My daughter is at college and called me. Her printer won't print and it says offline in the control panel. Its a brother mfc 255 cw
  • 823 Answers
Your going to laugh when you see how to fix this! At least I did the first time it happened to me.
Open a document that you want to print. Go to the top of the page and find where it says "File". Click on file and follow the drop down list almost to the bottom where it says Work Offline. Click on Work offline and this will put your printer back on line and able to start printing again.
Posted on Sep 30, 2010
Testimonial: "Ok we will try that! Thank you!"
  • Kandi Cook Sep 30, 2010
    You can also try right clicking with your mouse on the picture of the printer on the bottom right side of your pc screen and then choose properties and find the use printer online option located there.
  • Kandi Cook Nov 10, 2010
    Were you able to test my instructions with her computer yet? I was curious if this solved your problem being I did not see a response and/or rating from you.
Cannot clear memory on brother mfc 495 cw
go to the printers and devices near the control panel of the computer , click on printer and see what is printing
cancel any task pending not completed
Sep 30, 2016 | Brother 495CW MFC-495CW Copier/Fax...
How do I get my Brother MFC-7340 online from offline?
Have you gone into control panel and selected administrative tools and then services. Scroll down to print spooler and disable and then re-enable it and see if that helps. Also check to make sure that the printer is compatible with your version of windows. May have to update your drivers. I have a MFC-7220 myself.
Jun 06, 2014 | Brother MFC-7340 All-In-One Laser Printer
Problem with Brother MFC-9840CWD
Hi,Check to see in the connectioncables are all plugged in correctly.Open the printer and see if drumunit and toner cartridges are installed correctly. Sometimes not well installedconsumables are the cause of that particular problem.See if the print driver on yourcomputer is correctly installed. Try and reinstall the driver.Check if your printer is working in onlinemode. Sometimes printer changes online to offline method. If printer is atoffline mode click Start button on your computer, enter Control Panel. Click onHardware and Sound and choose Printers. Right click on Brother MFC-9840CWD andmake sure that the Use Printer offline is not checked.Hope this helps.
May 09, 2012 | Brother MFC-9840CDW Laser Printer
How to install a brother mfc-255 cw printer onto my computer?
You candownload the Brother printer drivers from their support WEB site. Please clickon this link and select your model printer to download : - http://www.brother.com.au/ProductsSolutions.aspx
Jul 04, 2011 | Brother Office Equipment & Supplies
My brother mfc 665-cw is saying offline no matter what I do to try to print wirelessly
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
Apr 25, 2011 | Brother MFC-665CW All-In-One InkJet...
I cant print any documents my brother MFC-255CW says offline and i cant get it to work
I had the same problem, and couldn't find a solution anywhere. My laptop said the wifi Brother MFC-255CW printer was offline, when the printer was definitely online and connected.
In the end I simply went into Control Panel / Printers, selected the Brother printer, and deleted it off the network. Then I chose "Add a Printer" from the network, and reselected the only printer on my home network - which was the Brother MFC-255CW that I had just deleted. The computer reinstalled the driver, and everything was fine again - haven't had a problem since.
Nov 08, 2010 | Brother MFC 240C All-In-One InkJet Printer
My printer (MFC-490-CW)print status is offline change online
If you want to make it online, than make sure it is on and connected to your computer, Once you are sure about this than
Go to control panel than Printers and Faxes
There You need to right click on printer and than Use printer online
IT will Put you printer back online.
Nov 10, 2009 | Brother MFC 490cw Color Inkjet...
Brother mfc is offline -
For my MFC, my PC says its ready and working properly. It really only works when I'm not connected to my cable modem. All PCs use it then. It's offline otherwise.
Sep 05, 2008 | Brother MFC-8860DN Printer
441 people viewed this question
jasbo
jasbo
