone help me with this problem?
    Problem Solver:
  • 6 Answers
First of all turn your volume all the way down and c what it does and if you turn it up to say 15 and it goes in pro mode turn it back to 13 and see if it does that and if it doesnt it means your amp is clipping. Make sure youre not overloading your amp by running it in to low of a ohm.
Posted on Nov 01, 2012
    Scholar:
  • 99 Answers
Thankyou for the detailed fault description..it really helps!
sounds like there is one of these 3 things wrong:
1. leaky or partially blown mosfets on ouput power stage of amplifier are leaking DC onto speaker output causing amp to go into protect..this explains any banging or clicking herd.
2. There has been damage to the internal SMPS and is going into protect because of an internal rail over-voltage/under-voltage.
or 3. you have a shorted speaker lead or sub that is bringing the amplifiers load down to less than 2 ohms..buy or obtain a multimeter and have a poke around and check all your speaker leads on the ohm setting anything lower than 1.6 ohms and you have a short...also make sure that you have correctly loaded amplifier to..alot of begginer audio enthusiats overlook this important step and cook amplifiers!!
remeber impendance ratings, have a look on google, search "impendance formulas" and study up if your unsure!
hope this helps,ben
Posted on Jan 04, 2011
Kicker amp powers no audio all connections made properly
Is this the first time installing it or have you had it a while and it suddenly stopped playing ?
Aug 07, 2011 | Kicker Car Audio & Video
I have a kicker 500.2 red protection light is on and red light on top of amp flashes every couple seconds. Have checked all connections and other amp in truck works good. I bought two of these amps and...
Disconnect all the wires except the three main power wires, ground, 12v battery and remote. Now, turn on your radio, if the protect light is still on then there's an internal short in the amp. If the light turns green, then there's a short in either the auxiliary cables or the speaker outs. If it turns green, then troubleshoot the other wires that plug into the amp by connecting them one at a time until the protect light comes on, which will tell you that there's a problem with that speaker/aux wire.
Jul 25, 2011 | Kicker KX500.2 Car Audio Amplifier
Amp runs but then will just turn off and red light comes on
you may have fried the amp pre outs in the head deck, try the amps on another stereo
Jun 01, 2009 | Lightning Audio Bolt B2.150.2 Car Audio...
Green light turns red on hard notes with kicker 750 mono amp
First off, never, ever replace a blown fuse with a bigger one (especially one that is almost twice as big) unless it's an absolute emergency. Most of the time, the reason a fuse blows is because of a problem with the device (in this case, the amp). By installing a larger fuse, there's a very good chance the problem will become permanent (i.e. busted amp).
The amp could be going into an overcurrent mode when the bass hits and power cycling itself to try and reset the problem. If this is the case, take it to a local electronics repair shop and see what they can do.
It's also possible the input voltage to the amp is dropping too low during the bass hit, making the amp restart. Try putting a 1.0F or higher capacitor on the battery to buffer the power during the bass hits.
Mar 16, 2009 | Kicker (ZX750.1) Car Audio Amplifier
Kicker amo in my old vette
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage drops below ~11 volts, you need to check the wiring feeding whichever line is dropping too low when the amp goes into protect.
If the voltage is OK, you need to check the speaker wiring and the speaker(s). Try it with a known good speaker if possible to see if the amp works normally.
Nov 07, 2008 | Kicker KX600.1 Car Audio Amplifier
Goes into protection mode for no reason
if the amp is powering on the sub and playing and then turns in to protect mode it could be the amp is getting hot and its kicking into protect so you wont fry the amp
May 06, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
IX704 kicker
There's a pretty good chance that your speaker load is too much or else your power coming in is not sufficiant. Be sure to check BOTH the battery and ground connections to be sure they are supplying enough power. If your speaker load is too much then correct that at once before you fry your amp. Good luck.
Jun 06, 2007 | Kicker IX704 Car Audio Amplifier
Car Audio & Video Logo
277 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
