Power to monitor but no images just ALL black
  • 95 Answers
For this issue you can try following
  • check if tower has power or not if there is no power on tower then it is a power supply
  • If the computer has power restart the computer and tried to get in BIOS if it has no display it could be video card.
If you can see the BIOS screen
  • make BIOS default.
  • reseat the ram
  • video cable
Posted on Sep 30, 2010
  • 27,725 Answers
One bad/faulty lead can cause a computer with lots of prolems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
2407 screen goes black
faulty connector... need to call a repair guy to solder a connection.. usually 50 bucks
Apr 20, 2012 | Dell UltraSharp 2407WFP 24" LCD Monitor
I have a Samsung Sync Master 731BF and when I switch it on, the power light stays on but the image is black and wont show any picture whatsoever.
Hook a spare monitor to the computer to rule out the Video Graphics Card in the computer, if okay! It is the Samsung, "power supply issues" bad capacitors, sometimes show a bulge at top. But to be on the safe side replace the video cord from the computer to the monitor if possible.
Mar 31, 2012 | Samsung 731BF (Black) Monitor
My monitor is on but no image at all the cpu is ok when i tried it to other monitor, but with my monitor it is black out but when i try to on and off the monitor an image will pop and turn to black out...
you have a defective monitor due to power error of its own, it can't maintain a 100% power to support all of its electronic parts inside of it. Buy a new one
Jul 31, 2011 | Computers & Internet
Samsung SyncMaster 174v will display image for 2 seconds then go black. When I turn monitor off and then on again, it displays image with normal brightness for 2 seconds and then goes black. When I plug...
Hi
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Your monitor power supply has several capacitors going bad. You’ll need to have these replaced by a reputable repair person or check my website www.micromendllc.com. Thanks
Mar 10, 2010 | Computers & Internet
IBM ThinkVision L191p after power on, remain black.
First place to chaeck will be power supply, the problem can also be caused by bad inverter circuits, bad lamps, see example of failed monitors due to bad caps, lamps, http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Feb 11, 2010 | IBM ThinkVision L191p (Black) 19" LCD...
Monitor Goes black, or flickers on and off
The high pitch sound is coming from the inverter. It is faulty and needs to be repaired or replaced. The inverter supplies high voltage to the CCFL lamp, this lamp gives the backlight to the LCD so you can see the LCD images.
Check out LCD parts for parts, service and DIY info. use this link :-
www.lcdparts.net
Aug 29, 2009 | ViewSonic OptiQuest Monitor
Monitor displays image for second and displays black again
Your Monitor has a heat sink issue. A capacitor in the monitor is at fault and when it heats it tells the monitor to turn off the display to save the display from damage....Problem Cost to repair will supercede the cost to replace it...Wal-mart 15" monitor 119bucks --17" monitor 129...same at staples office supply (Poof) problem solved.
Mar 21, 2009 | Gateway FPD 1810 18.1" Flat Panel LCD...
Monitor image comes up, then blacks out, power still on
Hello David,
This is very common problem and is heat/age related, but It can happen to monitors that are no more than a year old. It is usually bad capacitors on on power inverter board. I just fixed two monitors with this problem. This problem is common across all brands. Look for several radial capacitors in a cluster on the power inverter board. If some are bulging or have a slightly domed top, they are the ones that are bad. I usually replace all the capacitors in this small cluster because some may be marginal. This is easy to do if you have a bit of electronics skill.
Dec 27, 2008 | Rosewill MNTR |LCD 19' 8MS DVI R912E...
Hansol 730E CRT monitor
REPLACE THE BOOSTER C 5,6nF-1600V
Oct 18, 2006 | Hansol 730E 17" CRT Monitor
Computers & Internet Logo
90 people viewed this question
David Payne
David Payne
