Question about GE PSS26LGR Side by Side Refrigerator
At first the refrigerator side was freezing everything and the freezer was fine, except the ice & water quit working. I replaced the filter & it worked for a few days then it was back to the same thing. Now both sides are not as cold, still no ice or water & my icecream is melting. sometimes the fan would make a loud sound, now I don't hear it at all.
  • GE Master
  • 2,287 Answers
If the fan was loud you could have a bad evap fan motor,is there ice on the inside back wall of the freezer?if there is you have a defrost problem and ice could be built up around the fan motor and the blade,when the blade hit the ice that could be the noise you were hearing and now the ice is stopping it from spinning at all.if there isn't any ice on the wall you could have a bad computer board,part number wr55x10942,i've seen g.e.'s that when the water and ice didn't work and the temp was warm it was the board but when you say the fan was loud it makes me think you could be iced up in there.also if the fan motor was reving up and slowing down the board could cause that,let me know if there's like snow or ice on the freezer wall and i can help you out
Posted on Sep 30, 2010
  • Sal DeAngelo Oct 02, 2010
    also it's a good idea to change out the temp sensor at the top of the evap coil part wr55x10025
    the temp sensor looks like a white bullet,cut the white wires and then cut down the new sensor wires and reinstall it,keep the wires close to the original length
What this can be?
On the rear of the refrigerator, there is a water control valve, that controls the flow of water to the icemaker and the water dispenser, if equipped. Hard water is usually the cause for this to quit running. The icemaker and water dispenser, are two separate circuits, and each one has it's own water control valve.
Mar 13, 2015 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Frigidaire FRS26HF6BW2 side by side Refrigerator with ice maker, no water flow. Everything was working fine until the food in the refrigerator started freezing. Freezer stable at 0F and refrigerator...
Memory card is not opening and when i connect in pc so they show error like.. there was a problem starting -WKBPBCM.init the specified module could not be found.... so please solve my problem
Oct 31, 2013 | Frigidaire FRS3R5EMB Side by Side...
Why are only drawers in fridge cold & not making ice?
Contact a professional. Sounds like either your damper door is not operating correctly and not letting enough cool air from the freezer enter, or there is an air leak that is making ice form .
Aug 12, 2012 | Frigidaire FRS3R5EMB Side by Side...
Ice maker quit working. I found water on the floor outside freezer side. This happened after a power outage and the ice maker hasnt worked since
The ice maker is freezing sound like it turning but not dumping and new water is comming in and no where to go except over the top. A new ice maker is around 100.00 Sears had them on sale recently for 49.00 find a used appliance store and maby pick one up for ten or fifteen dollars. You can install it the just plug in and hang by two screws.
Apr 26, 2010 | Kenmore 21.8 cu. ft. Side-By-Side...
Traulsen Ultra freezer quit and right wall is leaking water--why?
The fridge is twenty eight years old and not worth putting another dime into it. A fridge that old will just keep dimeing you to *****.
Mar 06, 2017 | Traulsen Refrigeration 48'' Wide x 24''...
No water but ice is fine
turn freezer side to zero for 1 minute press water dispenser
Mar 29, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
bjones03@comcast.net
Mar 25, 2009 | Jenn-Air JCD2389G Side by Side...
Maytag plus MSD2756GEQ ice maker not working
I had similar problem in that the fan in the freezer that blows freezing air into freezer and over to fridge was not working. Fridge was running warm (over 40 deg and freezer up near 20) Service call around $160 with new fan.
Feb 06, 2009 | Maytag MSD2756G Side by Side Refrigerator
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
GE PSS26LGR Side by Side Refrigerator Logo
137 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
