Question about Vulcan E36XL Electric Kitchen Range
I have a Vulcan-Hart range model E36L. The problem I'm having is that when you turn on the top burners the red indicator light comes and it starts making this sizzing noise. When the light goes off the noise stops. How do I get to bulb to replace it? or is that the problem?
2 Suggested Answers
Treefrog15
  • 127 Answers
SOURCE: One of the top burner pilot lights will not stay
You probably have grease that has gotten into the pilot. Turn off the gas to the pilot and detach the pilot tubing and pilot tip. It sometimes helps to take a propane torch and heat up the pilot tip and tubing, paying special attention to the first bend from the pilot tip. Get it red hot and tap out any ash from the inside. You may have to **** out the tubing with a piece of bare wire or blow it out with WD-40. With the oven pilot, check the pilot flame. If low, adjust. If OK, replace the thermocouple. If neither of these corrects the problem, replace the pilot satety. I always recommend a new thermocouple with a new pilot safety.
Posted on Feb 25, 2010
I have current out of my thermostat but no gas flow to burner
Thermocouple sending pilot flame to allow gas to pass through gas valve?? Is it dirty try cleaning it
Jan 12, 2016 | Vulcan Hart GH60TC Griddle Tope Heavy Duty...
Vulcan oven pilot light how to relight
Hello Lynne,
To relight the pilots,start by removing the floor of the oven,then remove the small access panel below the doors. On the main oven burner will be a small pilot burner that probably looks something like this 10_26_2011_9_29_16_pm.jpg
on the gas valve behind that small panel under the doors will be a red button,push that red button and hold it in while lighting that pilot burner...continue tohold that red button for 30 seconds,release it and the pilot should be lit.
Good luck,GENE
Oct 26, 2011 | Vulcan 60XLC Gas Kitchen Range
We are cranking up this BRAND NEW Vulcan flat top. Weh have the convection oven below up and running, but we can't even see a pilot light for the flat top. Advice anyone? Culinary-yours Chef Geir
older ovens have pilots but the newer machines are electronic ignition,there are ignitors in the oven and electrodes or ignitors on the top burners,when you turn the knob for the burner you should hear a clicking sound and see a spark around the burner,that's what lites the burner,the gas comes in and the spark ignites it,i don't know much about your machine but it can't be any different from other stoves.if none are sparking there should be a spark module in there or they could have separate modules,if you send the full model number i can look it up for you
Oct 30, 2010 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
The pilot lights ok,the burners light,but after sometimes 5 to 10 minutes later both will go out
The gas for both passes thru the FMDA Safety Valve - in you case it's defective and must be replaced. You can find it here
http://midwestapplianceparts.com/stove-oven-range-58/vulcan-hart-parts-773/oven-safety-valve-1050/vulcan-hart-fmda-safety-valve-6253.html
Oct 02, 2010 | Vulcan EF3 Deep Fryer
Feb 23, 2010 | Vulcan Kitchen Ranges
I have a vulcan VG36-66. We turn off the oven and
if your oven is automatic check the clock is in manual.
Sep 28, 2009 | Stoves 36" VULCAN RANGES GAS(CLICK HERE):...
Red light stays on indicating burner is on when burner is not on.
It should stay on after the burner has been turned off and remain on until the top has completely cooled down,if it stays on and never goes off, the thermostat for one or more burners is faulty and will need replaced.
Jul 26, 2009 | Frigidaire FEF366 Electric Kitchen Range
My vulcan burners lit but I can't get the OVEN pilot to light . What are the steps to light the oven ?
use matches,the pilot ligth is hard to replace unless in the tecnician can do,and hard to find the parts.
tnx.gerbee
Jul 04, 2009 | Vulcan GCO2D Gas Single Oven
Need to calibrate oven
The model number you listed isn't in the current or 'retired' products list.
If you find that F60 is in error, you should be able to download a manual here:
Vulcan-Hart
Feb 26, 2009 | Vulcan E60FL Electric Kitchen Range
Vulcan E36XL Electric Kitchen Range Logo
43 people viewed this question
Top Vulcan Kitchen Ranges Experts
Treefrog15
Treefrog15
starztruck4u
Are you a Vulcan Kitchen Range Expert? Answer questions, earn points and help others
