Audiovox FPE1505 has picture but no sound. When there is sound, extremely faint picture and brightness and contrast have virtually no effect
  • 3 more comments
  • bgloyd May 25, 2008
    All capacitors look normal and there is no sign of overheating resistors.
  • bgloyd May 26, 2008
    Yes. This happens even with the AGC source selected. The computer picture is great. If the sound is active, then the computer picture is very dim as well. You can see an image by shining a flashlight onto the screen at an oblique angle. This allows me to see the Menu functions an none seem to have any positive effects.
    Sorry, I typed AGC and it should be VGA.
  • bgloyd May 27, 2008
    Unfortunately the warranty has expired. I did try other speakers as you suggested and that did not help. Thanks for trying to help.
  • bgloyd May 28, 2008
    Yes, that was my conclusion as well.
  • 3,037 Answers
You need to look at the capacitors for one and see if any look bloated. This will require opening up the system. Also look for bad connections on the board and don't touch the capacitors as they carry a large charge. You say that when the sound works, it works good but the picture dims? This would indicate bad resistors, or the capacitors. Please have a look and tell me what you find.
If you have any questions about doing this, please ask or if you don't feel comfortable doing this, please let me know
Posted on May 25, 2008
  • 5 more comments
  • Benjamin Patri
    Benjamin Patri May 25, 2008
    Alright, do you have an extra speaker at all? I want you to try hooking up some external speakers to see if they would work so we can narrow down the location of this problem better. Also, when you get sound, does occur on its own while the tv is on or once you turn it on the sound appears sometimes. Maybe a loose connection like I said before is causing this, when you don't have sound try bumping the tv to get sound and see if that works. Please get back to me on the external speakers. thanks
  • Benjamin Patri
    When you opened the tv, did you check the wires from the speakers to the board at all? I don't think these are a problem since your picture is having problems when the speakers work but it is worth a look.
  • Benjamin Patri
    I'm thinking that it may be your audio amplifier causing the problem and that it may be sucking a little too much power when working if everything above looks fine, but the external speakers would help narrow this down for sure
  • Benjamin Patri
    also one more thing, this happens on all inputs correct? channels, dvd player, I assume so...
  • Benjamin Patri
    Benjamin Patri May 26, 2008
    You don't still have the warranty on this device do you?
    Did you try plugging in any other speakers or headphones to it and seeing if they will do the same thing to the screen?
  • Benjamin Patri
    Benjamin Patri May 27, 2008
    well then it sounds like a defective board or maybe a wire is shorting out, have another look to see if any wires running to the speakers may be shorting out. You could try rewiring the speakers and see if that helps. Otherwise, what I would try now is calling audiovox and see what they can do for you, perhaps give you a discount on a new one as I don't think it would be worth fixing but see what they say and let me know how it goes
  • Benjamin Patri
    Benjamin Patri May 28, 2008
    Please don't forget to rate my solution when you are satisfied with my service here. thanks
    Genius:
  • 3,422 Answers
Did you try a hard reset by unpluging all the cords for 4 hours and then put them back?
Sound but no picture
The first thing that comes to mind is that the brightness and contrast or turned all the way down. See if you can't turn them up. Otherwise it may be the backlight inverter or backlight itself. Most likely the inverter, sometimes you can tell by looking really close to the screen, if you can still see a faint image then the inverter needs to be replaced. Probably a job for a technician but that depends how comfortable you feel opening up the TV and ordering parts online.
Good Luck!
Feb 27, 2008 | Audiovox FPE3000 30 in. HD-Ready LCD...
Fix color?
You may have a picture reset button available to you in your menu choices under display or picture. If not you will see a menu with color, contrast and brightness or something along those lines. With your remote make all of the settings for these the same with them set in the middle of the virtual slider. That will even you out and you can adjust to taste from there.
Jan 26, 2016 | Televison & Video
Hazy picture
This is listed in the standard TV area which means set has a picture tube and is not a lcd or plasma.
That being said try a rear audio and video input first to see if same issue or not.
Try to lower contrast and brightness (contrast on some sets is called picture) to see if that helps.
Lastly shoot me a model and brand.
Dec 20, 2012 | Televison & Video
Hellow. I bought a Lake PC to TV video converter. I pluged to my laptop and TV and no special problem, but the contrast and bright of the image in my TV is very bad. I pushed buttons to open the menu...
click start control panel,display,desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes hope this helps
May 30, 2011 | Audiovox Lake PC to TV Converter Box...
My jvc 52g 887 had the bulb replaced 6/1/10. The picture is very dull with very little contrast. Is it the bulb?
A poor output lamp won't reduce the effective contrast so I expect it just needs slight adjustment to the contrast or brightness.
Hope that helps
Jan 25, 2011 | JVC Televison & Video
Ibm thinkpad monitor very faint, images are barely visable.
It seems that the contrast and brightness are out. On the monitor, press the Menu button. Then go to the brightness and reduce brightness and set the Contrast to a little more. You will have to tweak these two settings to get the correct picture. First set them at default and the go up and down to get the right picture.
Nov 24, 2009 | IBM Computers & Internet
White screen when taking pictures in daylight
Go to the menu screen for LCD contrast and adjust, it sounds like it is to high. Kinda like a back light for a plasma screen.
Oct 23, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
RCA 32V420T 32" TV
This RCA set uses the CTC187BD chassis. Look on the back of the set and to the right of the cable connector you will see 2 controls sticking out, one on top of the other. The top control is for focus and the bottom one is screen, or overall brightness. If these controls have been turned clockwise then you will have a bright, fuzzy picture with white lines (retrace lines) through it. Tune in a channel with white letters on the screen and turn the top (focus) control until the letters are crisp and sharp. Go into the menu and turn the contrast and brightness all the way down, and then turn the bottom control (screen) until you can just see the picture, just above the point where the picture is too dark to see. Go back into the menu and reset the contrast and brightness and the picture will be back to perfect.
Jun 28, 2007 | RCA 32V420T 32" TV
Ccreen quality
There is no yellow tube my freind, only a red, blue, and a green one. If its too bright, have you tried to turn down the black level yet or brightmess, and also the contrast. On these sets you don't need to have the brightness up way high, as the contrast does this. If, when you turn down the brightness, and the picture looks dull, you may need to clean off the mirrors, and or the lens for the picture tubes. If that does not help, there could be a problem in the screen drive circuit or the high voltage block. Good Luck Ps Please do not forget to rate this thread.
Dec 08, 2006 | RCA P52926 52" Rear Projection Television
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
