Question about Sylvania 6260VF VCR
How do i adjust tracking. tapes roll. used a cleaning tape, didn't help. there is no switch for manual tracking.
  • Sylvania Master
  • 5,449 Answers
Cleaning tapes are not as good as going in with a can of Servisol Video 40 and some cotton buds. Take the top cover off and give it a really good clean with them. Clean everywhere the tape touches. Make certain you allow to dry before trying again. If that doesn't work you could have a faulty head.
PS it will take longer to clean if it is housed in a room where people smoke!
Posted on Oct 01, 2010
Where is the tracking on this VCR toshiba w403?
On this unit there is no manual tracking button - it's done automatically by a special circuit that uses the special signal from the tracks themselves. If the tracking is bad then the heads are dirty and they don't pick that special signal.
Clean them with a special cleaning tape. If you can't source one the unit will have to be dismantled and the 4 heads will have to be manually cleaned with a q-tip moist with alcohol.
Jul 26, 2011 | Toshiba W403 VHS VCR
Buzz during playback, but only on SOME tapes!! When i adjust tracking manually, pictures quality suffers.
Bad recording VHS or old VHS tapes,will sometimes causes this problems,because of degrading magnatic tapes.Sorry this problems,u did the fixed adjusting manual tracking,that it not fixing the problems,sorry that all u will getting that kind of quality of picture.
Mar 21, 2011 | GoVideo Go Video DVD/VCR Combo
Tracking will not adjust, continues to roll, have tried manual tracking adjustment with remote, does not work, wondering if I need to clean or adjust something internal to the VCR
Yes take the top cover off and give all the heads etc a spray with Servisol Video 40. That might make a differance. Allow to dry before trying a tape! If the house has a smoker you might need to do a lot of work!
Jun 06, 2010 | Panasonic PV-V4020 VHS VCR
Picture rolls and the tracking is off.
do the heads need cleaning? sounds like the heads are seriously out of alignment? take off the vcr cover get a philip scrdrv. put tape in. and play. theres an AC head just to the right of the drumhead. jiggle it around gently. u may have to adjust those 3 screws (precison) to put it back in proper adjustmant. also take the tapes u used in that vcr. open the top flap and inspect. are there marks? is there a line going the bottom portion of the tape. if so , it definitely is out of alignment.
Aug 14, 2009 | Philips Televison & Video
The tape only plays back in black and white.
normally this would be a tracking error, if you can manually adjust the tracking, this should fix the prob...if there is no way to manually adj the tracking, use a video head cleaner to see if cleaning the heads will help the auto track to function better.
clarkco
Feb 09, 2009 | Toshiba M752 VCR
Picture bounces up and down
All new VCR's are auto tracking however, you should be able to manually track it using your remote, or there are a few reasons that the auto track can fail, the tape may have worn or ragged edges which means that the control head cannot get a clean reading, the control head may itself need cleaning or the tape path requires adjustments, adjusting the guides really needs to be done by a technician as a reference tape is used, or that the heads are low and a good video signal cannot be obtained to gain a reference point....Phil
Dec 15, 2008 | Sylvania 6240VE VHS/S-VHS playback VCR
Playing slp mode picture rolls
the video and control heads are probably dirty. a video cleaning tape might work, otherwise you will need to get a proffessional to clean if for you.
Mar 25, 2008 | Philips Magnavox 20MC4304 20 in....
Tracking
Does this happen on ALL tapes?
Depending on WHICH model VCR you have (old or new) SOME have a switch which will allow you to adjust tracking MANUALLY. When the switch is in the manual position, it won't track automatically. If some played with that switch, that could cause your problem.
ALSO, do you have a cleaning tape? If the control track head is dirty, it won't see the "control track" (which gives you VCR information to control the tracking.
Another possibility is one of the video heads (there's 2 or 4) is dirty, and without ENOUGH video signal coming off the heads, it's not possible to track properly.
Try running a cleaning tape through. If you've never done it, it might be time. Unless yu know about equipment I'd wouldn't suggest you open the machine and clean it yourself. Let me know how you make out.
Mar 16, 2008 | Sylvania 6260VF VCR
Tracking
3 possible reasons:
1. Your video head needs cleaning;
2. The pinch roller is no longer making full contact with the entire tape width; or
3. Your capstan motor is running out of standard speed.
Corrective procedures would call for:
A. Clean the video head with a tape head cleaner;
B. Clean, re-align or replace the pinch roller; or
C. Re-calibrate the capstan speed. In some models, there are 2 adjusting trimpots for SP, LP and SLP speeds. This procedure would call for a special tachometer and/or an alignment tape. In the absence, you perhaps can try winging it (adjust till you are satisfied and no picture roll). To determine which are the trimpots, you need a service manual or at least a schematic/parts placement diagram. Further you need to be familiar with electronic components and circuitry as well as use of a DVM. of course this would involve running/diagnosing/adjusting with the case/cover open and the unit plug in to the mains and running. This would also call for extreme care working with live units.
Should you not be comfortable doing a DIY, perhaps your best option would be to seek the services of a qualified VCR technician.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 24, 2007 | Emerson EWR20V4 DVD Recorder/VCR
VHS Picture on new recorded tape shows horizontal bars.
clean the head of your vcr that will help also connections of the wires good luck.
Mar 29, 2007 | Sony SLV-D550P DVD Player/VCR
Televison & Video Logo
122 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
