Question about Panasonic PT-47WX53 47" Rear Projection HDTV
The TV was working fine and it cut off. I turned it back on and it will stay on for 2-3 seconds and cut back off. The red button seems to blink once.
    Problem Solver:
  • 10 Answers
Consider looking at your manual for replacing the projection bulb. They don't last indefinitely and depending on how many hours of use yours gets, the bulb may fail when it heats up. My Sony projection tV had very similar sysmptoms and no indication of anything else wrong, If your tV is a few years old and gets good use I would at least think about it. My Sony was easily user serviceble and cost less than it would have for a service call.
Posted on Sep 30, 2010
Four digit code for fios remote and hannspree tv
found a manual:
code: 087
1. Turn on your TV and the
FiOS STB. Make sure you
can see live television.
2. Locate the 3-digit code for
your TV brand in the list
below and circle the correct
code.
If your TV brand is not listed,
codes for additional TV
brands are listed at the back
of this manual.
3. Once you locate the brand
code, press and hold the
<OK> and keys
together. The RED LED on
the remote control will blink
twice and then stay on.
4. Enter the 3-digit TV code
for your TV brand using the
number pad. The RED
LED will blink twice and
then stay on.
5. Press and release the
<CH +> button repeatedly
until the TV turns off. You
can also "back up" by
pressing the <CH -> button.
*Please note - some TVs may
respond slower than others.
Please allow 1 second
between button presses.
6. Test that remote control is
programmed for your TV
a. Turn the TV on using the
key.
b. Press <VOL +> and
<VOL -> to make sure that
the volume keys work.
c. Press and keys.
d. If any of these keys do not
work as expected, press
and hold that key. Release
it as soon as it works.
7. If all these keys work, press
<OK> to save this TV brand
code programming. The
RED LED will blink 3 times
and then turn off
Your Remote Control is now
programmed for your TV!
Dec 29, 2010 | Televison & Video
Need a code to program an innovage jumbo remote to an RCA tv. nothing fancy just the tv code please
The Innovage Jumbo users manual lists over two dozen RCA TV remote codes. They are:
000, 003, 004, 005, 007, 009, 011, 015, 048, 082, 092, 094, 096, 098, 101, 102, 103, 107, 113, 125, 129, 167, 179, 187, 188, 191, & 194.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
If you can't be bothered to enter each of those codes one at a time, you might consider the auto-search function.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Dec 09, 2009 | Innovage Jumbo Remote Control
I have a jumbo universal remote,how do I programit to an rca tv?
  1. Turn on your TV.
  1. Turn on your TV.
I hope that helps.
Nov 23, 2009 | Innovage Jumbo Remote Control
I have an innovage jumbo remote did not loose it!!! LOST THE DIRECTIONS TO PROGRAM IT.
You can program the Innovage Jumbo Remote by entering three digit codes, or by using the auto-search function.
  1. Turn on your TV.
  1. Turn on your TV.
To program the remote for your VCR, repeat this process starting with turning the VCR on, then follow the steps substituting the VCR button for the TV button.
I hope that helps.
Oct 31, 2009 | Innovage Jumbo Remote Control
I bought a universal jumbo remote and i followed instructions i to program it to my Jvc tv but it does not work can u help?
Make sure you try every code in the list for your JVC TV.
The codes for your Jumbo Universal Remote to control a JVC television are 013, 054, 055, 060, 065, 067, and 089.
  1. Turn on your TV.
  1. Turn on your TV.
I hope that helps.
Sep 24, 2009 | Innovage Jumbo Remote Control
Need code for Innovage jumbo universal remote for a rca tv
  1. Turn on your TV.
  1. Turn on your TV.
I hope that helps.
Sep 17, 2009 | RCA TruFlat 27F520T 27" TV
I have a Jumbo universal remote by Innovage and I need the programing codes for the tv. Do you have them???
To program your remote by entering a code from a manufacturer's list, follow these steps:
  1. Turn on your TV.
  1. Turn on your TV.
I hope that helps.
Aug 21, 2009 | Innovage Jumbo Remote Control
Philips universal remote codes
Hi Troysingleto. The code can depend on what model of URC you have. According to a site I found by Googling, the code for Apex TVs on one common URC from Philips is 044. Here are the steps to input it directly:
1. Press and hold the Code Search button until the red indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV, DVD, etc). The red indicator blinks, then stays lit.
3. Enter the 3 digit code (044) . Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
4. With your device on, press CHANNEL Up. If the device responds, no further programming is required. Note: If some buttons do not operate your equipment, try one of the other codes for your brand.
If that code does not work, you can still find the code using this manual procedure first posted on FixYa by cptnkirk4064:
1. Manually turn on device to be controlled.
2. Press and hold the "Code Search" button until the red indicator light stays on, then release it.
3. Press and quickly release the desired code button (TV, VCR, etc). The red indicator light should blink once.
4.Press the "Channel Up" button repeatedly (up to 300 times) until thedevice to be controlled changes channel. The red indicator light shouldblink off with each button press. If you accidentally overshoot therequired code, press the "Channel Down" button to backtrack through thelibrary until the device changes channel. Pressing "Channel Up" changesdirection again.
5. Press and release "Mute" button to install the code.
If you wish to actually identify the code once this has been done, this is the procedure:
1. Press and hold the "Code Search" button until the red indicator stays on. Release the "Code Search" button.
2. Press and release the desired mode button (TV, VCR, etc.). The red indicator light blinks and then stays on.
3. Press and release the "Code Search" button. The red indicator light goes off.
4.To find the first digit for the code stored under the mode key pressedin "Step 2" press each numeric key from 1-9 in turn. When the redindicator light blinks off, the number you pressed is the first digitfor the code you are searching for.
5. To find the second digit,repeat "Step 4," this time when the red indicator light blinks off,this is the second digit in your number.
6. Repeat again for the third digit in your code number.
Once I find out the code for my TV or DVD player, I write it on a small piece of paper (make sure to note which unit code is for!) and tape it to the inside of the lid to the battery compartment for future reference.
Best of luck!
Feb 13, 2009 | Apex Digital AT2002S 20" TV
Code for apex tv through philips universal remote
Go to www.urc.philips.com/
Follow the steps..its easy. It will ask for the model of your remote which you will find where your batteries are located..The code I used for my APEX tv was 0023.. to load the code first hold the setup button until the red light stays on..then press tv or whatever mode you are setting up..then enter the code and if the red light goes off it is the right code and you should then press channel up to see if it works...If this code doesn't work the site above offers other codes.. Hope this helps!!
Aug 30, 2008 | Apex Digital ADV3800 DVD Player/VCR
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
32 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
