Question about Kodak EasyShare DX4530 Digital Camera
I just inserted a 8 MB card in and the camera says "Memory card needs formatting" I click continue, then it says "Formatting will delete everything on the memory card", no problem, it's a new card so I click on continue then it says "formatting" then I get the message that says "Memory card cannot be read, insert another card" What's the matter?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
8MB or 8GB? If it's actually an 8MB card, you'll be able to put maybe two or three pictures on it, so I'll assume it's an 8GB card.
The DX4530 is designed to work with SD cards. Your 8GB card is actually an SDHC card. While SDHC cards will fit into SD devices, there are electronic difference that prevent them from working there. SD cards will work in SDHC devices but not the other way around.
You need to use SD cards, 2GB and smaller.
Posted on Sep 30, 2010
Testimonial: "You are correct k_akima, I my new card is a SDHC 8GB and will not work. I did not know there were different kinds of cards. Thanks!"
Thanks to k_akima I got the same issue. I need to return the 8GB SDHC card to the store. Thank you again
Posted on Feb 23, 2013
Memory card requires formatting, press continue then it states that it will delete everything on memory card,then it does not format, it tells you that you need to format memory card. press cancel and...
Hope you have this figure out if not here goes. Sounds as if the camera is caught in a feed back loop. As long as you have down loaded and saved your images on the computer go ahead and format the card. When it says delete everything on the card select OK and click the start button everyone is happy again. By the way all new card and card after doenloading to the computer should be formatted in the camera. Never format in the computer and deleting images one by one is just a great way to totally mess up a memory card's mind. Format, Format
Dec 09, 2010 | Kodak EasyShare Z7590 Digital Camera
After inserting the new SanDisk, SDHC Card, 8GB the camera prompts "Memory card requires formatting", press continue; warms that formatting will delete everything on memory card; pres continue;...
First thing; check owner's manual and USA distributor, make absolutely sure that this camera is able to read/write to a 8GB card!
If so, put that card into your computer, directly into appropriate slot or through a "reader" and the USB port. If computer runs Windows, access My Computer, click on external memory device, and RIGHT CLICK. You will get a box which offers to format the card. You can rename the card at the same time. The computer's format routine is stronger that the one in the camera. If problem still happens, consult distributor. May be fixable with a cable from camera to USB port, you download new software from distributor. Follow their instructions EXACTLY.
May 14, 2010 | Kodak EasyShare Z650 Digital Camera
I just received a SanDisk, ElitePro, 32GB memory chip for my Kodak C875 camera. Upon chip insertion LCD says, "disc requires formatting", "continue", "formatting will delete everything on memory card",...
This camera's software will accomidate up to 2 GB SD card, or up to 8 GB SDHC card. Check your camera manufacturer's Help Page to learn the card capacity of your camera
Dec 25, 2009 | Kodak Cameras
Kodak EasyShare DX4530 Digital Camera Digital Camera Cannot format memory card After I inserted new card, it says that memory card required formatting....I hit Continue...it warn me that formatting will...
If your using more than 2GB of SD card or if yous using the SDHC card it will not format the Memory card.
Try to used the recommended Memory card 2GB or 1GB SD card It will reformat your card. Too Much or too High SD card is not compatible on DX camera series
Nov 08, 2009 | Kodak EasyShare DX4530 Digital Camera
Memory Card
Hi...
The way to format is just follow this, you just plug you camera to the computer then turn it on, after that, the camera will detected, you open my computer, you can see the removable disk, just right click then format then check quick, then ok
Good luck !!!
Regards
PCmania
Jul 06, 2009 | Kodak EasyShare C875 Digital Camera
Hi Mr.
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Dec 30, 2008 | Kodak EasyShare DX4530 Digital Camera
    My Kodak EasyShare C315 needs formatting.
    For all the camera users whose cameras won't format...they can't accept all the info on a 2 gb memory card... install a 1 gb card...worked like a charm for me! C315 and others were made before the 2 gb card. Only 1 gb cards work in the older cameras.
    Tami
    Dec 27, 2008 | Holga Flash, 120 Medium Format Camera...
    Preformat : By Fix-shad0w
    #1
    #2
    #3
    #4
    #5
    #6
    With A USB , CELLPHONE , Camera The SameThing
    Nov 22, 2008 | Kodak EasyShare C743 Digital Camera
    Cards not working with camera
    If you used the SD/MMC memory card in another brand of camera or device, you may need to format the card in your new EasyShare digital camera. (You may have noticed a "Memory Card Needs Formatting" message when you inserted the card.) CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card. To format the SD/MMC memory card or the internal memory of the camera: Transfer images to the computer before formatting the memory card. Press the camera Menu button. Highlight SETUP MENU, and then press the OK button. Highlight FORMAT, and then press the OK button. Highlight an option - MEMORY CARD (deletes everything on the card), CANCEL (exits without formatting), or INTERNAL MEMORY (deletes everything in internal memory). Press the OK button. Highlight Continue, and then press the OK button. Wait until formatting is finished before removing the card. When formatting is complete, the SETUP MENU is displayed. Press the Menu button to exit the menu.
    Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
    Kodak EasyShare DX4530 Digital Camera Logo
    467 people viewed this question
    Top Kodak Cameras Experts
    Tony
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
