Question about Microwave Ovens
I have a Kenmore Microwave - model# 721.6629292 500 - manufactured Oct. 2006. The microwave unit will not heat. The toaster unit is working, I do not have the manual. Is there a reset button?
  • Microwave Ovens Master
  • 11,800 Answers
No, no reset button. The magnetron - the device in your oven that generates the heat - is either defective or not powered. To check it you must open the oven and check the voltage at the magnetron.
The voltage is in excess of 5000 volts and you need a very special voltmeter for checking it. Using a regular multimeter or not knowing how to do it safely but still doing it is a absolutely sure way to die - don't do it.
Either take it to a repair shop or get another, do not attempt to fix it yourself, your life is worth more than a few hundred bucks.
Posted on Sep 30, 2010
I have a kenmore microwave toaster. Microwave no heat. table rotates OK and toaster works OK. What is most likely problem, HV diode, capacitor or magnetron?
Could be any of those 3 parts since they work together to make the microwave part work. Most common problem if under 5 years old would be the diode, then capacitor, then mag, but I have replaced mags on new microwave in some cases. Like I said they work together. Capacitors will sometimes swell up at the top or bottom but again not always.. This isn't much help but you need a multimeter and must know some test procedures on this one.
Apr 14, 2015 | Kenmore Microwave Ovens
Kenmore 1000w Not Heating Food Items
If it sounds like it is running and it lights up it is not the fuse. In my 24 years of service work I've found that the problem you are describing is cause by the failure of the magnitron ( The device that emits the microwave radiation). As your unit is a built in expensive unit I would look into replacing the magnitron. In cheap microwaves I just suggest replacement. If you need further assistance locating a replacement magnitron feel free to cotact me. It is a relatively easy part to replace. You just open the case and unplug it, unscrew it from the unit, and replace it with the new one. In most cases all you need is a philips head screwdriver and some patience. Anyway, I hope this helps you out in your decicion.
George
Jul 19, 2008 | Kenmore 62642 / 62644 / 62649 Microwave...
Microwave only stay on for 1.5 minutes at 100% power
Take it back you still have warranty, the problem is the magnetron, or the inverter board, and possibly the keypad control board.
May 18, 2012 | Panasonic Microwave Ovens
The microwave runs and sounds normal, but it does not heat up the food. (We did run it at 100% power a few times, with no heat up) Do you have any suggestions to what the problem could be? We purchased...
Sorry to read about your problem.
It seems your have a general failure in the power control or switch failure on the unit. you said your unit has power, and things lite. Then it is more likely you have a control/switch problem,
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances. Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged. A microwave radiation leakage test must be performed on the unit following any internal component repair
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 31, 2010 | Kenmore 63252 Microwave Oven
Kenmore microwave model 721.80033700 won't heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Jul 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Goldstar microwave oven stop heating
microwave ovens have a special Magntron fuse that is inside the body of the microwave its much bigger than a normal fuse, if its blown the microwave wont work.
Jul 30, 2017 | Goldstar Microwave Ovens
Microwave Toaster Combe
The button may be stuck... try cleaning the display really well.
Oct 26, 2008 | Microwave Ovens
Kenmore microwave
Since it's under warranty, they will replace or repair it at their choice, and if they replace it, it will be the same model or a "like model".
I'd ask them about it.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 04, 2008 | Kenmore 63663 Microwave Oven
Kenmore over the range Microwave
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Dec 05, 2007 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
44 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
