Question about Amana ACM1580 Convection Microwave Oven
Connection of safety switches that control the doors and other functions for the microwave to work!!!
  • Amana Master
  • 9,047 Answers
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Our door switch help file is here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on Oct 03, 2010
How to reset microwave
there is no reset function to look over, check safety interlock door switch, Has lamp & control Display lit?
Aug 19, 2014 | Panasonic NN-H965 Microwave Oven
Miele H147-2mb not heat when microwave other function OK
Check the door safety interlock switch. More than 90% of problems like this are due to failed safety switch. Switch fails because people open the door when the oven is operating.
Mar 17, 2013 | Miele H147-2MB Convection/Microwave Oven
Stopped heating
Check the door safety interlock switches. If they are faulty, the oven thinks the door is open. Forget what YOU know about the status of the door, the oven wants proof the door is closed and the safety interlock switch provides that information.
What happens is this: If you open the door while the oven is running, you cause these tiny switches to arc and they will eventually burn out and not function properly.
Thanks for your interest in FixYa.com
Feb 19, 2010 | Microwave Ovens
Microwave
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
This may possibly be a door switch issue. The door has to interlock 3 switches to provide safety and performance functions. If the performance function switch fails or is misaligned, it can cause these symptoms. Occasionally you may encounter a "sticky" door switch that may correct itself with a little harder closure of the door. If you are not familiar with how a microwave oven works, I would suggest a professional repairman look at this problem as it involves safety related issues.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 09, 2008 | Bosch HMT8655GB Microwave Oven
GE JEM31LWS Microwave.
Yes, the fuse being bad would kill the unit totally.
Do the fan and inside light work when you try to cook?
If so, then the problem is in the high voltage section.
If not, then the problem is most likely a door switch or mount issue or possibly a problem on the control board.
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 20, 2008 | GE JVM1870 Microwave Oven
All functions work except no heat
In this case I would most suspect the magnetron (or a bad connection at the magnetron) or a problem on the control panel.
But generally, the most common causes of a failure to heat are:
Mar 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven not functioning
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Dec 04, 2007 | Magic Chef CMV1000B Microwave Oven
Over range microwave not working properly
- problem or loose conneciton on the control unit circuit board
At our site, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information.
See our listing here on FixYa: http://tinyurl.com/yzjozk
Oct 15, 2007 | Whirlpool MH6150XL Microwave Oven
Microwave section not working
Quite often this is due to a bad door switch. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 Feel free to contact me directly if you have further questions.
Aug 10, 2007 | GE Advantium 120 Convection/Microwave Oven
No heat
The most likely causes are defective a door switch (or switch mount), a bad connection in the high voltage section, or on the controller. I would direct you to my safety text file and door switch text file for critical safety info anf info on testing & replacing door switches. You can find it via searching on Yahoo.com (not Google) for: microwave safety.txt After you check that out, please repost so we can hel you further.
Nov 27, 2006 | Goldstar MV-1501 Microwave Oven
Amana ACM1580 Convection Microwave Oven Logo
56 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
