Question about Sylvania DVR90VE DVD Recorder/VCR
Unit stopped working
Sylvania DVR90VF DVD Recorder with Cassette Recorder has worked fine for the year that I've had it. Now at power on the TV displays just a blank blue screen. When remote is activated the screen shows hash and unreadable jumbled text. Does this sound terminal or can it be corrected by opening the case and cleaning any components? The above problem occurs whether DVD or Cassette is installed.
  • theoeh1 May 28, 2008
    My thanks to bestdarngood, Irish Druid, and Ekse for the responses to my Sylvania DVR 90VF problem. I tried the suggestions that were offered, but no luck. I opened up the recorder today and found soot and a scorched circuit board under the hard drive. I'm afraid this unit is headed for the trash unless I get a decent repair quote. Thanks again to all of you for your input.
  • 3,037 Answers
The first thing to always try is a hard reset, this requires the unit to be totally unplugged for 30 minutes to see if that works. Did this screen come up during use or did it happen when you jsut turned it? Please let me know both how this goes and get back to me on my question, thanks
Posted on May 25, 2008
  • Benjamin Patri
    Benjamin Patri May 28, 2008
    sounds good, yeah a board isn't usually worth replacing, good luck with your next player
    President:
  • 2,712 Answers
Try replugging the cable b/w TV and Player. Make sure contacts are good.
Try a hard reset: Unplug the player from the wall socket, remove all other cables, wait about 10 minutes and then replug to power socket and redo cabling.
You can also try to open the player's cover and try blowing out any dust/debris using a can of compressed air.
If all that fails to resolve the issue, then it could be a problem with the circuitry, for which you will either need to get it serviced, or replaced (whichever works out cheaper for you). If it is still under warranty, try to call the manufacturer/point of purchase for an exchange.
Hope that helps!
  • Swilin Sampson
    Swilin Sampson May 26, 2008
    Please also try using a different cable b/n TV and player, or try using a different connector like SCART or RCA..
  • Sylvania Master
  • 13,433 Answers
It doesn't sound too good. Unplug it for a hour or two and see what happens
Sylvania tv stopped working
Something may have happened in the DVD unit to take out the main fuse in the power board, start by checking that
Dec 04, 2017 | Sylvania Televison & Video
Tip
How to record a program you are watching on your cable satellite receiver.
Hello,<br /><br />Most of the time we watch TV programs with our cable satellite receiver/decoder. And sometimes we would love to record these programs so that we can watch them again. You can learn how to record your TV program while you watching a TV program. <br /><br />All you will be needing is a DVD recorder or VCR (Video cassette Recorder). It all depends on the one you prefer.<br /><br />There are two methods of doing this connection. 1. is RF connection and the other is RCA. But I will start with the RF connection method;<br /><br />This is how is works. Get a RF cord, check the back of your TV, you would see RF in, connect the RF into TV in, then connect the other part to RF Out at the back of the Cassette or DVD Recorder.<br /><br />Turn the Cassette or DVD Recorder and the TV on. Go to Channel 1 or any channel on the TV, search the TV stations automatically or manually in order to get a display of the Cassette or DVD Recorder on the TV. To easily get the Cassette or DVD Recorder's station, play a movie on the Cassette or DVD Recorder while you search for the station. Once you see the display of the movie on your TV, you would easily know that that's the Cassette or DVD Recorder station. <br /><br />Once you have gotten a display from the Cassette or DVD Recorder, save the channel on the TV.<br /><br />Then get another RF cord, connect it to "RF out" at the back of the Satellite/cable decoder/receiver and the other part to "RF in" at the back of the Cassette or DVD Recorder.<br /><br />Now with the Satellite/cable decoder/receiver turned on and the Cassette or DVD Recorder also turned on, press the Cassette or DVD Recorder's channel, you should find search. Scan for channel/stations on the Cassette or DVD Recorder just like you did on the TV and you will find a display of the Satellite/cable decoder/receiver showing on the TV via the Cassette or DVD Recorder. Note that on some Cassette or DVD Recorder, you will have to select "Source" to RF before you can get a display of the channel.<br /><br />Now since the Satellite/cable decoder/receiver program is now showing via the Satellite/cable decoder/receiver, insert a black disc or cassette into the Recoder and press record. The Satellite/cable decoder/receiver programs showing on the TV via the player will be recorded and that would be all.<br /><br />For some recorders that has internal hard drive, you can just press record without inserting a blank disc......<br /><br />USING RCA CONNECTION METHOD.<br /><br />You could also achieve this by using a RCA (yellow, red and white cord).<br /><br />The connection procedure is the same with the RF explained above.<br /><br />Connect the Recorder to the TV. That is, from "Video and audio Out" of the recorder to "video and audio in" of the TV accordingly. Press AV or source on the TV to confirm that there is a display from the recorder on the TV.<br /><br />Now connect the RCA cord to "OUT" from the Satellite/cable decoder/receiver to "IN" at the back of the Recorder.<br /><br />Then, press source on the recorder to "INPUT" (RCA) and the Satellite/cable decoder/receiver's program will automatically display on the TV. <br /><br />While the Program is being displayed on the TV via the recoder, insert a blank disc and press record on the player and it will automatically start recording. You will see the record or record symbol while the recoding is in progress.<br /><br />I hope you understand the above. Please follow steps closely and you won't have any problems.<br /><br />Good luck.
on Mar 09, 2011 | Televison & Video
My remote is not being received by the unit. Unit works fine, and remote is emitting IR. Tried syncing remote but nothing, and cant use the unit without the remote.
8 YEARS has exceeded it's life expectancy by 3 years already as they consider 5 years as a life time in the electronics industry
Jul 02, 2015 | Toshiba RD-XS34 DVD Player/HDD Recorder
When I play DVD's my tv screen gets a rectangle box on it, the VHS is fine, it's just the DVD player.
Yes! you are right, this almost sounds like a captions problem, check the DVD/VCR Combo menu, if it has captions turn it off using your remote.
Mar 17, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
Sylvania DVR90VF will not play home burned DVD-R disc
Search for DVD43 on the net. It's a free download. It works 99.99% of the time.
Jun 26, 2008 | Sylvania DVR90VE DVD Recorder/VCR
LG HDD DVD Recorder remote control not working with LG TV
I have a rh 265 remote and lg tv. It stopped controlling the tv. I hold the tv power button down on remote then pushed 1 at the same time. It reset it to work with my tv.
May 29, 2008 | LG DE9523P DVD Player
Sylvania dvr90vf dvd recorder
my lg 7500problem was: turns on show "lg recoreder" on screen and then restart ,then i connect hard to a pc and format it , now it work correctly . but data lost
May 03, 2008 | Televison & Video
Unfortunately without a firmware upgrade the only disks you can use are DVD-R or DVD-RW. The tricky part is that you can ONLY USE 2X speed. Per my conversation with Sylvania there is a firmware update that will allow you to use up to 8x disks, but they are charging $17.00 for it.
Feb 12, 2008 | Sylvania DVR90VE DVD Recorder/VCR
Sylvania DVR90VE DVD Recorder/VCR Logo
169 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
