Question about Kenmore 44042 Front Load Washer
Kenmore 44052 will not spin. Replaced door switch still will not spin. Ran diagnostics (code E43) so I replaced motor control board still will not spin. Could not get out of diagnostics so I replaced electronic panel now it's out of diagnostics BUT, still will not spin. $450 and very wet cloths
Try replacing door lock and latch. I got sick of the same problem and watching the full cycle several times. My dad thought it may be the latch also. Also on the final spin I held in the door, top to bottom and finally it completed the drying spin cycle!!! You need to do that at the right time or it won't work! If that is the problem, replace the door latch on the door and switch inside the machine. Should cost about $20 total with shipping..
Posted on Jan 18, 2013
  • Ted Sanders
    Ted Sanders Jan 18, 2013
    Try replacing door lock and latch. I got sick of the same problem and watching the full cycle several times. My dad thought it may be the latch also. Also on the final spin I held in the door, top to bottom and finally it completed the drying spin cycle!!! You need to do that at the right time or it won't work! If that is the problem, replace the door latch on the door and switch inside the machine. Should cost about $75 total with shipping..
    Sergeant:
  • 168 Answers
Have you pulled the pump and checked for obstructions? There may be something in the pump itself; you will need to check that...
If your problem can't solve, keep in mind that the error codes means physical wrongs, so, E43 is a door-locking problem or "board comunication problems".
I hope this helps.
Posted on Sep 30, 2010
FTF2140ES won't spin
How old is the machine ?
if about 3years old check carbon brushers
Dec 14, 2013 | Frigidaire FTF2140ES Stacking Front Load...
Washing machine (Kenmore Super Capacity 3.5 front loading) not spinning and getting E43 error code. I suspect it's the door lock malfunctioning but want to make sure before I purchase it. I've done...
Well, you are PROBABLY right. It's probably The door interlock switch ("Wax motor") despite the fact that the diagnostic code E43 claims that its a controller board fault. I've had a few conversations about this code in the past and the phrase "Somewhat unreliable" has come up quite often (as has the phrase "complete ****")
For what it's worth, I believe there are 2 parts available for this switch replacement:
If it's a 0.05A rating, the part number is 99001807.
If it's a 0.12A rating, the part number is 12002535.
I believe they cost about $10 - $15
Please don't take the part numbers or price as guaranteed to be correct, I found them in some old notes I have and I may be talking rubbish.
Jul 27, 2011 | Washing Machines
Front Load Frigidaire Won't Spin Out
I had the same problem listed above on my LTF2140ES3...the machine did everything but do a final spin. In diagnostics I could do the final spin and the machine kicked out an E43 which is the control board error.
Following the advice here I changed the door latch first and the problem went away and the unit runs as it should.
You'll get "experts" who say that the unit would not spin at all if the door latch was bad. I can tell you first hand that they are wrong. Again the unit did all the normal tumbling but didn't do the high speed final spin. Again, replacing the door latch fixed the problem. The door latch is part number 131763245 (AP3886713)
Jun 30, 2009 | Frigidaire ATF6000ES Front Load Washer
Wont spin at end of any cycle
I am a service technician in grants pass oregon and i had the same problem. It told me to replace the board too. I replaced the main boad, Motor control board, door switch and cleaned all the hoses and it still didnt fix it. I had 3 other service technicians look at it ( one from sears ) And nobody could figure it out.
Feb 03, 2009 | Frigidaire GLTF2940ES Front Load Washer
Kenmore front load washer wont spin...
check the motor control board ,,, sound like thats what your looking at
Dec 08, 2008 | Washing Machines
Frigidaire front load washer won't final spin
THERE ARE A COUPLE OF CONDITIONS THAT WILL PREVENT THIS UNIT FROM SPINNING :NOT COMPLETELY DRAIN AND FAULTY DOOR LOCK AS SY.
FIRST REMOVE ELBOW ADAPTER HOSE FROM TUB TO PUMP AND MAKE SURE IS COMPLETELY CLEAN ,HOSE STRAINER THEN CHECK IMPELLER @ DRAIN PUMP NOT TO BE BROOKED , DEFORMED .DIRTY OR LOOSE IF IS LIKE THIS REPLACE PUMP IF NOT PUT EVERYTHING BACK TOGETHER ,MAKING SURE THE STRAINER IS ALL WAY DOWN (IF IT HAS ONE) IF NOT IT WILL GET LOOSE AND DAMAGE YOUR OUTHER TUB ,THEN THIS IS IT .
THEN CHECK PRESSURE SW HOSE FOR LEAKS AND BLOW SLOWLY AND CAREFULLY TO CHECK PRESSURE SW .IF CHECKS OK THEN REPLACE DOOR SW ASSY AND RUN ONE IM VERY SURE THIS WILL TAKE CARE OF YOUR SITUATION ;NOW GET ON YOUR KNEES , GET DIRTY AND HAVE A GREAT DAY!
MAYITOJHONES
Nov 09, 2008 | Frigidaire ATF6000ES Front Load Washer
417.4405200 not spinning at the end of wash cycles
Does the washer was loaded when you make the diagnnostic test ?
Jul 20, 2007 | Kenmore 44072 Front Load Washer
Kenmore 417. 4405200 Front Load Washer error code E43
It's a bad wax motor inside the door latch. The diagnostics are buggy and do not test it properly. It should measure about 1.5K ohms, and when 120 VAC is applied to it, it should extend in about a minute. Part number 12002535 is $10 to $15.
Jul 20, 2007 | Kenmore 43142 Front Load Washer
Kenmore 44042 Front Load Washer Logo
550 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
