How do you install the paper on adding machine monroe 3140
2 Suggested Answers
  • 1456 Answers
SOURCE: We have several Monroe 3140
Hello
Load the printer with a quick-drying paper,there are several varieties of paper with smudge-proof coatings. These specialty papers can be bought at most office supply shops.
the cause for ink smears on printouts is that the head gap lever may be placed in an improper position. If the lever is moved toward the "plus" position, the smearing problem should cease happening.
An ink buildup in the cartridge may be blocking the ink from flowing or may cause it to come out in sudden spurts, creating smears.
Remove the printheads and lay them on newspaper or a cloth to catch any ink spills. Dip a Q-tip in distilled water and squeeze out the excess with a paper towel. Clean the ink off the top of the printheads with the Q-tip. Allow the printheads to air dry, and reinsert them and run a test print.
Align the print heads.Remove the ink cartridges and tap them firmly against a hard surface Be sure to have a paper towel or napkin underneath where you tap; if this does fix the head, drops of ink will begin coming out. Replace the cartridges.
Posted on Nov 18, 2010
Ekg machine keeps beeping out of paper --- it has paper !
Check is the paper is properly installed or not. Here i have added a video wich will help you to proper installation of paper in the try. keep in mind the you have to use Schiller orginal paper.
Ajin
May 29, 2012 | Schiller Welch Allyn Cardiovit At 2...
FR-2650 Plus adding machine
How to install paper tape on a adding machine?
Apr 27, 2009 | Casio FR-2650A Calculator
MONROE 7130 LOCK UP WHEN I PRESS THE PAPER ADVANCE. ALSO LOCKS UP WHEN I ADD WITH THE PRINTER ON. A E COMES ON ON THE LEFT SIDE OF THE SCREEN ALSO.
We repaired many Monroe 7130...this could be logic problem..maybe something on the logic bd. ...coke , coffee, etc. etc. staple, paper clip.. but in all probably you may have a printer gone bad.. You can always shake your cal to see if you have dropped anything on the logic bd... but always turn your machine off before you do this...this problem has happened only once or twice..we would try a another printer unit and isolate if it was a logic or printer and go from there...good luck 608-222-2484
Apr 24, 2009 | Monroe 7130 Calculator
Monroe Calculator 7130 - won't print red for negative
turn it off & back on & that should fix it. the ribbon lift needs to reset.
dennis
Nov 18, 2008 | Monroe 7130 Calculator
Adding machine problems
Block yBob - did you ever get an answer to your problem. I'm getting ready to install an ink cartridge into the same machine.
Aug 20, 2008 | Office Equipment & Supplies
How do I clear misfeed.
In most cases where the machine says there is a jam, and there is no paper in the paper path, it's because the paper never got out of the paper drawer and didn't reach the 1st jam sensor. If you can open the machine and it resets, then chances are the paper feed roller is either slipping or in some cases not turning at all. If you can't clear the jam by turning off the machine, and back on, then you have a bad jam setect sensor or perhaps a small piece of paper lodged on the jam sensor. This will take some additional troubleshooting on your part. Need to know if the jam indicator goes away when you restart the machine. Let me know and I'll try to guide you from that point. Aloha, Bill Monroe
Sep 17, 2007 | Ricoh Aficio 1018D Copier
159 people viewed this question
jasbo
jasbo
